Old 09-26-2018, 12:49 PM #1
rwh963 rwh963 is offline
rwh963 has a spectacular aura about rwh963 has a spectacular aura about
Need to "exercise" the 4wd system?
I have a 2007 V6 4wd 4runner, and live in the northeast. i do not take it off road. the 4wd gets some as-needed use in the winter months. I've come across some comments about activating it and working through the various options (4h, 4l, locking diff) monthly. I never heard about this before. Is it just an opinion, or is there some data to support it?
rwh963 is offline   Reply With QuoteReply With Quote
Old 09-26-2018, 12:57 PM #2
4RunnerIdiot 4RunnerIdiot is offline
4RunnerIdiot is on a distinguished road
4x4 PSA: Use it or lose it monthly reminder
2004 Limited V8
4RunnerIdiot is offline   Reply With QuoteReply With Quote
Old 09-26-2018, 12:58 PM #3
Johns06yota's Avatar
Johns06yota Johns06yota is offline
Real Name: John Iannacone
Johns06yota has a spectacular aura about Johns06yota has a spectacular aura about
When I first got mine I didn’t engage any of it for roughly 6-8 months and within that time the 4wd had gotten frozen with just blinking lights. Now that I do this monthly my 4hi, 4lo and center diff engage immediately instead of taking 10 seconds
Johns06yota is offline   Reply With QuoteReply With Quote
Old 09-26-2018, 01:59 PM #4
cooper30 cooper30 is offline
Real Name: Ted
cooper30 is on a distinguished road
Real Name: Ted
I just bought an '08 Limited V8 from a dealer, and they are replacing the actuator (at their cost) because the center diff lock was never used by the previous owner.
Make a point to use it at least once a month (or more...it doesn't cost anything to engage it from time to time) to keep it working correctly. It's very pricey to replace on your own dime...even if you do the work yourself.
cooper30 is offline   Reply With QuoteReply With Quote
Old 09-26-2018, 03:02 PM #5
in 10 years i don't think the locking diff or 4L has needed to be engaged. i'm not even certain about the proper procedure for activating them (i know it is somewhat explained in the manual). i would want to do it safely, and know how to feel it engaged and disengaged.
Old 09-26-2018, 03:02 PM #6
S p a r k y's Avatar
S p a r k y S p a r k y is offline
Real Name: Mark
S p a r k y will become famous soon enough
Real Name: Mark
Reminder in my phone once a month!
'04 Sport V8
OME 885's, 1/4" spacers - 5100's at 0 - Toytec Superflexes with 1" rear spacers - 285/70/17 - SCS Gunmetal SR8's - LR UCA's - 20% front - 6000k low's and fogs - LED'd everything- Blacked out head lights - JL Sub and Amp
06 White Tundra - OME 888's and OME Shocks - JBA UCA's - AAL's - Summit Dakar's Black - NRG 285/75/17 - 20% front - LED everything.
S p a r k y is offline   Reply With QuoteReply With Quote
Old 09-26-2018, 04:36 PM #7
eleven14 eleven14 is offline
eleven14 has a spectacular aura about eleven14 has a spectacular aura about
It's for real
Toyota itself recommends 10-15 miles of usage per month to keep the system in peak condition. Plenty of frozen actuators back up this point - my 2008 wouldn't go into 4LO when I bought it but the dealer stepped up.
eleven14 is offline   Reply With QuoteReply With Quote
Old 09-26-2018, 07:22 PM #8
anyone have a very simple explanation about engaging 4L and locking diff.?
Old 09-26-2018, 07:53 PM #9
Real Name: Ted
Real Name: Ted
To go into 4L (and to go back to 4H) you must be in neutral and stopped when you shift (by shifting, I mean turning the knob)
You can lock the center differential by pushing the button while driving. I tend to let off the gas when I do it.
On mine, which is full time, the 4LO light is steady when 4L is engaged. Same with the Center Differential Disconnect...the light is steady, not blinking.
Blinking lights means you are not in 4L or the center diff isn't locked.
You can have one work but not the other. In mine, I had no issues going into 4L, but the center diff lock would not engage.
Old 09-26-2018, 10:15 PM #10
IRONLUNG IRONLUNG is offline
IRONLUNG is on a distinguished road
edited:You can drive on pavement in 4LO....
