Real Name: Brendan Chura
I would see if you can take it off yourself and get some pipe cleaner/wire brush through it. I don't know how water could get in there besides maybe condensation buildup? Either way, I imagine it should be easy to remove and clean out. You could also try and push through a cleaning brush then immediately change the oil but it might not be great to have the potential of rust particles contaminating your oil. Just thinking aloud here but I would see if you can remove/clean youself. Good luck
2007 SR5 4WD - Toytec Ultimate 3" Front Coilovers, Boss Extended Travel Rear Shocks and Springs, 285/70/17 Falken Wildpeak A/T3W, Spidertrax, Body Mount Chop, JBA UCA, White Knuckle Sliders
