04-25-2019, 10:06 PM
#91
Oh, and I don't have any issues with oversteer or pulling to either side. Maybe my lift is too mild to require the PCK.
04-25-2019, 11:31 PM
#92
Real Name: Danny
Real Name: Danny
Originally Posted by HomersCanyonero
I know these PCKs work on the GX470 = 4th Gen, but I'm only lifted like 1.5" in the rear using the air bag trick. Is there a minimum lift required before you really need the PCK? Just wondering...I'm usually on IH8MUD and someone referred me to this thread on the PCKs.
There's basically 3 settings. Stock, 1-1.5, and 2.5-3" roughly.
Sent from my Pixel 2 using Tapatalk
04-26-2019, 01:51 AM
#93
I'm surprised that rigs that are stock or up to 1.5" lift in the rear are having issues with the panhard. So, it's interesting that PCK supports those lower settings.
What specifically am I supposed to be fixing in the 1.5" rear lift? I don't have or feel any issues with steering.
Maybe my setup would help understand my non-issues:
Front:
TotalChaos UCA
New Toyota LCAs
Bilstein 6112s
Rear:
Air bags raised about 1.25" to 1.5" depending on what the original stock height was in the rear
OME 60004 shocks
Tires and wheels:
17x9 wheels with -12 offest
285/70R17 Nitto Ridge Grapplers E
Again, I'm just trying to understand if I need the PCK or not.
04-26-2019, 08:50 AM
#94
Official Vendor
Official Vendor
Front:
TotalChaos UCA
New Toyota LCAs
Bilstein 6112s
Rear:
OME 60004 shocks
Tires and wheels:
Take a photo of your panhard bar angle and let's have a look at it.
keith
eimkeith.com
all product descriptions © eimkeith LLC 2016-2023
04-26-2019, 10:13 AM
#95
Real Name: Danny
Real Name: Danny
Front:
TotalChaos UCA
New Toyota LCAs
Bilstein 6112s
Rear:
OME 60004 shocks
Tires and wheels:
It's not that they necessarily have an issue stock, it's that the pck retains the stock mounting position which is why I added it into my post. Are you still running a rear sway bar? If you are then you likely don't notice the handling issues that come with your panhard being at the incorrect angle due to the lift.
04-26-2019, 10:23 AM
#96
3” lift, is this maybe why my truck tracks slightly left even after several alignments?
04-26-2019, 10:46 AM
#97
Front:
TotalChaos UCA
New Toyota LCAs
Bilstein 6112s
Rear:
OME 60004 shocks
Tires and wheels:
If your panhard is not level you will benefit from the correction kit.
The more angled it is the more benefit you get.
06-15-2019, 11:33 AM
#98
Yeah, I'm still running the sway bars in front and rear, so this might explain why I don't notice any issues with steering. Here's a picture of my rear panhard.
06-15-2019, 12:01 PM
#99
Official Vendor
Official Vendor
I think you’re fine as-is - when you add weight you’ll be close to level
keith
eimkeith.com
06-17-2019, 02:50 AM
#100
Recently got my lift installed and am sitting at about 4" of lift in the rear empty. Rear bumper will be going on shortly and being loaded up for camping I imagine it'll settle 1" or so.
I haven't noticed any steering or control issues but perhaps just don't know that there are any. My question is if I still have my rear sway bar on (front is off) will I still benefit from this?
Here's a pic of my panhard bard. There is definitely an angle and I'm sure the kit will level it out nicely, just wondering if having the rear sway bar on makes it pointless.
Thanks
Whytey's 07 V8 Build Thread
2007 Toyota 4Runner Sport Edition V8, Elka 2.5 Suspension, Total Chaos UCA w/ Delta Uniball, Dobinsins C59-677V Rear Coils, Timbren Bumpstops, Prinsu Design Roof Rack, Baja Designs Squadron Sport Fogs, 285/70R17 BFG KO2, Blacked Out TE Rims, Spidertrax 1.25" Wheel Spacers, Satoshi Grill
06-17-2019, 08:22 AM
#101
Thanks
I’m more worried about the rust on your lower control arms. Wire wheel and paint, your rig will thank you! Also, I really like the look of those black TE wheels, I almost did the same but figured it wouldn’t look as good on a white rig.
06-17-2019, 12:19 PM
#102
Real Name: brian
Real Name: brian
I only have a 3" lift, and did the panhard relocation. The change is subtle, but I hated the feeling of getting my rear-end thrown sideways with each bump at road speed. It is indeed noticeably improved now, but it's not a "night-and-day" change.
The panhard and swaybar have completely different jobs, and I'd suggest the swaybar's effect on tracking is insignificant. Whether the panhard relocation is worthwhile is debate-able (I'm glad I did it) but I'd say no, having a swaybar does not make it pointless. I run both with and without swaybars, and properly positioned panhard does its job regardless, especially since our rear sways are not especially stout anyway.
'04 v8 4WD Galactic Gray Mica
JBA UCA, OME 885/895, 295/70R17 MXT's, RCi skids, stainless lines, interior LEDs, and a handful of other minor tweaks, upgrades, fixes, or replacements
06-18-2019, 12:19 AM
#103
I just realized I can raise and lower my rear airbags, so I can check the angle of the rear panhard when I lower it 1.5” and raise it like 1.5”.
Does the pangard cause a lean to one side if the angle is bad?
06-18-2019, 08:32 AM
#104
Official Vendor
Official Vendor
Hey, just saw this. It's actually Stock, 2.4" and 3.4"
keith
eimkeith.com
06-18-2019, 08:33 AM
#105
Official Vendor
Official Vendor
No sir.
keith
eimkeith.com
