09-24-2018, 11:49 AM
#16
Thanks! I realized after reading your previous post that you used Flowmaster cats. Were they a better fit than the shielded Magnaflow?
09-24-2018, 12:25 PM
#17
Can't say I've never used the shielded but the spun ones fit perfect.
2006 V8 Limited 4WD
| Doug Thorley Headers | Gibson | Old Man Emu | ToyTec | SPC Performance | RCI Metalworks |
| Skid Mark 4x4 | SpiderTrax | BFGoodrich KO2 | aFe | Rutech | HCF Mod |
10-30-2018, 04:19 PM
#18
Are the Magnaflow shielded? I just ordered the set from Burtman.
10-30-2018, 06:47 PM
#19
Real Name: Tim
Real Name: Tim
Would you guys mind stating what kind of tools would be required to do this job? Is welding involved, for example? etc etc
10-31-2018, 11:45 AM
#20
Speaking of cats, I see that Magnaflow has cats for Federal vs non Federal so make sure you order the correct ones for your state. One of them has more precious metals inside for cleaner exhaust, I think
2003 Sport V8 Icon 2" rear, Bilstein 6112 front with 700# king springs, Gibson cat back, Magnaflow cross pipe. OBA, DIY sliders, etc
1996 FZJ80 landcruiser with whole bunch of stuff, including a Turbo.
1997 4Runner SR5 - daughter's ride, slowly getting built up
10-31-2018, 08:08 PM
#21
Real Name: Blake
Real Name: Blake
School Me:
I realize it's long, so thanks ahead of time for reading and some more if you have some helpful info. Also, sorry if this is off topic to this threads original intent OP
Everyone has their bubbles of expertise (except for some on here I feel like are masters of all), and I'll let it be known exhaust is not one of mine... I'm purely interested in the DT Headers to fix my manifold leak, sound/hp/MPG boosts are all just by product pluses to me.... with that being said, I would have already pulled the trigger on a set before realizing install prices are more expensive than the headers themselves.
So, what is this like DIY with a basic home garage setup/tools? what specialty items would I need outside of the "basic" setup? As for my own experience, between my 4Runner, Old Speed3, and various friends cars I've done basic mechanic work (batteries, alternators, oil changes, brake pads, air intakes, etc..), but I've never messed around with exhaust. Anytime I don't know how to do something, I turn to the internet (that's you "strangers") to learn how to do it, and few times I bite the bullet and take it to the shop (like when I had the ENTIRE power steering system replaced in the 4Runner).
My main issue from doing more major engine work on the 4Runner myself, is just the weathered condition of the components (spent 10 years and 165k miles in NY, last bit as a hunting cabin truck) that I'm slowly but surely replacing as I'm going. BUT I'm not one to just back down bc I'm inexperienced (how else would I learn?) and figure if I truly can't get it, the shop can always finish the job I've started, I just don't want to cause additional damage.....
So I plan on (for now), to just fix the leak, getting:
-The headers from Jason
-new gasket/bolts kit
@ 0verland
mentioned (given the weathered condition of
the ones on the rig)
- and from my reading I'll need a CEL eliminator (I live in an emissions area
and need to pass)
I'll leave the OEM Cats and rest of the exhaust stock until more funds build up for the catback from Jason.... am I correct in thinking that's all I need to fix the leak?
If there's some magic install write up I haven't found yet, well that'd be the golden ticket to the chocolate factory... one besides that 60+ page thread out there.
22 SR5 Prem 4X4- Magnetic Gray
07 V8 Limited 4X4 - Natural White (SOLD)--> "Moby Dick" Build Thread
11-01-2018, 08:32 AM
#22
@ 0verland
and need to pass)
That 60 page thread is full of little tips and tricks for the DIY'er but the bulk of the install information is pretty well documented in DT's install instructions themselves.
