06-08-2019, 12:06 AM
#31
This is my favorite build thread I've read so far... choice mods, lots of creativity and DIY ingenuity, and making use of what you can find sweet deals on. Props to you sir!
06-08-2019, 07:30 AM
#32
Originally Posted by Whytey
My suspension pieces are all starting to come together. Just waiting on the last few major items to get shipped then the transformation will begin!
I was invited out for a short trip last night to a newly designated public land zone. So i threw some Spidertrax 1.25" Black wheel spacers on the day before and quickly threw in some Baja Designs Squadron Sport lights to replace my fog lights.
Following some advice from a local shop in town I cleaned up the hubs prior to installation and put a bit of antiseize between the spacer and the hub.
Before:
After:
And Wheel Spacers with new tire "poke":
These spacers gave me exactly the stance and poke from the fenders that I was after!
I have never been impressed with stock fog lights on any vehicle and this one is no different. I even put LED's in them to see if that would help but it still really only lit up the 3 feet in front of me.
So these lights have been on my list for a while and finally just pulled the trigger and installed them. It was unbelievably easy!
I followed YETIX Instructions and they fit like a glove. I did have to reverse the polarity on the connectors but that was it. Luckily I had one of the tools laying around that was designed for this cause before I found it I could not get the pins out for the life of me. Here is his build page with that info:
YETIX Build and Adventure Thread aka Travels with Savanna
I opted for the Squadron Sports over the Squadron Pro's because I wanted to be able to use them on the road in snowy or foggy conditions. I've heard the Pro's are just too damn bright.
The Sports seem to be a perfect level and love that I now have functional fog lights.
Plus the spacers now Bob Ross the crap out of my mirrors and entire side of the 4runner. Love it.
What is that filler piece you used to mount the sports? I’ve been considering a set of Amber sports I just don’t want any gaps between the square lights and round openings.
09-03-2019, 08:33 PM
#33
WOW nice 4runner!!
09-04-2019, 03:54 PM
#34
Real Name: The Native Explorer
@ Whytey
this is a wicked awesome build thread, props! Not to mention, killer photography. Curious, did you ever post a link to the center console organizers you ordered on ebay?
"Bumble" '17 Lim w/ 35k, IVD Stage 7, CBI/Prinsu metal, Morimoto lighting, ARB Linx : Build thread in progress...
The AventuRunner Build '07 V8 Sport w/ DO armor, Fox squish, Falken rubber, IVD UCAs, BD lights, Sherpa rack -- gonna miss the V8
The "Iceberg" Build... Natty White 3rd Gen ----gone, but not forgotten...
IG @apohl17
From ye fellow @Konkordmusk... "The 4Runner does not drive. It simply rotates the Earth to your desired position."
09-08-2019, 02:09 AM
#35
Originally Posted by Styner89
Nice build! I am looking to pickup a 4th gen in the next month or two and start my build. I came from tacomas and can't wait to get started. I just want a mild setup for the occasional beach champing trips I take.
Thank you! Hope you find the one you are looking for!
Thank you Zach!
And i'm just getting started! Haha, I guess it never ends. Few things to update on and a few more things on the way too.
I used the kit designed for the Tacoma's. Fit is pretty good and just requires drilling one hole in the bumper. Easy to do and far batter than the stock fogs.
Tacoma (12 - Current) / 4Runner (10 - Current) Fog Pocket Kit / Tundra (14 - Current)
Originally Posted by OffRoadRy
WOW nice 4runner!!
Thank you!
Originally Posted by apohl17
@ Whytey
Appreciate that! Thanks a lot.
