Not worth getting really involved in this, but I would like to see if there is any case study on the synthetic oil head gasket leak.
Originally Posted by Captsolo
Going back to conventional and the oil drips are down to 1 drip a week, and the garage is clean. The synthetic didn’t work in my 2005 4runner.
That's perfectly fine that you don't like using synthetic oil. I think most center for debate here is about your claims that synthetic oil will certainly cause engine oil leaks and damage, still without really any metrics. All of your links are essentially providing empirical data, as triethylborane mentioned. All I've heard from you is how "slippery" the synthetic oil is vs conventional, and this qualitative evaluation isn't really a comparable metric.
What do you own triethylborane?
Do your own research.
Something tells me the dude named after rocket fuel has probably done a tad bit of research. Most people are asking you about where your research is coming from, since claims like the head gasket leaks due to synthetic oil are a bit extravagant. I'd like to see at least one example of this before I can start to consider it as a potential failure mode.
Are you even a mechanic?
from your article: "When using the term older to refer to cars, it means those
manufactured before 1990 or so"
