07-18-2018, 07:02 PM
#16
Ordered for my 4th gen! Thanks for putting these together, been waiting since shortly after the 3rd gen ones!
07-18-2018, 07:50 PM
#17
Official Vendor
Official Vendor
my pleasure!
keith
eimkeith.com
all product descriptions © eimkeith LLC 2016-2023
07-19-2018, 12:57 PM
#18
Real Name: Danny
Real Name: Danny
How soon until these start shipping? Definitely picking one up on my next pay check.
07-19-2018, 01:07 PM
#19
Official Vendor
Official Vendor
I pick them up on 8/3, if not before; will be shipping by 8/6 (if not before.)
keith
eimkeith.com
07-19-2018, 01:08 PM
#20
Real Name: Danny
Real Name: Danny
Sweet, so I've got a couple weeks.
07-19-2018, 01:29 PM
#21
Official Vendor
Official Vendor
probably - although 1/2 of the run has been reserved already.
if you miss this run, there will certainly be another!
keith
eimkeith.com
07-23-2018, 01:26 AM
#22
Real Name: Blair
Real Name: Blair
Just ordered mine!
2008 4Runner Sport Edition 4WD V6- Long Travel, Camping Rig Build Thread
2023 Lexus LX600 F Sport- Daily Driver
2023 Highlander Hybrid Limited- Wife Daily Driver
07-23-2018, 04:27 AM
#23
Ordered!
07-23-2018, 06:43 AM
#24
Real Name: Steve
Real Name: Steve
Just ordered one! I have a new to me axle housing with e-locker coming to me and I'll put it on before install. Gonna be awesome with all the new goodness coming for my truck!
'15 Mag Gray LE -- TOTALED | '14 TE wheels - dipped black, Falken AT3W 285/70/17 | SPC Adjustable UCAs | Daystar 2.5/1.5 top spacer lift | RCI Fuel Tank Skid (Steel) | Shrockworks Step Sliders (trimmed LE Rocker Trim) | SR5 front end conversion
'08 BP Urban Runner -- 5100 fronts at .85 with Toytec 620# springs | SPC Adjustable UCAs | Plastics Guy Front Bump Stops | ICON VS 2.0 Rear with Toytec Superflex 2 inch springs | RCI Transition, Front and Transmission Steel Skid | LT275/65/18 Falken Wildpeak A/T3W | 1.25 inch wheels spacers
www.4runnerfamily.com | IG: Runn4est
07-26-2018, 11:41 AM
#25
Real Name: brian
Real Name: brian
Whew! Just found this, and ordered! Thanks for doing it.
Took me a little backtracking to figure out 4th & 5th gens are the same, so consider clarifying that on your ordering page?
'04 v8 4WD Galactic Gray Mica
JBA UCA, OME 885/895, 295/70R17 MXT's, RCi skids, stainless lines, interior LEDs, and a handful of other minor tweaks, upgrades, fixes, or replacements
07-26-2018, 01:12 PM
#26
Official Vendor
Official Vendor
Sure thing!
Sent from my iPhone using Tapatalk Pro
keith
eimkeith.com
07-26-2018, 02:16 PM
#27
Awesome! Been waiting on this. What is the max height (lift) you have made this for? Mines about 5" of lift, so this will be better than nothing but curious to what extent you designed this for.
Thx
Mark
Mark
04 V8 SE, RST Twin stick conversion. 4x4 Labs rear bumper, SW Sliders & Bullbar, ARB Locked F&R, 5.39’s, Smittybilt 10,000lb winch, 1.5 4Crawler BL, Flowmaster, CB and 2m/70cm Ham, Sat. Radio, CO2 system, Lightforce, African Outback Rack, Budbuilt, Front Runner RTT. Rock Solid Toys Solid axles, Atlas Crawl Case, 40" Cooper STT Pro's on Fuel Anza D116 beadlocks, 5:38 gear set, ADS Coilovers.
07-26-2018, 07:43 PM
#28
I may be over-analyzing this, but my 4Runner has 3" lift springs in the rear and the centers of the ends of the panhard bar are just about 3" different in height. It certainly makes sense to raise the axle mount to level the bar back out, but it looks like that would get close to the frame/underside of the body. Does this create any type of interference that has to be accounted for?
Thanks!
~Doozi
Doozi's 2006 Sport Edition V6 4WD - Titanium Metallic - purchased 09-13-10
Dobinson's F: C59-302/GS59-220, R: C59-677V/GS59-575 / LR UCA's / Medic links / LT285/70R17 DuraTracs on Countersteer Type-X wheels / WeatherTech DigitalFits and Window Visors / Rear Diff Breather Mod / J.A.'s Fog Light Mod / Centric Premium rotors w/ Akebono Pro-Act Ultra Premium pads / LED interior lights / HIDs (4500k lows) / Man-A-Fre engine+tranny skids / RCI MetalWorks T-case skid / B.A.M.F LCA skids / CBI front/rear, Sherpa Equipment Company roof rack, WKOR sliders welded on, Panhard Correction Kit... Lovin' it!
07-26-2018, 07:56 PM
#29
Official Vendor
Official Vendor
Thanks!
~Doozi
Hey Doozi - I assume you're talking about overhead clearance of the raised bracket, yes?
On the 5th gen I used to model and prototype the bracket, I went as high as you can go with the factory bump stops and still clear the overhead crossmember at full compression on the driver's side rear. That gives us a 3.4" lift on the axle side of the panhard bar. (I also put another hole an inch below it for milder lifts) The 4th gen I had in the shop to verify fitment had the same architecture (which is terrific for this situation)
If you're running extended bump stops to limit your up travel (because of shock compressed length) you have even more overhead room!
keith
eimkeith.com
07-26-2018, 09:46 PM
#30
Perfect! Thanks for the info! I have 3” bump stop drops so I’ll have luxurious clearance! LoL!
I’ll be ordering later this evening.
