Old 04-17-2024, 08:38 AM #16
rdruss's Avatar
rdruss rdruss is online now
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Originally Posted by maxdef View Post
I took this on and got one side done and now trying to do the driver side, but the 3rd bolt (under rear seat) is somewhat stuck- it can spin and slightly rock but it won't go up and out of the sleeve section. Lower bushing and sleeve are both out, and I've lifted the body enough to free the top bushing. I've used Fluid Film and PB Blaster to creep up the bolt shaft and I've even tried multiple times to press the floor jack into the bottom of the bolt but it still won't come out. Any advice how to remove this simple bolt?
Haven't done this job myself, but since you have done one side, is there anything that can possibly be seized to that bolt? Sounds like the sleeve that it goes through came out so what is left, a large flat washer???
2003 Limited, V8, AWD. K&N, Dobinson IMS/FJ springs,, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around, spare tire relocated to inside cargo area.
rdruss is online now   Reply With QuoteReply With Quote
Old 04-17-2024, 10:17 AM #17
maxdef maxdef is offline
maxdef will become famous soon enough
That's where I'm stumped- it's a flange head bolt that's isn't stuck at the head, and I can't see how anything could be holding on at this point. I'd be less confused if I hadn't already done the passenger side. There is maybe a 2 paper sheet thick space around the head if I wiggle the bolt, but somehow I can support a good amount of weight when I lift into the bottom.
This is the bolt with the trouble spot marked.
maxdef is offline   Reply With QuoteReply With Quote
Old 04-17-2024, 01:25 PM #18
awhitney1 awhitney1 is offline
awhitney1 has a spectacular aura about awhitney1 has a spectacular aura about awhitney1 has a spectacular aura about
You can get body mount bushings from battle born offroad for $402
Energy Suspension 03-09 Toyota 4Runner/GX470 / 07-14 FJ Cruiser Black
– Battle Born Offroad
awhitney1 is offline   Reply With QuoteReply With Quote
Old 04-17-2024, 08:55 PM #19
rdruss's Avatar
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Time for the big hammer, a couple of good whacks with a hand sledge.
Old 04-18-2024, 05:41 PM #20
I found the problem- the upper portion of the bolt fused to the sleeve in the body. That's what I'm spinning as opposed to just the bolt. Currently drilling into it and wishing I could be done.
It's been a nice upgrade so far. I got some height (final measurements TBD as I'm not finished) but the ride also feels better over uneven road such as rail crossings.
Front diff mount bushing and Rear UCA bushing PN? bugman-74 3rd gen T4Rs 12 01-07-2018 09:49 AM
OEM Body Bushing's jstim 3rd gen T4Rs 1 01-07-2016 04:28 AM
Body mount question ( not a body mount chop) crashman 4th Gen T4Rs 1 09-30-2014 01:57 AM
NV002-04 03/17/2004 Body - Body Mount Noise CBR_GUY_IA TSB 0 07-12-2009 10:34 PM
