Old 09-14-2018, 09:00 AM #1
Seasparrow Seasparrow is offline
Seasparrow will become famous soon enough
A few questions after 6 months owned
My 4runner is awesome. I seldom get enthused at my age but I love every time I get into it. I have read about most of the quirks on here, seat moves, transmission doesn't know when to shift when turning etc etc.
But I have couple others. 2004 4WD Sport
1. Slight whine when I am at hwy speed, could be normal engine noise, does not change when I weave, changes when I let off throttle. For the most part this 153K 4runner absolutely surprises people with how quiet it is. If this forum would accept audio files it would be great, but it doesn't that I can find.
2. When the windows are rolled up and A/C is on, I feel like my ears have pressure on them, again, amazed at how tight this old of a vehicle is.
3. Is there a package deal anywhere with just replacement speakers and not complete re-install.
4. Reception is poor sometimes, what is most likely culprit.
Thanks for any help,
Donny
NATO Seasparrow Mk 57 Mod 2 & 3
2004 4th Gen Sport Edition
Seasparrow is offline   Reply With QuoteReply With Quote
Old 09-14-2018, 04:42 PM #2
Ralph Blake Ralph Blake is offline
Ralph Blake is on a distinguished road
If you have a BestBuy near you they can replace the speakers and check the radio.
Ralph Blake is offline   Reply With QuoteReply With Quote
Old 09-15-2018, 01:43 PM #3
waypoint's Avatar
waypoint waypoint is offline
waypoint has a spectacular aura about waypoint has a spectacular aura about waypoint has a spectacular aura about
waypoint's Avatar
If the whine isn't coming over the speakers, and it's a powertrain noise, I'd go after the rear diff lube and U-joints. Has the rear diff had a fluid change? If not, I'm a fan of Lucas 80W-90 for old diffs...really quiets them down.
As for the u-joints, are they getting greased during oil changes?
waypoint is offline   Reply With QuoteReply With Quote
Old 09-15-2018, 03:37 PM #4
Yes on propeller shafts
Greased in 1st 2 days of owning with lithium based nlgi #2 as per manual. Mobil1 75w 90 purchased yesterday, happens at 55mph and above, radio off, I was thinking it might be normal engine noise because I dont know what it should sound like. receipt in glove said right Wheel brg replaced already nothing about left but the noise subsides 80% when I let off the throttle, thaks for helping.
Old 09-15-2018, 06:51 PM #5
grave's Avatar
grave grave is offline
grave has a spectacular aura about grave has a spectacular aura about
grave's Avatar
might be a wheel bearing going bad.
pet every dog
grave is offline   Reply With QuoteReply With Quote
Old 09-16-2018, 12:46 AM #6
waypoint's Avatar
waypoint's Avatar
Mobil-1 gear lube is good and it has it's place, but a high mileage diff isn't it. I'd go with thicker Lucas gear lube in this case.
Old 09-16-2018, 07:50 PM #7
wcjeep's Avatar
wcjeep wcjeep is offline
wcjeep has a spectacular aura about wcjeep has a spectacular aura about wcjeep has a spectacular aura about
wcjeep's Avatar
Crutchfield can sell you speakers, adapters if necessary and instructions.
2018 Offroad Premium w/KDSS
1993 Jeep YJ w/stuff
wcjeep is offline   Reply With QuoteReply With Quote
Old 09-17-2018, 10:41 AM #8
twa318 twa318 is offline
twa318 is on a distinguished road
My thought on the whine as well.
I've seen reports of them failing on the 4th gen anywhere from 100-200k miles. I just replaced mine which were growling and it made a world of difference
'99 SR5, 2007 Sport
twa318 is offline   Reply With QuoteReply With Quote
Old 09-17-2018, 01:32 PM #9
waypoint's Avatar
waypoint's Avatar
Front or rear wheel bearings?
Old 09-17-2018, 03:58 PM #10
Front bearings 2wd, drivers side was making noise so I replaced both @ 200891 miles.
Amazing how much smoother the ride is
'99 SR5, 2007 Sport
Old 09-18-2018, 10:47 AM #11
Huge mirrors (sails) on these things do they make noise ?? roof rack maybe ??
Where is the best place to upload a quick audio file ???
Swerving back and forth produces no change in pitch,
Thanks for all the ideas and help folks.
Old 09-18-2018, 11:26 AM #12
nevada's Avatar
nevada nevada is offline
nevada has a spectacular aura about nevada has a spectacular aura about nevada has a spectacular aura about
nevada's Avatar
a whine that only changes with throttle input, and NOT while swerving sounds a lot like a differential. whether its bad enough to be of concern is hard to tell. I have seen rear ends go basically forever with a slight noise. I have also seen them fail quickly.
it might be worth taking it in to have someone a bit more experienced test drive it.
1985 pickup: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited: stock. Build Thread YouTube Channel
nevada is offline   Reply With QuoteReply With Quote
Old 09-18-2018, 05:24 PM #13
waypoint's Avatar
waypoint's Avatar
That would likely rule out the wheel bearings, in my experience.
If reducing the load (by lifting the throttle) reduces the noise, it's more likely the ring & pinion gear and/or their bearings.
If the rear diff has never been serviced, it could use fresh lube anyway. Try Lucas 80W-90 as mentioned earlier and see what effect it has on the whine under load.
Old 09-19-2018, 10:35 AM #14
Just a reminder of the original post that this only occurs at Hwy speeds, 55mph +. I will change the 3 diff fluids, post an audio file (somewhere) of the sound and go from there.
This occurs in 2WD mode.
I still have a question though, what does the inside of your cabin sound like at 55 vs say 35.
Thanks for all the suggestions.
How many have owned third gen since, well, there was a third gen? lhsoulrebel 3rd gen T4Rs 22 10-30-2017 10:05 PM
Do/have any if you also own/owned a 3rd Gen? PitbullRescuer 5th gen T4Rs 15 05-12-2014 07:01 PM
New vs. pre-owned... TripleT General Discussions 7 09-22-2013 07:38 PM
how many 4Rs you have ever owned? jsun_2k 5th gen T4Rs 29 11-04-2011 08:55 PM
After 18 Months of Research & Waiting, and 15 months on T4R.org... sp8ball 5th gen T4Rs 24 03-22-2011 03:18 PM