Heres the stuff i got:
Toyota 4Runner - SALEX | ORGANIZERS
Whytey's 07 V8 Build Thread
2007 Toyota 4Runner Sport Edition V8, Elka 2.5 Suspension, Total Chaos UCA w/ Delta Uniball, Dobinsins C59-677V Rear Coils, Timbren Bumpstops, Prinsu Design Roof Rack, Baja Designs Squadron Sport Fogs, 285/70R17 BFG KO2, Blacked Out TE Rims, Spidertrax 1.25" Wheel Spacers, Satoshi Grill
09-08-2019, 02:54 AM
#36
New Elka Suspension
After 2.5 years of owning my 4runner I finally pulled the trigger on a proper suspension kit. Initially I had planned on going with Fox 2.5 in the front and Fox 2.0 w/ resi in the rear. But my local shop informed me of some new to the truck world Elka Suspension. Apparently pretty popular in the Snowmobile and Summer toy world. Figured I would give them a try. They do not offer a kit for the 4th gen 4runner so we had them put the correct size bushings in at the facory. Here are the specs:
Going from XREAS (100,000 miles) w/ Daystar 2.5"/1.5" spacer lift and 265/70R17 tires to Dobinsons C59-677V rear coils with 285/70R17 tires I gained 2.9-3" hub to Fender and 3.5-4.5" ground to fender.
Front:
Elka 2.5 Reservoir with DSC
Eibach 14"x650# spring installed (replaced 13"x700#)
Total Chaos UCA with Delta joint
Timbren Active Offroad Bumpstops
Rear:
Dobinsons C59-677V
Before I lifted I was running XREAS with Daystar 2.5"/1.5" Spacer lift on 265/70R17 wheels.
Measurements before:
Driver Front-
Ground-Fender: 36"
Hub to Fender: 21 1/8"
Passenger Front-
Ground-Fender: 36"
Hub to Fender: 21"
Driver Rear-
Ground-Fender: 36"
Hub to Fender: 21 1/2"
Passenger Rear-
Ground-Fender: 37"
Hub to Fender: 21 3/4"
After the lift I upped my tire size to 285/70R17's.
Measurements are:
Driver Front-
Ground-Fender: 38 1/4"
Hub to Fender: 22 1/2"
Passenger Front-
Ground-Fender: 38"
Driver Rear-
Ground-Fender: 40 1/2"
Hub to Fender: 24 1/2"
Passenger Rear-
Hub to Fender: 24 1/8"
I have had this kit on for about 4-5 months now and am very happy with it. On the road it is definitely softer (i also removed the front sway bar...) and offroad it is a dream. No more clunking or hard drops like I did with the Daystar.
The adjustability is nice and still need to play with it a bunch.
PRELIFT:
POST LIFT:
09-08-2019, 03:10 AM
#37
More Lift:
The local shop to me told me about a Canadian company; Elka Suspension, that was getting into the truck market. They come from a world of UTV's, ATV's and snowmobiles. I figured I'd give it a try and support a Canadian company at the same time. Currently at this time they do not offer these shocks for a 4th gen 4runner so Krave Automotive (my local shop) worked with Elka to get the correct bushings installed from the factory. These shocks come with 13" x 700lb coils (I believe) so I have a set of 14"x650lb Eibach coils installed as well. This provides me with a bit more lift and a softer spring rate (no front bumper as of yet.)
I paired these shocks with Total Chaos UCA' with a delta Joint pressed in (apparently better suited for our climate up here.) I put 2nd gen 4runner rear end links on (longer) and went with a pair of Dobinsons C59-677V rear coils. Timbren Bumpstops in the rear and I've got front ones on the way.
I've had this kit on the vehicle for about two weeks now and absolutely love it. I don't have much experience with aftermarket shocks so my comparison is coming from a spacer lifted stock XREAS suspension but these feel amazing. The shocks front and back have dual speed compression adjusters as well so I've been playing with that and tweaking to my liking.
Before:
After:
09-09-2019, 11:33 AM
#38
I posted this a while ago but figured I'd add it to my thread.
I Got back from a 700km trip and while I was getting the mud off as thoroughly as I could I noticed this:
Rear Lower Control Arm nut fell off somewhere and the bolt almost backed itself out completely. I did not feel anything strange but I'm pretty happy I caught it when I did. Can't imagine what would have happened if that arm dropped while on the highway.
