Old 07-19-2018, 07:36 AM #16
Johns06yota's Avatar
Johns06yota Johns06yota is offline
Real Name: John Iannacone
Johns06yota has a spectacular aura about Johns06yota has a spectacular aura about
Originally Posted by jamesewells View Post
I know very little about painting. What king of prep did you do? Thanks!
Originally Posted by DZNUTS View Post
Did you wet sand between paint coats and clear coats??
Originally Posted by 2003-4x4runner View Post
I love what you did, looks Great!
For the prep with the trim I used a soft foam sanding block so I could get in all the corners. Next I wiped everything down with 90 percent isopropyl alcohol then after that was dry sprayed 3 layers of base coat (warmed the can up in hot water) then later went back over everything with three coats of clear. (Also heated up the can) I did not wet sand anything. There is a little orange peel but nothing I am going to worry about haha
Johns06yota is offline   Reply With QuoteReply With Quote
Old 08-17-2019, 10:03 AM #17
TampaBay_4Runner's Avatar
TampaBay_4Runner TampaBay_4Runner is offline
TampaBay_4Runner is on a distinguished road
Originally Posted by Johns06yota View Post
Thanks!!
How did you paint around the transmission shifter? I removed shift indicator but the indicator plate behind the trim piece appears to be permanently adheres to the trim. I’m not having much luck cutting small pieces of painters tape to cover the shift indicators. Also, how did you remove the trash bag holder?
TampaBay_4Runner is offline   Reply With QuoteReply With Quote
Old 08-17-2019, 05:32 PM #18
I actually just cut the plastic tabs that hold it in place to remove the indicator to paint. Afterwards I just glued it back on. The trash bag holder takes some force but once open it pops out from the side
__________________________________________________ ___
If you are looking for custom 4runner parts, then look no further!
iannaconeautoaccessories.com
Old 08-17-2019, 11:34 PM #19
Thank you. I ended up doing the same thing with the shift gate. I’ll have to work on the trash bag holder tomorrow. I appreciate the reply!
Old 04-07-2021, 05:20 PM #20
gigajoe's Avatar
gigajoe gigajoe is offline
gigajoe is on a distinguished road
gigajoe's Avatar
Did you paint the silver door trim as well? If so how did you get it out?
thanks
2009 Trail Edition
4thgente on Instagram
gigajoe is offline   Reply With QuoteReply With Quote
Official 3rd Gen 4Runner Interior Trim Color Code Guide SURF RUNNER 3rd gen T4Rs 37 09-08-2023 01:12 PM
Interior Trim Color 06 Limited Texas8668 4th Gen T4Rs 2 08-08-2016 04:59 PM
Oem interior trim color options xspsi6 3rd gen T4Rs 2 01-16-2015 03:24 PM
3rd Gen Interior Color Code segafan1989 3rd gen T4Rs 2 07-09-2014 03:49 PM
Color code for Galactic Grey Rez90 4th Gen T4Rs 3 11-18-2009 12:41 PM
