Old 09-15-2021, 10:36 AM #61
DoctorPopcorn's Avatar
DoctorPopcorn DoctorPopcorn is offline
Real Name: Tyler
DoctorPopcorn is on a distinguished road
Real Name: Tyler
Originally Posted by Dabsalot View Post
I ended up going with the 05+ Long Tube headers. Probably the best option for my case.
On a related note, I went with the URD O2 simulator and with a little adjusting I was able to eliminate the ‘catalytic converter efficacy’ code. But only since installing the DT headers I sometimes get a P0172 & P0175 code ‘System too rich bank 1 & 2’
Hey, thanks for the quick response, Dabsalot, and 05+ LTs make the most sense. That's also super helpful to note you went with the URD O2 sim and the intermittent rich codes. Hope the LTs are treating you well & you're enjoying them.
The O2 sim seems like the best route, rather than monkeying with rear O2 spacers, but I've seen and heard URD's stock is off & on. I think they used to have a plug & play specifically for the 4th gens, then had a universal sim, and now I can only find the O2 sim as a purchase option with their headers.
'98 Limited 4X4 320K (summer truck): OME/5100 lift, LT235/85/16 AT3W WPs, supporting mods, many trails, on 3rd rear diff. Rust.
'05 V8 Sport 4WD 250K (DD, was hoping for pavement princess, turned out to be a work horse): IronMan 4X4 Nitro Gas Stage 2: 2.5" 0-110 lb front, 3" 440-880 lb rear. Sway bar(s). LT255/80/17 Falken AT3Ws. URD Y pipe, Slyfox75 AIP Bypass. Also rust.
DoctorPopcorn is offline   Reply With QuoteReply With Quote
Old 09-15-2021, 11:32 AM #62
JONBOY345 JONBOY345 is offline
JONBOY345 has a spectacular aura about JONBOY345 has a spectacular aura about JONBOY345 has a spectacular aura about
Originally Posted by DoctorPopcorn View Post
Please know that I haven't replaced my headers with DT, but with all of the info that I've poured over from a ton of super helpful folks on T4R, I can offer this:
DT longtube headers (deleting upstream cats, connect straight to the Y pipe): you will either need an O2 simulator (URD sometime has one on their website), or space out your downstream 02 sensors with something like this. With LT headers and deleting the upstream cats, can't recall anyone getting around either of these 2 options.
Great info, just wanted to toss out another option in addition to the ones you listed.
I've recently moved to LT headers from ST headers due to less than stellar work by my mechanic's fabricator. In doing so, I wanted to retain catalytic converters because tread lightly. If I'm rolling through a national forest and stinking up the place, I'm not being a very good steward of our resources or a very good neighbor to those I'm passing or near...
Anyways, here's what I did.
I moved the GSport cats from their original location in front of the y-pipe, to the DT Y-pipe. Specifically, I removed the resonators in the y-pipe and replaced them with the cats. I plugged the O2 sensor bung just behind the flange of the DT y-pipe and had my fabricator weld in new O2 bungs behind the cats that are now installed in the y-pipe for the downstream O2 sensors.
It does take a little bit longer for the cats to warm up and start working, but I've not gotten any codes since completing the work. Few pictures showing what I did in case the above is clear as mud. lol.
Showing the DT y-pipe with O2 bung plugged and comparing the size of the resonator to GSport Cat.
Driver side with GSport cat replacing resonator and new O2 bung for downstream OS sensor.
Passenger side finished as above.
One of the most interesting things I noticed, is that now at about 70 MPH, I'm running 100-150 fewer RPM than before when I had the short tube headers.
'09 V8 Limited | Dobinsons Lift | Front: 3" - C59-302 + GS59-220 | Rear: 2.5" - C59-675V + GS59-701 | Tires | Ridge Grappler 275/65/18XL | Wheels | Method Standard Machined Finish 18x9 -12 offset | SPC UCAs | DT Long Tubes | GSport 2.5" Cats | DT Y-Pipe | Magnaflow Cat Back | 2.5" Vibrant Ultra Quiet Resonator
JONBOY345 is offline   Reply With QuoteReply With Quote
Old 09-15-2021, 11:59 AM #63
Real Name: Tyler
Real Name: Tyler
Jonboy, that's a sweet setup, and another slick way to go! Agreed on removing cats vs being a good steward, but that's a whole other discussion. Also pretty sweet that you're not throwing any codes, even during warmup. I've got the URD Y-pipe and would consider this same setup if I were doing DT LTs, BUT, I had my driver stock DS cat cutout last September by cat thieves. We've got a 1-stall garage that houses the 3rd gen, and the 4th gen and fiancé's Crosstrek sit out in the elements on the parking pad on the alley. So, I settled on the URD Y-pipe with no resonators, because I thought cat thieves might come back and cut the DT Y-pipe, thinking the resonators are cats, like the stock pipe.
This is a great option for folks with LTs that don't mind a set of cats in their Y-pipe, no other monkeying with fooling the DS 02s, and don't have to worry about their cats getting cut out.
Old 09-16-2021, 10:13 AM #64
From what I can tell, it may take just a few more minutes for them to warm up. It's nothing significant in the grand scheme of things. From start to them being at operating temp isn't more than 5 minutes.
