Originally Posted by RazzRoach
Hmm I don’t understand what you mean. They sell this as a kit. This also isn’t mentioned anywhere in the instructions for the kit.
I know, but they are designed to use the factory (stock) spring with the lift notches. If running a lift spring that is taller than factory, you should use the lowest setting.
From Wheelers site about the Eibach shocks.
Allows you to adjust the level of the spring seat to lift the front of your truck or SUV up to 2.5" by moving the spring seat on the shock body. Uses your stock coils.
Call Eibach though.
