Ruthven13
I don't think the slotted rotors are as big a problem as the drilled are for people who offroad frequently. It makes sense if the holes fill with mud and then you get don't get heat dissipation like you should and possible scoring of your rotors from the dirt getting between the pad and rotor? So drilled AND slotted would be the double whammy? I have the drilled & slotted Power Stop on my 5th with never an issue but IH8MUD and don't go through much of it anyway.
For some reason searching for the right calipers is a PIA, at least for me anyway. I plug in the make and model on amazon, click on the search listings, and then it tells you this part doesn't fit. Well why did I just plug in my make and model and the website lists parts that don't fit? I just purchased Centric 5th gen front calipers and power stop pads for my 4th gen. When it came to 4th gen rear calipers I have read that the 5th gen version might cause a fitment issue with E-brake components and they aren't really an upgrade anyway. Apparently trying to piece these parts together and not buying a full kit is somewhat taboo for the innerweb. Took me 30 minutes to cross reference 4th gen rear caliper part numbers from Centrics website and get amazon to show me those Centric offerings. Then it took me another 20 minutes to get Amazon to show me Powerstop rear pads as a stand alone item. I guess my search parameters are flawed. Or maybe Im is Puter illiterate.
1988 DLX 22RE AUTO BLACK-
"Granny" - SOLD
2003 SR5 SPORT V8- Build-
"Pearl" You Tube
2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD
THREAD