Old 06-24-2023, 11:29 AM #65
4RunnerAquasport's Avatar
4RunnerAquasport 4RunnerAquasport is offline
Real Name: Brett
4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of
Real Name: Brett
Bump, hopefully good fortune for the 2UZ owners.
Doug Thorley headers...successful install stories.-screenshot-2023-06-24-11-32-05-facebook-png
1988 DLX 22RE AUTO BLACK-"Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
4RunnerAquasport is offline   Reply With QuoteReply With Quote
Old 06-24-2023, 04:56 PM #66
Az4runnin's Avatar
Az4runnin Az4runnin is offline
Az4runnin will become famous soon enough Az4runnin will become famous soon enough
Az4runnin's Avatar
Thumbs up
I wonder what part of Arizona
2003 V8 Limited 4x4 Black. JBA UCA's, TRD Pro Wheels. OEM LED Tails, 2012 FJ Springs F/R 5100's F/R 1.75 Cooper AT3 4S 265-70-17. Bye X Reas, Wet Okole Seat Covers Weathertech liners.
Az4runnin is offline   Reply With QuoteReply With Quote
Old 07-05-2023, 12:54 AM #67
Gamblin4Runner's Avatar
Gamblin4Runner Gamblin4Runner is offline
Gamblin4Runner is on a distinguished road
No cats
Question 1...did you change out the cats?
Eliminated all four entirely
Question 2...did you use an O2 simulator or spacer?
Sure didn't. Got a YotaWerx tune that took care of all of it (I don't have emissions testing to worry about)
Question 3...did you put a cat back exhaust system on?
Gibson Elite Exhaust:
Gibson Performance Exhaust 618815B Gibson Elite Series Cat-Back Exhaust Systems | Summit Racing
Here is what she sounds like:
4.7L V8 4Runner | 2UZ-FE | Doug Thorley Headers & Gibson Elite Exhaust - YouTube
'06 4Runner Sport Edition V8 4x4 | Thorley LT Headers & Y-Pipe | Gibson Elite Exhaust | YotaWerx ACTIVE DUTY Tune | 33" Kenda Klever R/T KR601's | 17" TRD Gloss Gunmetal Gray Wheels | OME Lift Kit w/ Diff Drop | Smittybuilt XRC 9500# w/ BudBuilt hidden mount | Cali Raised LED Ditch Lights | Victory Skid Plates | Sony XAV-AX6000 w/ factory JBL's | Hydrocarbon Filter Delete | Complete LED Conversion - Interior & Exterior
Gamblin4Runner is offline   Reply With QuoteReply With Quote
Old 02-06-2024, 03:38 PM #68
cyclingtrav's Avatar
cyclingtrav cyclingtrav is offline
cyclingtrav is on a distinguished road
Finished Install of Shortie Headers, Successful California Smog
Hey y'all- just finished a detailed write up of my shortie header install and California smog experience. Check it out here:
Doug Thorley Shortie Headers 4.7L V8 - My Experience w/ Install & CA Smog
TL;DR- my mechanic is a gangster (shout out to Mark @ Auto Tech in San Ramon) and successfully installed my DT headers. I went on to get SMOG cert and registration completed. Be sure to replace things like the air tube gaskets, O2 sensors, and motor mounts.
cyclingtrav is offline   Reply With QuoteReply With Quote
Old 03-17-2024, 05:58 PM #69
parsky1 parsky1 is offline
parsky1 is on a distinguished road
Would this job be any easier with the Struts out? I gotta do the suspension anyway. Also, can anyone confirm if the magnaflow high flow cats cause a CEL with the shorties?
parsky1 is offline   Reply With QuoteReply With Quote
Old 03-20-2024, 09:01 AM #70
Zero0575's Avatar
Zero0575 Zero0575 is offline
Real Name: Casey
Zero0575 will become famous soon enough Zero0575 will become famous soon enough
Zero0575's Avatar
Real Name: Casey
Yes, you will get a CEL. Easy to fix by adding O2 spacers to the downstream sensors. I had to stack 2 spacers to get rid of CEL.
2007 Limited V8 | 275/70/18 Falken Wildpeak AT3W | Spidertrax | 4xInnovations Weld On Sliders | Victory 4x4 Blitz Front Bumper | RCI Skids | TNF Rear Bumper | Smittybuilt Winch | KOYORAD Aluminum Radiator |OME 886 Front/Toytec Superflex HD Rear and OME Shocks/Struts | JBA High Caster UCA | Rebuilt LCA with Superpro bushings + Moog BJ | HCF Delete | Doug Thorley Shorty Headers | Magnaflow HFC | Gibson Catback | Rear Diff Breather Extension | 20" Spot/Flood | 9" Spots | DD SS3 Yellow Fogs | Amber Grill Lights | Fog Lights Anytime Mod
Zero0575 is offline   Reply With QuoteReply With Quote
COLORADO Doug thorley headers install shops 4Running335i 4th Gen T4Rs 32 08-18-2021 07:47 PM
Shops that will Install Doug Thorley Headers Bob J 4th Gen T4Rs 0 06-08-2016 07:25 AM
Doug thorley headers. Slowerthanyou Classic T4Rs 4 04-21-2015 10:33 PM
Doug Thorley Headers rossk35 5th gen T4Rs 0 03-19-2014 03:03 AM
Doug Thorley Headers kraftwerkauto 4th Gen T4Rs 3 10-12-2012 11:25 AM