IRONLUNG is offline   Reply With QuoteReply With Quote
Old 09-26-2018, 10:41 PM #11
had to run out to do an errand. decided to test the system. 4H seemed normal, did a little in 4L, also seemed normal. in both cases tried to activate the CDL, but nothing seemed to occur. need to research this.
Old 09-26-2018, 10:58 PM #12
Berty_K's Avatar
Berty_K Berty_K is offline
Berty_K has a spectacular aura about Berty_K has a spectacular aura about Berty_K has a spectacular aura about
Berty_K's Avatar
Originally Posted by IRONLUNG View Post
You also don't want to be driving on pavement in 4LO; switching into 4LO while not moving is ok I think......
This is incorrect. You can be in 4LO or 4HI on hard pavement.
However, you cannot lock the center differential on hard pavement. This is how you get driveline bind and end up breaking something.
'08 Silver SR5 V6 4x4: OEM+
Berty_K is offline   Reply With QuoteReply With Quote
Old 09-26-2018, 11:18 PM #13
Dang! I have a lot of "exercising" to do....although the last time I put it 4LO, I heard some crunching...normal?
Old 09-26-2018, 11:36 PM #14
Doozi's Avatar
Doozi Doozi is offline
Doozi will become famous soon enough
Doozi's Avatar
You can lock the center diff on pavement, but you shouldn’t turn which is what would require the front and rear drive shafts to rotate at different speeds... driving straight is fine... not always practical, but I do it from time to time if I haven’t been in the dirt for a while just to exercise the center diff lock actuator. I just use a 50-yard straight section of my street while I’m going 10-20 mph. It took my 4Runner a while to switch in and out of 4HI and 4LO when I first got it (originally leased by a saleswoman in northern CA), but it consistently takes just a few seconds now. I really like the features of these Torsen center diffs!
Doozi's 2006 Sport Edition V6 4WD - Titanium Metallic - purchased 09-13-10
Dobinson's F: C59-302/GS59-220, R: C59-677V/GS59-575 / LR UCA's / Medic links / LT285/70R17 DuraTracs on Countersteer Type-X wheels / WeatherTech DigitalFits and Window Visors / Rear Diff Breather Mod / J.A.'s Fog Light Mod / Centric Premium rotors w/ Akebono Pro-Act Ultra Premium pads / LED interior lights / HIDs (4500k lows) / Man-A-Fre engine+tranny skids / RCI MetalWorks T-case skid / B.A.M.F LCA skids / CBI front/rear, Sherpa Equipment Company roof rack, WKOR sliders welded on, Panhard Correction Kit... Lovin' it!
Doozi is offline   Reply With QuoteReply With Quote
Old 09-27-2018, 12:35 AM #15
Big update: doing searches on reasons for center diff. not to be engaging, and getting worried about lack of use and $2500 actuator replacements, i recalled someone mentioning to check to make sure the locking button was plugged in.
at midnight, i went out to move the 4runner around to try and engage the differential. nothing happened. so i took the fuse cover off and saw an unplugged line. i reached up an popped the differential plug out. no connection!
plugged it in (perfect fit) and went out for a short drive. into 4H and press the button, and it goes on. ran it through some paces, and no issues that i can tell.
didn't really notice anything different driving, but the lights all worked fine.
this is with a 2007 V6 w/200k in MA. as far as i know, neither the 4L or diff. lock had ever been engaged (known it since new).
i can sleep much more soundly tonite. i'll check the actuator breather tube later.
FS - Thule Podium "Foot" Roof Rack System - Louisville, KY manderson1 For Sale: T4R Items 0 05-20-2015 04:28 PM
1992 4Runner "Premium Sound System" issue ServerRage Classic T4Rs 3 07-25-2012 02:11 AM
1992 4Runner "Premium Sound System" issue ServerRage Engines / Suspension / Wheels / Tires / Audio / Accessories 0 07-25-2012 01:10 AM
Zero point didnt work how to turn off "VSC TRAC" & "VSC OFF" & "ABS" lights sciff5 4th Gen T4Rs 6 09-27-2010 12:10 AM
03 Swapping 17 " for 16" wheels - Tire pressure system question Big Duke 6 Engines / Suspension / Wheels / Tires / Audio / Accessories 3 11-10-2008 08:44 PM
