Originally Posted by Seymore Butts
Does this report's oil data contain any information that can be used to deduce your optimal oil change interval? If so, what does it imply about your next interval?
Yes it can, however I didn't have that particular test done, because I don't do extended change intervals, and it's an additional charge to have done. Down at the bottom of the report on the left side, you will see TBN. If you have that test done, it will tell you how much more life is in your oil at what mileage you did the sample at. It will tell you that you can either go longer on your next oil change, or you went to long.
John
2004 SR5 V-6 4X4. 2" lift.
2016 4Runner 4X4 SR5
