08-11-2018, 11:55 AM
Need recommendation for good HID/HIR or LED headlight system
I currently have morimoto/TRS HID lowbeams in my runner. I am on my second igniter and ballast in 8 months for the passenger side headlight. The first time i replaced it was because the low beam would intermittently not ignite and i wouldnt realize this which eventually led to me getting pulled over. I chalked this issue up to living in maine and my car spending equal time in and out of a garage every day so i figured some moisture got into the wiring from the repeated and rapid temp changes. Now my second set that was replaced in january is flickering and the bulb doesnt warm up all the way.
At this point I think that I am done with the morimoto/TRS brand as they used to be good but as of late the QC seems to be in the dumps. My brother is also using them and has been having frequent issues with igniting and flickering.
SO can anybody recommend a brand for HID, HIR, or LED headlight systems that has been problem free so far?
2006 limited v8 4wd
Toytec/ebiach 3” coilover lift with 1/2” top plate spacers, Jba high caster UCA’s, blistein 5100 rear shocks with toytec superflex hd springs, Cooper st max 255/80/17 with mb 352 in 17x9 -12 mm offset, auxbeam light bar in front bumper, custom retrofit headlights, SS brake lines, 5th gen brakes, custom rear storage box
08-11-2018, 01:14 PM
I used to have OPT7 LEDs installed in my pilot but they bumped their price up and I’ve been having some issues with the set. My friend recommended auxbeam LEDs which he has on his STI for over 2 years and so far... they have been good and zero problems.
Here is the link to the site. I got the T1series from them for my 4runner. It’s their new release LED model. Good luck man!
https://www.auxbeam.com
08-11-2018, 05:17 PM
Originally Posted by hgill
That looks good -- did you have to do any modifications for it to fit? And did you have to adjust the bulb so it's not blinding other drivers?
Also I'm curious which one of these kits you ordered -- there's so many options and all the info out there is kind of overwhelming https://www.xenondepot.com/H11-autom...lbs-s/1047.htm
2008 4Runner Limited 4x4 -- MK7 GTI Autobahn -- C6 Corvette 6-speed
08-11-2018, 05:57 PM
I did not have to do any modifications to make it fit and did not have to adjust the bulbs to prevent it from blinding other driver. I have not had anyone complain directly to me about blinding them, but I don't live in a big city or anything.
I do recommend sticking to 4300k or 5000k as the highest for the low beams. I have 6000k because the younger me loved the blue low beams look with yellow 3000k fogs (I always run both when driving at night), however, the mature me plans to change the low beams to 4300k for more useful lighting.
I have run xenondepot hid's on my 4runner and my previous ISF and have had no issues at all.
08-12-2018, 12:45 AM
I've installed a Xenox Depot HID kit on both of my 4runners and would highly recommend them.
2009 Trail Edition
2006 Sport Edition - SOLD
08-15-2018, 08:14 PM
+1 for the Xenon Depot HID kit. Purchased the 5000k HID low beam kit and only had mine for a few months but it works great. Clear install instructions and everything connected no problems.
What really sold me was the pre-purchase sales and I had a ton of questions. Robert over there was great and super responsive with emails.
08-15-2018, 09:20 PM
9 1/2 years on a XenonDepot Phillips 4300K HID set. Of all the mods I’ve done to my truck (cost irrelevant), this one remains my favorite.
I have the SR5 package (so no auto-off headlights) and leave my headlights on 24/7. I must have 8K hours on this set and I’m continuously floored every time I start my truck and they fire up. No idea what the expected life of these bulbs is but the package has exceeded my expectations several times over.
-Rex
Not Stock 2008 V8 4WD SR5
Reason: Corrected the color of my set
08-15-2018, 10:50 PM
+1 Xenon Depot LED. Love them, have them in all three of my 4runner's and other family members.
08-16-2018, 07:45 AM
im 9.5 years on the morimoto SS ballast, 5fives.
trs has good warranty so let them give you another one, also check the grounds, but i did have some problems on another car and they always took care of it.
you can also use hylux ballast, good stuff.
lightwerkz and trs also sells those.
i still remember the ballast back then was big, i still have a medium size ballast, but these new ones are compact because they have a separate igniter, so parts can be replace easily.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
08-16-2018, 09:39 AM
Real Name: Caleb
Real Name: Caleb
Thanks for all the love on our HID Kits and LED Kits
Danny
08-16-2018, 10:47 AM
Real Name: macdonaldarchitect
Count me in as another fan of the XenonDepot Phillips 4300K HID kit. It couldn't be any easier to install and the light output is incredible. Probably the best mod I've done to my 4Runner yet.
08-16-2018, 11:46 AM
I've recently installed Xenon Depot HID kit, can't comment on the longevity, but overall the components looked solid. It's obviously no match to the modern OEM xenons and LEDs, but definitely a huge upgrade over stock '06 halogens.
