07-16-2018, 10:41 AM
Interior grey trim/bezels color code?? Anyone figured it out?
I’ve searched for a long time and I don’t think anyone ever figured out the exact color to touch up scratches in the Grey (Stone??) 4th gen interior.
I found a thread that says “Rustoleum universal (not just for metal) satin nickel“ is a 95% match.
I tried 1D4/Titanium Metallic, and it’s too shiny. Not even close.
I’m wanting to touch up the silver/gray area where the transmission indicators are and the sides of that area, the console. Two large scratches are there.
I can’t vinyl wrap it, I have read that stuff doesn’t work well in cold climates. I’m in Wisconsin, so that’s out.
Has anyone figured it out a touch up code that works?
May have to go to a body shop, as a last resort if not.
2022 LUNAR ROCK TRAIL SPECIAL EDITION
2010 MAGNETIC GREY SR5 PREMIUM
2004 V6 WHITE 4RUNNER SPORT
1995 V6 3.0 BLACK 4RUNNER 4X4 (Retired)
4th & 5th Gen UCA Install Thread
07-16-2018, 11:49 AM
Not sure what part of the interior you're referring to specifically, but could you remove a piece of the trim that matches and take it into a store and have them color match it for you, using one of the paint machines? Just a thought.
07-16-2018, 12:26 PM
Pics added.
Your way at be the only way
@ OliviasDad
Real Name: Derek
Real Name: Derek
I had it in the back of my mind to use this stuff at some point, in black.
Redo all the silver that has been scratched up over the years.
VHT Wrinkle paint to help hide the deeper gouges.
https://www.eastwood.com/vht-high-te...5deae449731b0a
Good grief the spelling correction is fighting me today.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
07-16-2018, 01:33 PM
Would you have to get adhesion promoter so it would stick?
I figured it will still scratch off, why I just want to touch up the areas that are blatant.
The 4runner is 15 years old, after all.
Very interesting idea. That stuff is tough as hell, I have heard.
07-16-2018, 03:26 PM
Real Name: Derek
Real Name: Derek
I have not done it.
Was thinking a slight sandpaper scuff-up...no turning back at that point.
Then a good wipe down with 99% isopropyl.
A couple spots I have would need a sanding and some body filler to look good all smooth and shinny.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
07-16-2018, 09:41 PM
Real Name: John Iannacone
I’ve searched for a long time and I don’t think anyone ever figured out the exact color to touch up scratches in the Grey (Sone??) 4th gen interior.
Not sure if you would want to do this but after not being able to find touch up paint for it I ended up just repainting all the trim to match the sport edition. Here were the results. I used a 2K clearcoat in a can, rustoleum Carbon mist metallic.
07-16-2018, 10:45 PM
That looks really good! I have some scratches that really bug me in the silver trim, and was considering just going with a darker charcoal type color, so it’s nice to get a preview of how it would look. Like the OP, I can’t seem to find a good match for the original silver anyway.
2004 black SR5 V8 4WD with TRD dual exhaust, Thorley headers, AFE dry filter, Sprint Booster, Icon 2.0 rear shocks, OME 895E springs, Fuel wheels with 265/70/17 Wildpeak AT3W tires, more to come...
07-17-2018, 12:26 AM
Thanks! and that was my issue as well and once I looked closer the paint itself was fading anyway so I went ahead and repainted. Prep is key to a good outcome
07-17-2018, 06:45 AM
The only thing holding me back is that on the ‘04, there is also a silver bezel around the gauge cluster (more silver than just the rings on the later years like yours). There is painted black lettering to label the 3 buttons on it that control the odometer functions that would get painted over with a color change, and I think it would look odd if that panel wasn’t painted to match the rest of them. On yours it looks fine because as I mentioned, it’s much less silver that shows.
07-17-2018, 07:38 AM
You worked your butt off and it looks amazing!
07-17-2018, 07:59 AM
Thanks!!
07-17-2018, 09:07 PM
I love what you did, looks Great!
2003 V6 BLACK SR5 4X4-Runner
OB #1334
https://www.instagram.com/ob_1334/?hl=en
Dad's Travel Service.
We drive around till we find it. No map's needed!
07-19-2018, 03:32 AM
Real Name: Jimmy
Real Name: Jimmy
I know very little about painting. What king of prep did you do? Thanks!
2003 SR5 V8 2WD, Borla Exhaust, Volante Intake
Stebel Truck Horn, All LED Conversion, Map Light Mod
2014 Scion Touch Screen Radio, Lexus Steering Wheel
Lexus Shift Knob
07-19-2018, 06:25 AM
Did you wet sand between paint coats and clear coats??
1995 ECR33 GTS-T (sold)
1990 s13 coupe TONS of work
2005 4Runner Sport V8
