Old 08-18-2018, 09:37 PM #1
WhiteBoomer04's Avatar
WhiteBoomer04 WhiteBoomer04 is offline
WhiteBoomer04 will become famous soon enough
Fuel/Air sensor (Not Oxygen sensor)
Need to change the air/fuel ratio sensor on sons 04 4.0ltr engine. I’ve read that on the 4.0 the upstream are air/fuel sensor, NOT oxygen sensors. Most threads I read elsewhere, people had to go to Toyota for an original part that was $200 for 1!
What about this as an alternative?
https://shop.advanceautoparts.com/p/...l+ratio+sensor
Mark
04 V8 SE, RST Twin stick conversion. 4x4 Labs rear bumper, SW Sliders & Bullbar, ARB Locked F&R, 5.39’s, Smittybilt 10,000lb winch, 1.5 4Crawler BL, Flowmaster, CB and 2m/70cm Ham, Sat. Radio, CO2 system, Lightforce, African Outback Rack, Budbuilt, Front Runner RTT. Rock Solid Toys Solid axles, Atlas Crawl Case, 40" Cooper STT Pro's on Fuel Anza D116 beadlocks, 5:38 gear set, ADS Coilovers.
WhiteBoomer04 is offline   Reply With QuoteReply With Quote
Old 08-18-2018, 10:46 PM #2
lightfreak lightfreak is offline
lightfreak will become famous soon enough lightfreak will become famous soon enough
Link doesn’t work.
The one you want is around $100 on rockauto. Denso part 2349047 , works for either upstream left or right on the ‘04 V6
Denso makes the OEM sensors for Toyota so it’s basically the same part as the dealer just different packaging.
2004 4Runner Limited V6 4WD ***SOLD***
385,000 Km
Titanium Metallic
Vehicles: '21 Highlander XSE V6 AWD | '21 Acura RDX SH-AWD Tech | '03 Honda CBR600F4i
lightfreak is offline   Reply With QuoteReply With Quote
Old 08-19-2018, 02:00 PM #3
Tanker Yanker's Avatar
Tanker Yanker Tanker Yanker is offline
Tanker Yanker is on a distinguished road
2005 Sport 4x4 V8 Stratosphere Mica
Tanker Yanker is offline   Reply With QuoteReply With Quote
Old 08-19-2018, 07:59 PM #4
Terminator03 Terminator03 is offline
Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough
I recently bought them for my ‘04 V8, and ordered them right from Amazon for about $50 each. I looked up the correct Denso p/n for all the sensors, then found them on Amazon. On the V8, the 2 front ones are the same number, but the rears are 2 different numbers because they have different length harnesses, not sure if it’s the same situation for the V6.
2004 black SR5 V8 4WD with TRD dual exhaust, Thorley headers, AFE dry filter, Sprint Booster, Icon 2.0 rear shocks, OME 895E springs, Fuel wheels with 265/70/17 Wildpeak AT3W tires, more to come...
Terminator03 is offline   Reply With QuoteReply With Quote
Old 08-20-2018, 04:21 PM #5
The V8 has all oxygen sensors.
The V6 has two air/fuel sensors upstream.
Oxygen sensors are different from air/fuel sensors.
Mark
Old 08-20-2018, 04:21 PM #6
Originally Posted by lightfreak View Post
Link doesn’t work.
Thank you for this
Fixed my link. Same part #
Ill compare prices now.
Much appreciated!
Mark
Old 08-20-2018, 04:36 PM #7
Supply only. Shipping extra
Rock Auto $110.79 + $11 tax
Advanced Auto Parts $139 + $13 tax
Mark
Old 08-20-2018, 06:10 PM #8
There’s a 5% discount code for rock auto on here, look for their sub forum under official vendors & sponsors.
385,000 Km
Titanium Metallic
Old 08-21-2018, 07:32 AM #9
This is the first time I’ve ever heard that. From all the reading/research I had done, I was led to believe that the front sensors are used to determine air/fuel mixture on the V8 as well, but I could be wrong. Where did you get that info from? Either way, I decided to change all 4 since I have 127k on my truck, and have a CEL that I’m hoping will go away in doing so. I haven’t changed them out yet, just ordered the front ones to start with, then after those are installed, I’ll order the rear set at another point.
Old 08-21-2018, 11:08 AM #10
oljedi11950's Avatar
oljedi11950 oljedi11950 is offline
oljedi11950 will become famous soon enough oljedi11950 will become famous soon enough
Pass. side is fairly easy BUT driver side is a real so before you start goggle this for info ! I needed 3 different wrench's, cut myself on the brackets & I'm a skinny ol man ! Found mine on Amazon decent price one side is more not sure why .
2011 SR5 Mgm 4x4 alpharex pro headlights & depo black tail lights level 8 trackers wheels & p285/70/17 cooper at3s, 6112s all around set 2.5 rear rancho spacer 11/4, FJ coils TRD intake.w/afe-dry filter Urd y-pipe flowmaster super70ii TE roofrails! 2014 Sr5 Superwhite Bils 6112s/eibach 2.5 /1 "rear springs 285s Cooper at3 ms on fj pc-d satin black, Urd y-pipe/Flow delta 50 muffler/all interior led lights & low beams sealights h7 led with laminx yellow fogs & oldreds puddle harness w/2010-13 mirrors
oljedi11950 is offline   Reply With QuoteReply With Quote
P0038 Oxygen Sensor Circuit High but not the sensor? Troymclure 4th Gen T4Rs 6 05-03-2015 11:53 PM
FS: Brand New 3rd Gen Air/Fuel Sensor & Oxygen Sensor in Texas (2001-02 V6) SURF RUNNER For Sale: T4R Items 2 01-03-2015 09:41 AM
02 3.4 Oxygen/Fuel sensor bad dwulffusa Maintenance/Detailing 3 07-06-2008 07:29 AM
02 oxygen sensor for Air/Fuel Guage JustAnotherT4R 3rd gen T4Rs 4 10-25-2007 04:31 PM
