Old 02-04-2022, 03:12 PM #1
OGHalo OGHalo is offline
OGHalo is on a distinguished road
2005 Toyota Hilux Surf SSR-X Build
Hello everyone from Canada, I currently drive a 2005 Toyota Hilux Surf SSR-X 20th ANNIVERSARY EDITION, I recently picked it up after waiting 3 months for the vehicle to arrived from Japan to Canada. I'm not looking to do anything crazy build here, this will be my daily and want it to be comfortable to drive. This will be used to update my build and the process that's been done so far. If you want to know more about the 4th gen Hilux Surf I already made a post about it: Hello From Canada!.
Plans for this build:
Engine wise I plan to install a Oil Catch Can, K&N 62-1370 Vent Filter for the Secondary Air Pump, engine block heater, metal coolant bypass pipe (the plastic one is leaking coolant)
Exterior, undercoat the frame to prevent rust on Canadian roads, paint the chrome trim and a couple of faded trim pieces, 2" lift kit, trailer hitch, offroad tires, and a front push bar.
Interior, add a cruise control switch (hopefully it's plug and play, the Hilux Surf never came with cruise control switch), install a new head unit because the original one doesn't work here in North America, clean up the interior.
2005 Toyota Hilux Surf SSR-X Build-1-jpg  2005 Toyota Hilux Surf SSR-X Build-2-jpg
OGHalo is offline   Reply With QuoteReply With Quote
Old 02-04-2022, 03:24 PM #2
Here is the interior if you guys are curious about the difference between the North American 4runner and the Hilux Surf, nothing really other then being a right hand drive vehicle and no cruise control switch.
2005 Toyota Hilux Surf SSR-X Build-1-1-jpg  2005 Toyota Hilux Surf SSR-X Build-2-2-jpg  2005 Toyota Hilux Surf SSR-X Build-3-3-jpg
Old 02-04-2022, 05:40 PM #3
SurferUK's Avatar
SurferUK SurferUK is offline
SurferUK has a spectacular aura about SurferUK has a spectacular aura about SurferUK has a spectacular aura about
SurferUK's Avatar
That makes 2 right hand drive members on here now
Looks like a beauty mate. Yours is as corrosion-free underneath as mine. I have a CC kit I need to be brave enough to install at some point.
Check out the auto fluid change via the cooling lines thread if you are doing all fluids.
Have you got the ETC boxes in the centre console/armrest compartment?
2008 2.7 2WD 4 speed (Tacoma-Runner?)
SurferUK is offline   Reply With QuoteReply With Quote
Old 02-04-2022, 10:40 PM #4
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
more interior and engine bay shots
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
Old 02-05-2022, 07:44 PM #5
I actual do have a ETC box in the centre console, hopefully once I pick up my cruise control switch I can confirm weather or not it's plugin play type of deal
Old 02-05-2022, 07:45 PM #6
Whenever I have time I'll take more better pictures of the interior and engine bay
Old 02-05-2022, 07:58 PM #7
SurferUK's Avatar
SurferUK's Avatar
Mine looks like it has receivers on the windscreen, but just needs the gear stick trim panel removed to remove the wiring to the boxes. I still haven't bothered and she whispers sweet nothings to me in Japanese every startup
Old 02-07-2022, 11:38 AM #8
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
@OGHalo , wow. Your acquisition story is interesting to say the least. I wish you all the best with your Surf.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 02-07-2022, 10:50 PM #9
Thanks man, only a hand full of Hilux Surf in this forum that's for sure
Old 02-09-2022, 08:49 PM #10
Here are some better pictures of the engine bay and interior. I did install the K&N 62-1370 Vent Filter, I definitely need a cover for it, if your wondering about the engine, it's a 2.7L 2TR-FE petrol, same engine in the 05 and up Toyota Tacoma.
2005 Toyota Hilux Surf SSR-X Build-img_5982-jpg  2005 Toyota Hilux Surf SSR-X Build-img_5983-jpg  2005 Toyota Hilux Surf SSR-X Build-img_5984-jpg  2005 Toyota Hilux Surf SSR-X Build-img_5985-jpg  2005 Toyota Hilux Surf SSR-X Build-img_5986-jpg  2005 Toyota Hilux Surf SSR-X Build-img_5987-jpg  2005 Toyota Hilux Surf SSR-X Build-img_5988-jpg  2005 Toyota Hilux Surf SSR-X Build-img_5989-jpg
Old 02-12-2022, 07:37 PM #11
Update: (2/12/2022)
So today I removed my throttle body to clean it, when I pick the vehicle up for the first time it was idling below 500 rpm and stalled on me twice. When I removed it there was a lot of carbon in the pictures and gasket. After cleaning it to the best of my ability and installed it back in, I noticed a huge difference, once warmed up it stays idle around 800-900 rpm. Here's a video of the vehicle starting up
https://www.youtube.com/watch?v=dBo4...hannel=OG_Halo
2005 Toyota Hilux Surf SSR-X Build-img_6005-jpg  2005 Toyota Hilux Surf SSR-X Build-img_6007-jpg  2005 Toyota Hilux Surf SSR-X Build-img_6010-jpg  2005 Toyota Hilux Surf SSR-X Build-img_6011-jpg  2005 Toyota Hilux Surf SSR-X Build-img_6012-jpg  2005 Toyota Hilux Surf SSR-X Build-img_6013-jpg  2005 Toyota Hilux Surf SSR-X Build-img_6014-jpg
Old 02-17-2022, 03:13 AM #12
as4runner as4runner is offline
as4runner is on a distinguished road
Hey im from edmonton as well. which company did you use to import your 4runner?
as4runner is offline   Reply With QuoteReply With Quote
Old 02-18-2022, 11:15 AM #13
iowabadger iowabadger is offline
iowabadger is on a distinguished road
Nice!
Saw a Mark II yesterday at Culver's in Iowa.
iowabadger is offline   Reply With QuoteReply With Quote
Old 02-18-2022, 03:14 PM #14
SurferUK's Avatar
SurferUK's Avatar
Does your import have VSC/TRAC? Mine doesn't (Well I have no lights or buttons), quite pleased about it really, less to go wrong.
Old 03-01-2022, 10:09 PM #15
I don't believe so, I haven't seen lights or buttons
build , hilux , interior , surf , switch
TorqueOfTheDevil’s Build Thread ..::1UZ-FE VVTi Hilux Surf::.. TorqueOfTheDevil 3rd gen T4Rs 149 05-25-2020 10:30 PM
HiluxSurfGuys 99 (Slow) Hilux Surf Build HiluxSurfGuy 3rd gen T4Rs 119 10-27-2018 11:43 PM
Hilux Surf Grill - Made in Japan 2003-2005 models mahabali For Sale: T4R Items 1 04-07-2012 02:15 AM
Hilux Surf Grill - Made in Japan 2003-2005 models platinumx769 Classifieds - buy & sell (no commercial ads please) 5 12-03-2010 12:25 AM
Hilux Surf *High Spirit* Billet Grill 2003-2005 platinumx769 Classifieds - buy & sell (no commercial ads please) 3 09-13-2010 06:48 PM
