Old 09-20-2018, 08:27 AM #1
Runabout36 Runabout36 is offline
Runabout36 is on a distinguished road
Doug Thorley headers...successful install stories.
2005 Toyota 4runner Sport 4.7l V8. Just got my DT headers. Want to hear successful install stories and what you used. Question 1...did you change out the cats? If so what did you use? Question 2...did you use an O2 simulator or spacer. Want to avoid CEL . Question 3...did you put a cat back exhaust system on?
Runabout36 is offline   Reply With QuoteReply With Quote
Old 09-20-2018, 08:54 AM #2
Habitant Habitant is offline
Habitant is on a distinguished road
I just did mine a few weeks ago. Decided to stick with stock cats even though I bought 4 aftermarket ones. I have the full set up too, Volant intake, DT headers and mag aglow exhaust. Sounds great and the overall driving feel is good. The car feels lighter which I equate to more power.
Habitant is offline   Reply With QuoteReply With Quote
Old 09-20-2018, 09:24 AM #3
How old were your stock cats (miles)? I have 175,000 miles and it seems foolish to not change them at the same time as installing the DT headers. Was thinking of using Magnaflow high flow cats. Did you use an O2 simulator or spacer. I was told by DT/Mike Johnson if using stock cats no simulator or spacer is needed.
Old 09-20-2018, 09:42 AM #4
blackoutt's Avatar
blackoutt blackoutt is offline
blackoutt has a spectacular aura about blackoutt has a spectacular aura about
blackoutt's Avatar
1. Used someones old headers to build a wooden jig to weld on 2.5" pipes and flanges instead of cats, non inspection state. If I were to do it again I would reduce to 2.25" and flanges to better mate to the stock or even aftermarket y pipes.
2. O2 sensor spacers with no cats was a must, at least two on each side.
3. "stock" exhaust piping from the headers back. Muffler and side exit but otherwise it's all factory piping still.
There was a noticeable increase in power but I've since added weight and tire size and wind resistance so I've effectively offset it.
blackoutt is offline   Reply With QuoteReply With Quote
Old 09-20-2018, 09:58 AM #5
About 140k miles on the stock ones. I was adviced to run them until they malfunction and then install the new ones. I bought the O2 sensor bypass thing too. If you want the 4 cats and the bypass I could sell them to you!
Old 09-20-2018, 10:36 AM #6
0verland's Avatar
0verland 0verland is offline
0verland will become famous soon enough 0verland will become famous soon enough
0verland's Avatar
yes, Flowmaster HFCs. I don't see why anyone wouldn't over 100k, but thats just me.
O2 spacer. Blox Racing BXFL-00108
Yes, Gibson Side Exit aluminized version coated in matte black high temp paint. I don't deal with really any corrosion here in the desert but I put on the coating to keep the rust off if any, your mileage may vary.
I went above and beyond on for my install by ordering new studs and gaskets. I went with the Stage 8 8919 4.7L V8 Toyota 10MM Header Kit and OEM Toyota manifold gaskets.
2006 V8 Limited 4WD
| Doug Thorley Headers | Gibson | Old Man Emu | ToyTec | SPC Performance | RCI Metalworks |
| Skid Mark 4x4 | SpiderTrax | BFGoodrich KO2 | aFe | Rutech | HCF Mod |
0verland is offline   Reply With QuoteReply With Quote
Old 09-20-2018, 02:26 PM #7
Keros Keros is offline
Keros has a spectacular aura about Keros has a spectacular aura about
I used magnaflow high flow cats and a sensor spacer when the shop did the headers.
They built a custom system up to the muffler, I think it's 2.25"
Sounds amazing. Butt dyno says it makes more power... I haven't had time to take it to a real dyno yet.
Keros is offline   Reply With QuoteReply With Quote
Old 09-22-2018, 12:13 AM #8
dsieber dsieber is offline
dsieber is on a distinguished road
Did mine about a year and a half ago. Kept the stock cats (had to - emissions), and stock exhaust.
'99 4Runner SR5, 370k
'07 Limited v8, 100k
dsieber is offline   Reply With QuoteReply With Quote
Old 09-22-2018, 11:58 AM #9
toyotaguyMT toyotaguyMT is offline
toyotaguyMT is on a distinguished road
did mine over the summer, removed the cats (was planning on the diy o2 simulator but that didn't work), running with CEL but still in closed loop so i don't care. Definitely more responsive and got 2mpg or so back after the lift and bumper took it down to 16mpg. still running stock exhaust otherwise, i like it being quiet when I'm on back roads for a few days camping.
toyotaguyMT is offline   Reply With QuoteReply With Quote
Old 09-23-2018, 03:45 AM #10
Ed_C's Avatar
Ed_C Ed_C is offline
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
Originally Posted by 0verland View Post
Flowmaster HFCs
O2 spacer. Blox Racing BXFL-00108.
Since you do have converters, why did you still install O2 spacers? Preventative measure or were you getting a CEL without them?
Old 09-23-2018, 12:31 PM #11
0verland's Avatar
0verland's Avatar
The DT headers still throw a CEL for bank 2. The CEL Eliminator is necessary regardless from my understanding. I didn't believe it myself initially until I ran it without for a few weeks and with no success of getting rid of the CEL I threw them on per J Burtman's recommendation (granted it stated this in the first place) ...haven't seen a code since.
I personally wanted the cats on there regardless to tone down the exhaust to a level I would be comfortable with for hours of driving on the highway.
2006 V8 Limited 4WD
Old 09-23-2018, 03:11 PM #12
Morphyne Morphyne is offline
Morphyne will become famous soon enough
Exhaust newb here: So a complete system upgrade would look like:
1. DT headers
2. Magnoflow high flow cars
3. Gibson side exit muffler and exhaust
4. New 02 sensors?
5. What else?
Morphyne is offline   Reply With QuoteReply With Quote
Old 09-23-2018, 04:01 PM #13
0verland's Avatar
0verland's Avatar
1. DT headers
2. Magnaflow high flow cats
4. O2 spacer. Blox Racing BXFL-00108
5. Stage 8 8919 4.7L V8 Toyota 10MM Header Kit (NOT REQUIRED)
6. OEM Toyota manifold gaskets. (NOT REQUIRED)
Due to my personal preference I also got OEM gaskets and new manifold studs
2006 V8 Limited 4WD
Old 09-24-2018, 10:40 AM #14
Overland...many thanks for the info. Could you tell me what the product number is on the Magnaflow Cats? There seems to be two recommended on Magnaflow website....#51205 and #99205HM which is just a couple bucks more.
Old 09-24-2018, 11:03 AM #15
0verland's Avatar
0verland's Avatar
I didn't use Magnaflow HFCs in my setup, I went with FlowMaster.
Clicky
Honestly though you can go with any 3" Inlet/outlet cat thats roughly 10.5" or around there. If you have a good exhaust guy they shouldn't have a problem mating it up. I prefer the spun cats though since they don't have all that shielding to get in the way.
2006 V8 Limited 4WD
COLORADO Doug thorley headers install shops 4Running335i 4th Gen T4Rs 32 08-18-2021 07:47 PM
Shops that will Install Doug Thorley Headers Bob J 4th Gen T4Rs 0 06-08-2016 07:25 AM
Doug thorley headers. Slowerthanyou Classic T4Rs 4 04-21-2015 10:33 PM
Doug Thorley Headers rossk35 5th gen T4Rs 0 03-19-2014 03:03 AM
Doug Thorley Headers kraftwerkauto 4th Gen T4Rs 3 10-12-2012 11:25 AM
