10-04-2018, 04:38 PM
How much front bump stop clearance should there be? 08 v6
On level ground, with wheels straight, how much clearance should there be under the front bump stops, assuming the springs aren't old and tired? Stock v6, OEM suspension.
10-04-2018, 05:25 PM
youll see a big difference after you do new shocks, but with stock its like it lights to ride on the bump stops, atleast when i had x reas.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
10-08-2018, 09:52 AM
Does anyone know what the clearance spec is?
10-08-2018, 01:55 PM
You're prob going to get a variety of answers, as most of us replaced suspension and gained lift above stock. I have the bilstein coilovers around 1" over stock and prob have a few inches of clearance between the LCA and my 4Wheeler's bumps. Before I put in the billies, I was riding on the bumps.
What problem are you trying to solve / question are you really trying to answer, eg, do you need to replace your suspension?
2008 Nautical Blue GX470
Bilstein 6112/5160
10-08-2018, 02:54 PM
Good question, ZiaMan!
I have a tired suspension with 108k miles on it. This year, it has been doing more work than ever with the additional weight of RCI under-armor, sliders, a rear drawer system, as well as more time to drive rough mountain trails than in past years.
While there is nothing broken or leaking, I sensed that I hit the front bump stops easier than I remember doing so in the past. At this point, I can't get my entire index finger under the stops, and I don't have fat fingers - just regular average size.
Now that summer driving season is over, I'm about to refresh the suspension with new OEM upper control arms, OEM springs, and Bilstein shocks ( no lift desired ).
I was asking about bump stop clearance to see what's normal. I don't want to overdo it or "underdo" it. I'm planning on installing springs either from the v8 version of the 4th gen because I have all that additional weight on my v6, or perhaps brand new 5th gen TRD off-road OEM springs which I can get for free. The 5th gen is a heavier truck than my '08 v6, so I suspect they may be appropriate given all that weight that I added to my truck.
10-08-2018, 03:56 PM
There are ways to get stiffer springs than stock that don't give you lift. Adjustable coilovers can be adjusted to give you ~0" of lift in the front and would have heavy enough coils to improve your ride. OEM springs with that much weight makes me cringe.
10-08-2018, 09:37 PM
My '08 v6 has a curb weight that is 420 pounds less than that of the 2018 TRD Off-Road edition.
I've added about 280 lbs and will probably add another 100 as I finish armoring the underside all the way back.
Using the four springs from that '18 TRD seems to make sense on paper. Am I missing something that makes this a cringe-worthy idea?
10-09-2018, 08:21 AM
Real Name: Newell
Real Name: Newell
Cringe-worthy if you stay OEM across the board. If you can afford OEM why not upgrade? You can get stiffer springs in the same height? or adjustable coilovers just to have the option. I have an 08' V6 and can say that they are close (without measuring - I have 150k on stock setup). skids, sliders and a loaded drawer system is easily adding a couple hundred lbs on top of your aged setup. Surprising you feel it more up front than in the rear but if you have the option, go with the TRD springs. I think you'll need to do a few modifications to make them work.
10-09-2018, 12:18 PM
Real Name: Gary
Real Name: Gary
Consider Tacoma or maybe FJ Springs? On my 07 V8, taco Springs alone added an inch of lift and rode great. Probably similar to 5th gen Springs, but I can’t personally vouch for the 5th gens...
I like my droop droopy
Front: Swayaway 2.5s + TC UCAs--Rear: Swayaway 2.5s + Icon 3.0 springs + Light Racing Jounce Shocks — 285/70R17 BFG KO2s
My build: http://www.toyota-4runner.org/4th-ge...ld-thread.html
