Originally Posted by BackOff
My 2004 V6 has had Royal Purple in it since 2010...ZERO drips.
The one time i took scotties advice on SteelSeal...head gasket repair.
Needed new water pump and radiator after it killed the water pump and plugged up the radiator and started to run 190*+.
I have no following or friends and dont make money off the internet.
Just some guy that likes 4runners.
Good to know.
My 2005 4runner (150,000 miles on island where you can't drive to 60mph except 1 time a year) has had no engine problems since I bought it new (15 years), and I always wondered what to do if my HG failed.
If the HG is badly damaged I doubt anything but a new HG will fix the problem. I'd try the Steelseal. What have you got to lose? If it don't work, find your mechanic for a new HG.
I check my coolant level (in the overflow canister) twice a week. It is always on the same line, never low, but I still keep checking it 'cause it is a 15 year old 4runner.
Never had 1 overheat (OH), and don't want one OH!
I use regular conventional oil recommended weight, and change it every 5000 miles in the driveway! Taking it to the dealer is just a waste of time. They always ask me to leave it overnight. Takes 30 minutes with a filter in my driveway, on my time. Just don't overtighten the drain bolt.
