09-11-2018, 12:32 PM
who here has bypassed the AIS system on their v8 toyota? Should I bypass mine??
I bought the AIS bypass kit from Jeff, $48 shipped, and it's ready to install but I want to make sure I really need it before performing the mod in case it's not removable.
I'm not having problems with my AIS yet and I don't know exactly how common the problem is but there's 165,000 miles on the vehicle and, reportedly, that's around the age that folks start having problems with the AIS system. (FYI and as far as I understand it, the AIS system pumps air into the exhaust manifold to be "burned" in the catalytic converter to quickly warm it up. Once its a operating temp, the valve closes. The problem is that the valves, once for each header, can get jammed open or closed when the paper filter crumbles and gets sucked into the air pump. And its only for the '05+ v8 engines. Toyota issued recalls for this engine part in the Tundra, Sequoia, etc. but not the 4Runner for some reason. Again, this is just as I understand it and not to be taken as expert testimony.)
I understand the AIS system is there to extend the life the catalytic converters as well as reduce emissions during warm up, right? I would say that after 165,000 miles it did its job and can be gracefully retired before it fails and causes $1500 in repairs.
Or would I be better off maintaining the AIS system rather than bypassing it? And would would that include? Replacing the filter and oiling/greasing the moving parts?? And it is possible to install the bypass kit after it fails, but it can become a bit trickier especially if the valve is stuck in the open position.
Thanks!
09-11-2018, 12:39 PM
When I installed my Doug Thorley headers I opted to throw in the Rutech Air Induction Pump Bypass Kit & Exhaust Port Plates. I did this for piece of mind and to have one less thing to worry about. I never experienced any issues or hiccups with the AIS but after doing a bit of research you can find thats generally what happens. No warning signs and now your dealing with it.
Personally, I think its worth it just to have one less thing to maintain. I'm sure others have a different view.
2006 V8 Limited 4WD
| Doug Thorley Headers | Gibson | Old Man Emu | ToyTec | SPC Performance | RCI Metalworks |
| Skid Mark 4x4 | SpiderTrax | BFGoodrich KO2 | aFe | Rutech | HCF Mod |
09-11-2018, 01:02 PM
Real Name: Brent
Real Name: Brent
Yes, do it. It's simple, and you don't need it. It's bound to malfunction at some point. I haven't had any problems after doing mine.
05 V8 Limited - Titanium Metallic - Build Thread
Gobi Stealth rack | King 2.5" Coilovers | Custom length 2.5" King rears | Insain Fab BMC | SPC UCAs | AIP bypass | SCS Ray 10s | BFG KO2s | RCI aluminum skids | RCI sliders | ARB Dual Compressor | ARB Diff breather | DT long tubes | Custom y-pipe | Gibson cat-back
09-11-2018, 01:32 PM
Same here...to a "T"
09-11-2018, 02:06 PM
Real Name: Matthew
Real Name: Matthew
Is this only a thing on the '06+ engines, or is it on all V8's?
Sorry to theadjack
Instagram: @projectrustyrunner
2003 V8 | Titanium Silver | 180k miles | Uniden CB | Bilstein 5100 Front @1.75" | Extended rear diff breather | American Racing 16" wheels | Full interior LED conversion | Curt roofrack w/ extension
09-11-2018, 02:22 PM
Sorry to theadjack
It’s from the ‘05+ V8 engines. That’s the year they introduced the VVT-I. Otherwise, the ‘03 and ‘04 V8’s didn’t have them.
09-11-2018, 02:28 PM
This is the kind of assurance I was looking for!
Thanks everyone
09-11-2018, 03:01 PM
I bought the kit, then sat on it for several months. but, there was really no need, its like a 5 minute job. stupid easy.
its been a few years now, I basically forgot about it until this thread.
1985 pickup : EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5 : 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited : stock. Build Thread YouTube Channel
09-11-2018, 07:20 PM
Did mine after getting the error code, did not do the blocking plates.
Of course it IS removable.
Potential cost of not dealing with this makes it a no-brainer.
was: 2005 2wd V8 Limited, one owner (me), 155K miles
now: 2019 Kia Sorento SXL V6
09-11-2018, 08:27 PM
Real Name: Sam
Real Name: Sam
I did from Ru-Tech
2005 4Runner SR5
Bilstein 5100/SPC UCA's/Toytec-Eibach 112620 Front Coils + RC2.0HD Rear Coils/33.26 Cooper Discoverer STT Pro with 17" Cragar Wheels/Custom built roof rack
09-11-2018, 08:30 PM
I have a 2006 V8 with exactly 160k and mine just gave out. Got the kit from slyfox before it threw any codes and luckily I dodged a bullet. Started with the shop vac sound, but since bypassing I've had no issues. 100% worth it, mine even has slightly less miles than yours and it bit the dust hard.
2006 V8 Sport Edition 4WD
5100 Bilsteins / OME 885 / 895
TRD Pro Wheels / BFG KO2 275/70/17
Rola Roof Rack / Custom Drawer System
09-11-2018, 10:00 PM
I have the rutech plug in kit without the block off stuff. I've bypassed all my systems since my Maxima. Nothing but trouble to keep up with. Same system causes carbon build up in my former RS4.
1999 2.7 5MT - SOLD // 2007 V8 4WD - Gone
2011 FJ 4WD - to new beginnings
// 4G V8 // 3G 2.7 5MT // Model 3 // IS300 5MT // FD RX7 //
09-11-2018, 11:09 PM
Real Name: Taylor
Real Name: Taylor
Bypass it. But if you own a 08 or 09 don’t order from Rutech. His kit doesn’t work on those MY but he doesn’t advertise it that way.
Hewitt Tech has what 08+ V8 owners need.
1999 4Runner SR5 Highlander V6 4WD ELocker
2008 Toyota 4Runner LTD V8 4WD
2000 4Runner SR5 V6 4WD- Sold
"Why do people measure life by the years, and not by how good the years were?"
09-12-2018, 12:18 AM
Not to thread jack but I also have a 06 v8 without any AIS issue. Where should i get the kit from? Doing it to prevent future problems.
09-12-2018, 12:38 AM
Secondary Air Injection Pump Failure on V8's! Important!
There is a big thread on it but the low cost option is to get a kit from
@ slyfox75
The other options include a plug and play kit on ebay for 100, plug and play from rutech or hewitt for 170 to 230 depending if you decide to do the block off plates or not. Block off plates are also available separately if you get slyfox's kit but are not necessary if your system was originally functioning well. You only need them if you decide to remove the pump or if your pump is stuck in the open position. Someone else can chime in too. I'm just thinking off top of my head since its been a few months since I thumbed through the thread.