Managed to get a new nut on in the parking lot of work. I had to use a ratchet straps to get the bolt all the way back through.
09-09-2019, 12:56 PM
#39
Registered User
Real Name: Morris
Registered User
Real Name: Morris
Yikes.....only "liked" as a dislike
09-11-2019, 08:57 PM
#40
Work has been getting in the way of my summer way more than I would like. But I am trying to get out as much as I can. Weather is changing and nights are getting colder here way up north but I figure i've still got another month or so of easy camping. Then i'll have to switch from the Duvet to a proper sleeping bag.Haha
I picked up a set of full Aluminum Skid Plates from R.A. Motorsports in Edmonton, Alberta. Installed everything but the skid plate yet (havent had time.) I figured Aluminum should be good enough for what I need. Not planning on heavy rock crawling but if they will save me from the impacts that would disable the vehicle then they are worth the money.
I have been in limbo with a friend of mine regarding my Coastal Offroad Rear bumper. Its sitting nearly completed and we have been playing tag with our availability to get the final fitting done before powdercoating. Hopefully dropping it off tomorrow to get that going soon!
Now i'm dreaming of a front bumper and sliders... Problem is getting them up here to Canada without getting gouged on currency exchange, shipping and duty...
09-12-2019, 01:04 AM
#41
This photo shook me for some reason. There’s probably not another soul around for miles. I used to backpack quite a bit and haven’t been out in four or five years. Missing it so hard right now. Thanks for the inspiration to get back out there.
As for the sliders and bumper. Have them built and powder coated, drive down and have them installed. Probably cheaper than shipping and import costs lol. Good luck!
09-12-2019, 03:27 PM
#42
Love that a photo made you feel that way!
Hope you get a chance to go on an adventure soon!
Might be the route I go. Unless I can find a local shop or fabricator to make me some. Would be my first choice.
09-18-2019, 04:58 PM
#43
Real Name: Michael
Real Name: Michael
Electrical Management System
I did a fair amount of research on electrical management and came across the Bussman RTMR Fuse Box and found a prebuilt one on Ebay. Fairly inexpensive and ordered one. Then began designing a tray for it to mount on. Began with some lexan from home Depot.
Can you provide a link for the bussman system as you have it setup? I have seen some pre-built ones online before but none like this...Did you just end up making this yourself?? Also how did you end up mounting that powertray?? Any close up shots? Also what model should I get?? Sorry for all the questions but I am about to get a similar electrical setup and want to do my research before I buy anything. Thanks!
Titanium Metallic 2006 Limited 4WD V8 | Doug Thorley "Premium" Long Tubes/Modded Ypipe | Magnaflow dual in/dual out | True Dual Exhaust | Fr: 5100/885/SPC R: Icon 2"/2nd gen links | 285/75R17 G003s | Sherpa Princeton | Baja Designs | 5th Gen Brakes | Everything else is in the Build Thread
09-18-2019, 05:19 PM
#44
The Bussman unit I bought came wired already. There is a guy who builds these and sells them on Ebay. I will try and find a link to it.
Send powertray's an email and inquire about the 4th gen tray with the Bussman cut out. They did this for me a year and a half ago so should still be do able.
The powertray is designed to bolt right in. I'll see if I have any pics of it for you.
I used this thread:
DIY - Build and install a Bussmann RTMR Fuse/Relay Block | Tacoma World
This is probably the most comprehensive walk through I have ever seen and it was extremely helpful. Has more info than you'll ever need!
I am actually contemplating replacing this Bussman unit as I have exceeded the number of relays available. Need to get something bigger. So if you are interested I could have an entire setup ready to go...
09-19-2019, 09:53 AM
#45
Real Name: Michael
Real Name: Michael
I used this thread:
I would definitely be interested! Please let me know!