http://www.dougthorleyheaders.com/im...S-C-INST_A.pdf
11-11-2018, 03:23 PM
#23
Here is what I learned from the DT Header install on my 2005 4runner V8. I did not do this myself, but will tell you what the shop told me about the installation. First off, purchased the DT headers, Stage 8 bolt kit, since I was paying for labor I was not going to have them weld cats on that had 176,000 miles on them. Bought two Magnaflow heavy load cats from the exhaust shop. Installation was 8hrs. Old manifolds and their rusted fasteners will be your first challenge. They removed most of the fasteners and I think broke two. Their biggest challenge they said was installing the DT headers was the drivers side/upper back two bolts behind the air injection rail on the top of the manifold. He said he actually had to use a magnet to get the bolts in and started. If you are sticking with factory cats or putting new OEM cats on you will not need a CEL eliminator. This is only if you are eliminating the cats. On the subject of cats I called Magnaflow and talked to them and had the shop order Magnaflow #99205hm heavy load cats. These are the primary cats that need to be welded on. To get this part of install right, the headers have to be temporarily installed, the cats put in place and mocked up with the rest of the exhaust, tack welded in place, headers with cats are then removed and permanently tig welded all the way around. I put a cat back exhaust with a Thunderbolt muffler on it other than the resonator that is right at the end. I also had them install Hewitt technologies bypass kit on the air injection system, so that I never have to worry about the air injection pump failing, which is costly to replace. With the bypass kit it never comes on with a cold start. Air injection is only on 2005-2009 V8's. Very happy with the results. The shop had me come back twice for a retorque. Good luck with your installation, I would recommend replacing the primary cats, do you really want to do it twice if the old ones fail?. The shop where I had work done at was
Exhaust Special T's in Muskegon MI. Cost was a little under $1500- 8 hours labor, two cats and cat back exhaust.
12-12-2018, 01:03 PM
#24
I'm in the middle of this project now and ordered all new hardware. But I didn't order any of the exh manifold studs, hoping that the nuts will come off w/o spinning the studs. So far, the few nuts that I have been able to access did come off easily.
In order for me to access the lower row of manifold nuts, I might just raise the engine one side at a time in order to bring the nuts up higher. I'll make sure that the radiator fan doesn't come into contact with the fan shroud.
Let's see how well this works!
11-18-2019, 04:56 PM
#25
I am looking to do this MOD in the near future. I am curious as to part numbers for the High Flow CAT's that people have used. Had any issues with MIL's coming up? Trying to decide whether or not to just stick with the factory CAT's...
I continue hearing about this Jason Burtman guy... Anyone have contact info??
1986 4Runner SR5 - Sold
1990 4Runner SR5 - Sold
2000 4Runner SR5 - Sold
2003 4Runner Limited - Current
11-18-2019, 05:53 PM
#26
Real Name: Michael
Real Name: Michael
His number. You can call or text.
717-319-2100
Email
[email protected]
Website
Burtman Industries
Titanium Metallic 2006 Limited 4WD V8 | Doug Thorley "Premium" Long Tubes/Modded Ypipe | Magnaflow dual in/dual out | True Dual Exhaust | Fr: 5100/885/SPC R: Icon 2"/2nd gen links | 285/75R17 G003s | Sherpa Princeton | Baja Designs | 5th Gen Brakes | Everything else is in the Build Thread
11-18-2019, 08:31 PM
#27
Hey there to the guys who installed and removed cats did you just straight pipe in place of cats? And how loud or smelly is the exhaust now ?? Lol
11-18-2019, 09:43 PM
#28
Originally Posted by That_Titanium_4RNR
Thanks for this!
11-19-2019, 01:25 AM
#29
Any of you guys 2003/2004 v8 4runners?? With a suspension lift??? I hear it’s better to buy the 2005-2008 shorty headers from DT as they come with the egr tube? Is this true? Can anyone confirm? As well any problems installing the headers around steering shaft due to a lift ???
11-19-2019, 09:27 AM
#30
If you have an 03-04, there's absolutely no reason to buy the version for the later trucks.
Interference with the steering shaft only comes into play with body lifts, not suspension lifts.
'09 V8 Limited | Dobinsons Lift | Front: 3" - C59-302 + GS59-220 | Rear: 2.5" - C59-675V + GS59-701 | Tires | Ridge Grappler 275/65/18XL | Wheels | Method Standard Machined Finish 18x9 -12 offset | SPC UCAs | DT Long Tubes | GSport 2.5" Cats | DT Y-Pipe | Magnaflow Cat Back | 2.5" Vibrant Ultra Quiet Resonator
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
