06-04-2018, 04:12 PM
4th Gen front seat swap options?
What are some suggestions on seats that are bolt-in with factory rails? Either from other 4runners or other make/model cars/trucks?
My truck is an SR5 with leather seats, all manual adjustment.
My 4Runner's seats look like a Ninja had a temper tantrum on them and the leather is ripped up beyond repair.
I'd like to make it a bolt in affair rather than taking apart the seat or buying a single cover replacement for $300.
06-04-2018, 04:19 PM
I have the sport cloth seats and although they still look clean, the cushion is shot and support just isnt there for long trips. . been wondering the same thing.
Some research ive found:
Metal tech has some aftermarket seat kits available.
Most people have success with high quality seat skins, katskin or clazzio
I couldnt find any good convincing threads of OEM seat swaps from another vehicle. and it would most likely require some decent modifications to make it work.
06-04-2018, 10:47 PM
I have, in the past, taken the passenger seat out of a 4Runner, pulled the cover and foam, and re-did my driver seat with that less used alternative. Now, I haven't done it on a 4th gen, so your mileage may vary.
06-04-2018, 10:51 PM
Might be worth checking out your local reupholster for a quote.
I've seen a few guys on here have the leather replaced and it's not too expensive for just one seat bottom.
'99 SR5, 2007 Sport
06-05-2018, 11:54 AM
Real Name: Derek
Real Name: Derek
Your pic is of a 3rd gen. Maybe a different T4R needs the fix...
Was a little talk of a seat swap in the 3rd gen section.
Recaro Seat Install
May get more info over there.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
06-06-2018, 03:17 AM
Real Name: Matt
Real Name: Matt
I've been thinking about installing a Recaro racing seats into my T4R, since that seat is STUPID comfortable. There are plenty of brackets out there, so that you can install your seat...
The only problem I'm having is that there isn't all that information on:
1. Height adjustment. My Recaro seat is at LEAST 3" lower than the OEM seat. Most, if not all, after market seat brackets for the T4R only account for X and Z axis adjustment. No Y-axis adjustment. I came across a guy who installed racing seats onto his factory rails on here, so that he could retain the Y-axis adjustment, but he hasn't gotten back to my PM. I guess he doesn't check T4R anymore.
2. Wiring. You'll want a way to trick the system to thinking you still have your OEM seat with the airbag, so you don't get A) an airbag light and B)disable your airbag system completely, without having to trip the system when you go installing it... There just isn't enough documentation/posts to make me want to do it comfortably. Sure there are a few users here who have done it, but... they don't state what resistor and which wires they tapped into.
06-15-2018, 01:24 PM
Recaro Seat Install
My 3rd gen had a much more interesting life. I haven't done anything worth taking pics of in the 4th to make it signature worthy lol.
01-16-2019, 11:41 AM
I have looked into this, and while I cannot 100% confirm- the GX460 seats look like they share the same mounting pattern, and may bolt in with minor mods. Since the controls are on the seat, supplying power should enable all of them to work(including the venting hopefully), however the memory function may prove more difficult. I love my 4runner- but being 6' tall, even with extended travel rails the seats are really uncomfortable on long trips.
Imgur: The magic of the Internet
I plan to try this on the driver side as soon as I can source a 460 seat with ventilation. My 4runner is Grey, and the Lexus seats only come in black, brown and tan it seems.
11-21-2019, 07:12 PM
Update to this thread, I ended up replacing my driver seat with a power model
11-21-2019, 07:27 PM
The lumbar support on mine is uncomfortable at any level. I find i just keep shifting around while driving. Related question- Do your seat backs have some give and move? Sometimes when getting in the seat back will move almost an inch or so and going around tighter corners I can hear something inside the seat back moving. Maybe mine is just broken.
Sent from my SM-G950U using Tapatalk
11-21-2019, 09:38 PM
How much and how hard was it to do?
11-22-2019, 07:56 AM
Real Name: brian
Real Name: brian
I ended up replacing the bottom leather on both my 4runners with the covers found on ebay and ordered new foam from toyota. Im into the new foam upper and lower seat sections and lower cover for under 500.00 each seat. I got the comfort back and the interior is now a nice place to be in.
'08 4Runner Limited V8 Shadow Mica: Sport hood, bilstein 6112's, 5160's, b12 coils, Gibson cat back, 4runner XSP rims, Michelin X LT AS 275/55-20
'06 4Runner Limited V8 Salsa Red: bilstein 6112, 5160, Wheeler T12's, 4Runner XP wheels, Michelin AT2 275/55/20, Magnaflow Exhaust,, Powerstop brakes, sport hood
RIP.....'08 4Runner Limited V6: white, bilstein 6112s, 5160s, b12 , powerstop brakes, nav, TRD cat back, 4Runner XP rims, Michelin Defender LTX 275/55-20, sport hood
12-08-2019, 04:00 AM
Real Name: Seth
Real Name: Seth
So I have run several seats in my 2004. Honestly, the OEM seats are the best.
My first set of swap outs were $250 JDM racing buckets, welded to the stock slide adjusters. No problems with this setup, just too stiff for my back after a while.
Second set of seats were from a 2003 Lexus RX300. They sat probably 2-3" taller than OEM seats, and were at least 3" wider making it impossible to get to the electronic seat adjusters with the doors closed. They cost me $50 and were fun.
Third set of seats are from a 2004 that came with leather, power, and heat. Back to OEM for me, but an upgrade from my non-power cloth seats.
2006 Shadow Mica SR5 v6 1" BL, Fox Racing UCA's, RC 3" N3 Lift, Rock Trix RT110 -12 Wheels, 315/70R17 Goodyear Territory MT, Tacoma Front Bumper, 5th Gen 4R Tire Carrier, Big Lion LED's
12-08-2019, 01:07 PM
I’m also interested in this but want OEM only options as my experience with aftermarket seats/covers is not good in terms of quality.
There are three things I don’t want to have to deal with due to expense
- engine problems
- transmission problems
- seats
2006 4-Runner XSP V6
SCS Ray10 17x8.5 (Matte Black)
Falken ATW3 Wildpeak 265/70/17
Daystar 2.5/1.5
12-08-2019, 07:25 PM
Real Name: Elliott
Real Name: Elliott
Found some really nice custom covers on eBay, made to order the set was $200. Bought a nice foam cushion for the seat on the driver side and installed the covers over that. Couldn't be happier, looks great, feels great. I think all in I'm at $220 or so plus about an hour of my time removing the seats to install the covers. Just make sure you unplug EVERYTHING under the seat, there is still power for the seat belts and lumbar adjustment.
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
