08-07-2018, 09:58 PM
easiest disablement of back window? Fuses?
(And no, duct tape over the dash switch doesn't count )
In just a year of ownership, I've had multiple occurrences of going out to my truck, and finding the back window is down. It's parked outside, so this is Not Good. I've gotten better at checking when I get out, but I've never caught it in the act of happening.
An accidental touch on the dash? The only control near that window switch is for 4wd, which I do happen to use every time I park at home, backing uphill on a dirt driveway. But I don't think that's it -- more likely would be unknowingly pressing on the remote fob.
Regardless, the last straw is that, twice in recent weeks, unintentional lowering has forcibly removed an expensive rear dash-cam mounted on the window. Not damaged -- yet. Mounting it there is "only temporary", until I get around to fabbing a permanent mount on the headliner. And even without the camera issue, I don't want weather or critters or thieves getting in.
I posted a question months ago about having an open-window alert (like the open-door alerts), but never got a response. So now I'd like to just disable the damn thing -- without modding the switch mechanism. The manual says fuse "39. ECU−IG 10 A: Shift lock control system, power windows..." and a bunch of other stuff, so that's out. Next best is fuse "56. POWER 30 A: Power windows, electric moon roof", and nothing else. It's not specific to the back window, but I could live with it.
Does anyone know of an aftermarket piggy-back-style fuse controlled by a cord with an on/off switch (like the in-line switches on some household lamps)?
"Moby 4Runner", Blizzard Pearl 2008 Urban Runner 4WD 6-cyl, purchased 2017 after abandoning a years-long search for a 2009 Trail Edition.
Ch.36:"Aye! And I’ll chase him round Good Hope, and round the Horn, and round the Norway Maelstrom, and round perdition’s flames before I give him up!"
08-08-2018, 01:02 AM
Did the previous owner access the computer with Carista? With the 5th Gen's it's possible to use Carista to auto down some or all of the windows with the keyfob. It's some combo of keyfob commands.
2018 Offroad Premium w/KDSS
1993 Jeep YJ w/stuff
08-08-2018, 01:05 AM
Not directly answering your question, but this was happening to me too. Turns out the culprit was my...key fob. The button for the rear window was being pressed when I had it in my pocket. Whoops. Now I'm a little more mindful about where I set my keys and it hasn't happened since!
Sent from my SM-G950U using Tapatalk
08-08-2018, 01:11 AM
Open the back panel for the tailgate and simply unplug the motor
2011 SR5 Pelfreybilt :: Radflo :: Total Chaos :: Stubbs Sliders :: Prinsu :: RB BL :: 34x10.5 BFG T/A KO2 :: Rockford Fosgate, JL Audio
08-09-2018, 04:58 AM
How would I know, other than asking them? I'm not personally acquainted, but happen to have their name & address from some of the dealer paperwork.
08-09-2018, 05:02 AM
Originally Posted by LarsBars
...the culprit was my...key fob.
Yeah, that was eventually my best guess, as I said, inadvertently. But since I'm never aware that I'm doing it, it would be easier to hack the truck than hack my hands or nervous system.
08-09-2018, 05:37 AM
OK, thx for the tip, had no idea that was possible. Found several threads on how to remove the panel.
08-09-2018, 06:56 AM
That is an easy way to do it, however, you will lose the ability to put it down if you ever want/need to, such as if you were needing to haul long boards, or something that would need to protrude through the gate. I also leave it open on job sites occasionally to make accessing tools easier without having to open and close the entire gate dozens of times throughout the day. I have had the same thing as you and others mentioned about accidentally hitting the remote button, so my thought was to take the fob apart and disable just that button. I haven’t done it yet, but it would be fairly simple to cut a short round bushing, or something to go around the actual switch under the outer push button to make it so it doesn’t press. Honestly, I think it would solve your problem, and it should be WAY easier than taking apart the rear door anyway. Plus side is that you’ll still have full functionality if you ever need it. To me, the remote button sucks anyway since it won’t allow you to put it back up without getting in and using the dash button anyway.
2004 black SR5 V8 4WD with TRD dual exhaust, Thorley headers, AFE dry filter, Sprint Booster, Icon 2.0 rear shocks, OME 895E springs, Fuel wheels with 265/70/17 Wildpeak AT3W tires, more to come...
08-09-2018, 02:54 PM
you are accidentally hitting the key fob button while its in you pocket most likely. thats the stupidest idea they ever had to make that function work with the key fob unless it auto rolls up when you lock the truck
you need it hooked up for power to be able to open the rear hatch so the only way i know of to disable it is to pull the back panel off and unplug the window motor
You can only learn if you ask the question, so there are no such things as dumb questions.
2006 super white 4runner sport 4.7L V8
08-09-2018, 03:41 PM
pry open the fob, remove the inner rubber button /presser....boom you have disabled the remote from accidentally lowering the back window
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto...... sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
08-09-2018, 09:10 PM
Real Name: Skip
Real Name: Skip
I have had the same happen to me several times, it is the key fob in my pocket that does it.
I would agree with the quotes below and disable the window button on the fob so you retain the window function when needed!
2004 Limited V8
08-09-2018, 09:38 PM
That'll be the easiest way to do it. If you want to get fancy with it, you can add a switch to the power wire for the motor and it'll act as follows:
Switch in "off" position: Rear motor disabled and unable to go up/down
Switch in "on" position: Rear motor has power and acts as normal, including accidental key fob presses.
Essentially you'll cut the power wire to the motor and route it through the switch first, and the switch will feed back to the motor. That way if you ever want to use the rear window you can just flip the switch instead of removing the whole panel to plug the motor back in.
08-09-2018, 10:49 PM
That’s actually another really good option
08-09-2018, 11:05 PM
Hey, sometimes I have good ideas!
08-10-2018, 08:10 AM
You'll lose the ability to re-initialize the tailgate features if the tailgate window is disabled.
Mod the fob to disable the button or just get a new fob, there's a thread on here with links to an ebay seller for $40, just have to get it cut and you can program it yourself.
2004 4Runner Limited V6 4WD ***SOLD***
385,000 Km
Titanium Metallic
Vehicles: '21 Highlander XSE V6 AWD | '21 Acura RDX SH-AWD Tech | '03 Honda CBR600F4i
