Originally Posted by gookies
I was unable to find an answer for this, my assumption still remains the same, the coil springs may be a bit beefier to account for the additional weight compared to a 2WD.
your assumption is correct, the 4WD version has a slightly taller spring with a higher spring rate than the 2WD. would probably give at least 1.5" lift over stock.
the KYB coil over shocks (they are not struts) are ~10% stiffer valving & spring rate vs the factory shocks/springs, on a 4WD this will give a slightly firmer ride & about a 1" lift over stock which makes for a nice more level stance.
