Advice needed on wheel/tire specs
Okay, so I think I’ve finally decided on the wheels I want (Fuel Cleaver), and they are available in 2 different offset options and I’m not sure which will look and fit best. For tires I’m planning to run KO2, Toyo Open Country ATII, or Falken Wildpeak A/T3W (choice will be mostly decided based on price at the time of ordering, but I’m leaning towards the KO2). I’m not planning to go crazy on the size, but figured it may be relevant to helping pick the correct offset, so the sizes I’m considering are:
265/70/17
255/75/17
Possibly 275/70/17
I’m strongly leaning toward the 255/75/17 mainly because it seems to be the best balance of slightly larger size, but not having the big mileage drop the others have. I was thinking since I’m going all new, I may as well go up a bit in size.
The specs on the wheels are 17x9”
One offset option is 1mm, which gives 5” backspace
The other is -12mm, which gives 4.5” backspace
So, which one will be the best overall fit? I don’t mind moving the fender liner a bit if needed, but I’d rather not get into removing the flaps, or cutting the body mounts if possible. I realize that the tall, skinny 255/75s are less likely to rub anyway, but I am worried they are too narrow for the 9” rims, so if anyone has run them on 9” rim width, I’d like to hear about that experience as well.
2004 black SR5 V8 4WD with TRD dual exhaust, Thorley headers, AFE dry filter, Sprint Booster, Icon 2.0 rear shocks, OME 895E springs, Fuel wheels with 265/70/17 Wildpeak AT3W tires, more to come...
