Old 10-16-2018, 09:20 PM #1
New_2_4runners New_2_4runners is offline
New_2_4runners will become famous soon enough
Swapping Frames. No clue what I’m doing.
Hey all,
Just starting a thread to chronicle my frame swap. I’m not a car guy but this seemed fun so I bought 2 4runners for $500 each. One running but badly rusted frame and one parted out.
Here is the starting arrangement
The first order of business was to get the donor truck apart
Which was pretty easy
Then getting the frame picked clean
It’s for sale in Norfolk if you want it!
Clean frame
Last edited by New_2_4runners; 10-16-2018 at 09:59 PM. Reason: Adding to the story
New_2_4runners is offline   Reply With QuoteReply With Quote
Old 10-16-2018, 09:25 PM #2
Johns06yota's Avatar
Johns06yota Johns06yota is offline
Real Name: John Iannacone
Johns06yota has a spectacular aura about Johns06yota has a spectacular aura about
Originally Posted by New_2_4runners View Post
Hey all,
I really look forward to this!
Johns06yota is offline   Reply With QuoteReply With Quote
Old 10-16-2018, 09:37 PM #3
P40Wolf's Avatar
P40Wolf P40Wolf is offline
P40Wolf is on a distinguished road
P40Wolf's Avatar
Hey all,
Take the body off the hulk, clean up the frame, push to the side. Unplug/disconnect/ unbolt everything from body of complete 4Runner from frame and drivetrain. Tag and mark all connections so you don’t mix stuff or forget. Take frame with engine, trans and tcase, park next to good frame. Move all good drivetrain to good frame (I’d keep the rear axle in good frame there, housing is probably still good).
Take new frame with good drivetrain, push back under new body and put together. Hook up all connections again.
Start and season with pepper for effect.
P40Wolf is offline   Reply With QuoteReply With Quote
Old 10-16-2018, 10:08 PM #4
Then I went on assignment at work for about 5 months while the frame sat out in the field.
Finally 2 weekends ago we got around to working on wire wheeling the frame
The time in the field had it pretty rough
The previous owner had cut out the tire winch
There comes a time in every frame’s life for a certain procedure
Degreased with POR15 degreaser
Then metal prepped and painted with POR15
Drying
All finished up
Inside until the next stage
Old 10-16-2018, 10:11 PM #5
Feel free to offer any tips, tricks, advice, or ‘wish I hads’! Hopefully in a few weeks it’ll be frame swap time.
Old 10-17-2018, 06:53 AM #6
Slowgoat's Avatar
Slowgoat Slowgoat is offline
Slowgoat will become famous soon enough Slowgoat will become famous soon enough
Slowgoat's Avatar
Impressive
2022 LUNAR ROCK TRAIL SPECIAL EDITION
2010 MAGNETIC GREY SR5 PREMIUM
2004 V6 WHITE 4RUNNER SPORT
1995 V6 3.0 BLACK 4RUNNER 4X4 (Retired)
4th & 5th Gen UCA Install Thread
Slowgoat is offline   Reply With QuoteReply With Quote
Old 10-17-2018, 08:33 AM #7
Hey not sure if you did this or not but Eastwood makes an internal frame coating that blocks and goes over any rust. I’ve heard it works pretty well and may save your new frame from what happened to the other one
Old 10-17-2018, 10:22 AM #8
CookieRoe's Avatar
CookieRoe CookieRoe is offline
Real Name: Ed
CookieRoe is a jewel in the rough CookieRoe is a jewel in the rough CookieRoe is a jewel in the rough
CookieRoe's Avatar
Real Name: Ed
sub'd
Very cool, good luck with the swap!
CookieRoe is offline   Reply With QuoteReply With Quote
Old 10-17-2018, 11:26 AM #9
adkfinn's Avatar
adkfinn adkfinn is offline
adkfinn will become famous soon enough
adkfinn's Avatar
Did you top coat the POR-15? If you haven't, you should. It is meant to be painted over and is not UV stable and will fail over time when exposed to light/air/water/etc.
2007 4Runner with some crap on it. Nice crap.
adkfinn is offline   Reply With QuoteReply With Quote
Old 10-17-2018, 01:02 PM #10
duffdog duffdog is offline
duffdog is a jewel in the rough duffdog is a jewel in the rough duffdog is a jewel in the rough
I would paint that with appliance epoxy or the hardest possible paint I could find.
2005 Blue SR5 v8
3" suspension lift, 1" body lift, 315's, rear Elocker, on-board air system, slider air tanks, full skid plates, front Demello bumper, rear HMF plate/tube bumper, rear 9000lb hidden winch, front 10000lb winch, dual electric fans (in cab adjustable temp), rock lights, 25W LED projector lights.
duffdog is offline   Reply With QuoteReply With Quote
Old 10-17-2018, 04:59 PM #11
Terminator03 Terminator03 is offline
Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough
This is quite true. It looks awesome as is, but it would be best to topcoat it wit some nice black acrylic enamel with hardner.
2004 black SR5 V8 4WD with TRD dual exhaust, Thorley headers, AFE dry filter, Sprint Booster, Icon 2.0 rear shocks, OME 895E springs, Fuel wheels with 265/70/17 Wildpeak AT3W tires, more to come...
Terminator03 is offline   Reply With QuoteReply With Quote
Old 10-17-2018, 05:32 PM #12
Jdevtac Jdevtac is offline
Jdevtac is on a distinguished road
Yeah for all the work that went into it I would’ve picked an epoxy paint rather than por15. POR15 is for last ditch rust coat. It doesn’t like to stick long term to previous paint, clean metal, or the like. And people get mixed results even with metal prep on clean metal. I’d be scared it would start peeling in sheets down the road.
Jdevtac is offline   Reply With QuoteReply With Quote
Old 10-17-2018, 06:52 PM #13
cooper30 cooper30 is offline
Real Name: Ted
cooper30 is on a distinguished road
Real Name: Ted
Thank you for sharing
cooper30 is offline   Reply With QuoteReply With Quote
Old 10-17-2018, 08:32 PM #14
Thanks, I do have 3 cans of it and plan to coat the inside of the frame
Old 10-17-2018, 08:37 PM #15
I’ve been getting mixed answers on that in my research so I haven’t decided yet if I’m going to top coat it.
Road noise and frames/sub frames GangsterOfLove General Discussions 0 10-15-2016 07:48 PM
No clue - Tires. jaebird82 4th Gen T4Rs 19 06-23-2012 01:49 AM
Any clue what this plastic box is? CraigRoberts 5th gen T4Rs 5 06-19-2012 10:23 PM
have no clue muddybamayota88 Maintenance/Detailing 1 01-17-2005 10:05 PM
K I don't have a clue....help! nyceride Classic T4Rs 4 10-17-2004 08:30 AM
