12-08-2019, 07:46 PM
#16
Share some pics/info on the covers
2006 4-Runner XSP V6
SCS Ray10 17x8.5 (Matte Black)
Falken ATW3 Wildpeak 265/70/17
Daystar 2.5/1.5
12-27-2019, 07:05 PM
#17
I too need to find a solution for this. My 4th gen seats feel like im sitting on bricks. There is 150,000 miles on these concrete slabs.
I have been looking into maybe getting the corbeau 4th gen seat brackets $119 but the part that is holding me back is I havent seen a corbeau seat less than $500. If I do the passenger seat that is another $500+
I am hoping to find a solution where I can get both seats done for about $500
12-28-2019, 11:48 AM
#18
Real Name: Elliott
Real Name: Elliott
Custom Fit Neo-Camo Seat Covers for Toyota Avalon | eBay seat covers
RaoRanDang Car Seat Cushion Pad for Car Driver Seat Office Chair, Computer Chair with Non Slip Bottom Memory Foam Seat Cushion (Gray) https://www.amazon.com/dp/B07RX2ZTJL..._uK3bEb40C3G49
Cushion
Google Drive: Sign-in
Finished product
Let me know if you can't view the links
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
12-28-2019, 12:13 PM
#19
Real Name: Skip
Real Name: Skip
Originally Posted by 81runner
When you ordered the seat covers, was it for an Avalon or 4th Gen T4R?
2004 Limited V8
12-28-2019, 12:18 PM
#20
Real Name: Elliott
Real Name: Elliott
It was for the 4th gen. When you order the set, the seller will contact you about your vehicle, ask a few questions about how the seats are set up. They CNC these to order so you get to choose your pattern and everything, made in Texas I believe ('Merica!) Comes with install instructions, I just elected to remove the seats to be more efficient and save myself the strain on the back doing the install with seats in the vehicle
07-04-2020, 09:31 AM
#21
Found some really nice custom covers on eBay, made to order the set was $200. Bought a nice foam cushion for the seat on the driver side and installed the covers over that. Couldn't be happier, looks great, feels great. I think all in I'm at $220 or so plus about an hour of my time removing the seats to install the covers. Just make sure you unplug EVERYTHING under the seat, there is still power for the seat belts and lumbar adjustment.
On my 2004 sport model, the foam and bottom seat covers were interchangeable between driver and passenger sides. Got a lightly used passenger seat and rebuilt the drivers side with the parts
08-10-2020, 03:05 PM
#22
5th Gen or Tundra swap??
I don't have any parts in front of me to check but I find it hard to imagine that Toyota wasn't lazy enough to upcycle lots of parts into the 5th gen. Might seats be one of them?? Anyone have access to a friendly neighborhood 5th gen to see what kind of connectors and size differences there are between the two. I'd gladly pay a few hundred bucks for some "new" 5th gen seats for the front of my 4th gen. An FJ Cruiser might also be a donor but some of those parts will be nearly as old as the 4th gen so finding a "premium" set of those seats will be equally hard as the 4th gen.
I just took mine for a swim this weekend and my Airbag light is now on. I wonder if the "sensor" in the seat is bad but I'm not sure the driver's side has that. I haven't had anyone in the passenger seat yet to see if it goes from off to on there on the dash.
06 Sport 4x4
185K and counting
Bilsteins, FJ/Tacoma springs
Nitto Terra Grapplers
11-27-2021, 08:43 PM
#23
Real Name: Adam Gilliam
Where did the foam come from
12-09-2021, 07:26 PM
#24
Hi everyone! My driver's seat in my 06 just started making a creaking noise and the left side of the foam is collapsing a bit. I'm guessing I either broke the support springs and/or the foam is shot. Do I need any special tools to take the bottom cover off and inspect the innards?
