10-15-2018, 02:17 PM
Real Name: brian
Real Name: brian
Pedal Commander Real World Review
Well i pulled the trigger on a pedal commander for my 06 v8 4runner. I have had this on my 4runner for a little over a month now. Here is my review of it:
Pros:
1- better throttle response, almost completely removed the drive by wire delay. Used Sport 1 setting. City was OEM setting, sport + was too sensitive.
Cons:
1- unless you are in city this thing killed fuel mileage, i mean killed it. It literally cut in half.
2 - looses top end power, actualy took away from it. From what i have diagnosed over this time is that the module actually opens the throttle blade sooner so its fully open by roughly 3/4 pedal travel. at full throttle it does not pull as hard. So now if i want it to move quickly i have to figure the sweet spot at roughly 3/4 pedal or it will not have the power it should have.
3- not consistent at all. Like i said before i keep it at sport 1. Sometimes its very smooth off the line, other times its throwing you back in the seat. Not very good when you have others in the vehicle and the rear seat passengers end up in the cargo area.
I tried different adjustments, different settings and i just cannot find myself to like this device.
So if anyone out there is thinking about this unit hopefully this review might help. In my opinion it was 260.00 wasted.
'08 4Runner Limited V8 Shadow Mica: Sport hood, bilstein 6112's, 5160's, b12 coils, Gibson cat back, 4runner XSP rims, Michelin X LT AS 275/55-20
'06 4Runner Limited V8 Salsa Red: bilstein 6112, 5160, Wheeler T12's, 4Runner XP wheels, Michelin AT2 275/55/20, Magnaflow Exhaust,, Powerstop brakes, sport hood
RIP.....'08 4Runner Limited V6: white, bilstein 6112s, 5160s, b12 , powerstop brakes, nav, TRD cat back, 4Runner XP rims, Michelin Defender LTX 275/55-20, sport hood
10-15-2018, 03:40 PM
You are the first person I've seen give it a negative review.
It hasn't changed my fuel mileage at all since installing it about 2 years ago. I keep a close eye on that every fill up. If you drive faster after installing it it will change the mileage, but not if you drive the same speed as before.
I really doubt it decreases full throttle. The blade I'm guessing can't open past 90deg. I haven't noticed that issue and I've gone 60-90mph a couple times and it still pulls hard. I'll need to turn it off to check.
It has taught my pedal foot to be very sensitive on the street, so when I turn it off offroad it really feels like the pedal is dead which is a good thing when rock crawling.
On the positive side I'm sure you can get most of your money out by selling it on the forums to somebody if you wanted.
10-15-2018, 07:24 PM
Real Name: brian
Real Name: brian
I do not drive any different than before in installed it. The throittle blade just opens earlier with it on. Thats how the system works. Think of this. When it was stock flooring it would open the throttle blade 90 degrees. With the system hooked up it opens the blade earlier than stock would so full throttle comes in earlier than stock.
I have not figured out the fuel issue yet. I just know that i am going through more gas on the same commute than i did when it was stock. This is just from observation but we went to the inlaws saturday. I usually use less than 1/4 tank of gas round trip this time i used 1/3 tank. Thats substantially higher.
10-15-2018, 07:41 PM
That's exactly how it works, but as long as you are accelerating at the same speed as you were before your MPG wouldn't change. It just crams the 0-100% throttle inside a shorter pedal range.
10-16-2018, 07:10 AM
Gas in New England was switched over to 'winter blend' over the past month. Even without a throttle modifier, I've seen my mpg drop by about 2 to 3 mpg with the season.
Blame ethanol and government regulation.
2007 SR5 V6 long live the kingfish !
2009 SR5 V6 ---RIP
10-16-2018, 11:08 AM
I believe the pedal uses a different map when in low range also. it requires much more travel. so that, combined with turning off the PC, I can imagine its a significant difference in pedal feel/travel.
1985 pickup : EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5 : 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited : stock. Build Thread YouTube Channel
10-16-2018, 04:59 PM
Hmm... that’s too bad that it didn’t work out for you. I thought it was very similar, or the same as the Sprint Booster, but maybe not? I consider the SB to be some of the best bang for the buck mod money I’ve personally spent so far on my runner. It has like 18 different settings to play with, and that makes it easy to find the perfect sweet spot for anyone’s driving style. I run mine on “race 5” now that I have larger tires, but I used to have it at race 3, or 4 and that was perfect for the response I was looking for. It really woke up my truck and made it more fun to drive. BTW, I have had zero change in mileage in the couple of months I’ve been running it now. The only change, as someone previously pointed out is due to the winter mix of the fuel.
2004 black SR5 V8 4WD with TRD dual exhaust, Thorley headers, AFE dry filter, Sprint Booster, Icon 2.0 rear shocks, OME 895E springs, Fuel wheels with 265/70/17 Wildpeak AT3W tires, more to come...
10-16-2018, 09:15 PM
Real Name: Russell (OB #9908)
Pros:
Cons:
Ouch. Sorry it worked out that way but your candor is greatly appreciated.
I guess I was lucky coming into my '07 V6 4Runner from 11 years in a 170 hp Xterra. Those 60 extra horses make it like Christmas morning every time I step on the gas compared to my X.
The 4Runner moves pretty well for an SUV imo and I've never understood the complaints about pedal lag and such. I've only driven mine but when I hit the gas, it goes.
12-27-2019, 08:51 PM
reviving an old thread instead of starting a new one.
I just got the Pedal Commander and I had to try it on SPORT+ +4, CRAZY, I love it lol.
What settings are you guys running?
2007 Sport.
"Colorado is FULL, try N.M."
"Everyone is an expert"
12-27-2019, 10:14 PM
Real Name: Elliott
Real Name: Elliott
I've been running mine for a year solid. I love it. I did notice a decrease in mileage, however I later eliminated the PC as the culprit when I had to overhaul the fuel delivery system. Since then, mileage is excellent as before and PC works great. I'm running sport+ 0
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
12-27-2019, 10:56 PM
awesome, thanks I will try the SPORT+ 0 tomorrow
2007 Sport.
12-28-2019, 11:33 AM
Let me know how it goes!
I have an 04 sport edition and i just learned about this pedal commander it’s looking interesting!
12-30-2019, 09:26 AM
Right now I'm on the SPORT,,,, +4 seems good. But we had some snow this weekend so kind of hard to tell lol
2007 Sport.
12-30-2019, 03:35 PM
Real Name: brian
Real Name: brian
Wow. I must be the only one who did not care for it. My v8 has horrible lag and i thought it would help but it just did not feel right. My v6 has instant response so i did not use it in that one.
Its just sitting in the box now.
01-07-2020, 02:05 PM
I second you on that statement. I’m coming from a weak Xterra myself. That 3.3l V6 was a pig and did not have any power at all. Now I’m in a V8 and don’t need to change a thing!
