10-27-2018, 03:41 PM
#16
Originally Posted by flipflopnfly
Good point. Yeah, my 2008 was very difficult to flush the frame clean. It was absolutely PACKED with Colorado silt. There is only tiny drain holes on the underside, I had to stuff my garden hose with a spray nozzle into the side openings and flush the silt out of the rear. Required hours, I left the spray nozzle in each side and had a couple beers before the water came out clean.
The front of the frame was more difficult to flush clean, no front exit, silt/water had to exit from the sides.
Do they use salt in Colorado, Denver specifically? My daughter is going to move there after graduation with a pristine, Houston all its life, 2006 4Runner sport. We both hope/plan for this to be her daily driver for another 10 years. Wondering if we should be concerned or take some preventive action...
2012 4Runner Limited 2WD
2006 4Runner Sport 4WD
2006 4Runner Sport 2WD
10-27-2018, 03:44 PM
#17
Real Name: Matthew
Real Name: Matthew
Even if they don't use salt, it'll rust, just not necessarily as fast. And if sometime during that time period they (God forbid) start using brine...good luck. You'd probably be best off taking preventative measures anyways, I have heard tons of really great things about Fluid Film.
Instagram: @projectrustyrunner
2003 V8 | Titanium Silver | 180k miles | Uniden CB | Bilstein 5100 Front @1.75" | Extended rear diff breather | American Racing 16" wheels | Full interior LED conversion | Curt roofrack w/ extension
10-27-2018, 03:52 PM
#18
Is this a DIY product? Doesn't seem like it would be a lot of fun crawling underneath and spraying this stuff all over, including on me and the garage floor. And how would it get into the frame if it doesn't have access points to spray into?
10-27-2018, 04:23 PM
#19
Salt and Magnesium Chloride and gravel. Don't worry, vehicles don't rust in Denver or Colorado as a whole. Car washes are rarely closed for more than a week due to below freezing weather so one is able to spray off accumulated grime, put the wand on the underside, wheelwells, blast the skid plate.
The 2008 was a CO vehicle all its life when I bought it and even though the frame was packed with Western Slope silt, it wasn't rusted at all. The thing is the air is perpetually dry here year round, it's a semi-arid climate. Dry climate means even with accumulated dirt it doesn't STAY damp.
The gravel blasts the paint pretty good, like on the rear axle. Just keep it clean.
10-27-2018, 04:57 PM
#20
Really only thorough washing is needed in CO. There will be surface rust where paint is gone on the frame and undercarriage, but not the godawful things I've seen from east of the Missouri River. The air is just too dry here, it sucks the moisture out of accumulated dirt like I found in the 2008's frame when I bought it.
Salt itself is minimally corrosive unless it is WET. A dry environment like CO, vehicles are constantly DRY, unlike a humid environment.
Anyway, I still haven't figured out how the 2008's frame got packed like it was. It literally was packed with silt to the side holes on the frame. That's how I discovered it, ripping the XREAS off to put a BOSS suspension on it. Frame wasn't rusted though.
10-27-2018, 05:19 PM
#21
I did spray FluidFilm on the 2008 after I flushed the interior of the frame rails. Probably wasn't necessary but it was on jackstands installing the new suspension, so I did it. Spray cans, sprayed it into all of the openings I could find on the rails. It's a waxy product, lasts maybe a year on exposed surfaces. The product has great reviews.
Your daughter's 2006 will be fine without such treatments. Frames don't rust out in CO, I've had Tacomas, a Tundra, notorious rusters in Eastern humid climates, no problems here.
10-27-2018, 10:49 PM
#22
We moved from CA to MN for almost five yrs with a 2008 in 2010. That part of the country uses salt religiously and it’s on the ground intermittently 6-8 months out of the year. Knowing we’d eventually be moving back to CA I was super concerned about rust and did a ton of research on options, including undercoating, ultimately deciding on regular car washes because the undercoating processes can miss areas, certainly including inside surfaces of the box frame.
Did a bunch of research on good full-service car washes in the area (undercarriage wash was a must), picked one not super close to home but with stellar reviews, bought an unlimited-visit monthly membership and went at least once weekly during winter months. We moved back to CA 5 yrs later almost entirely unscathed.
Just my experience moving from no-worry to high-worry rust environments.
Not Stock 2008 V8 4WD SR5
12-20-2018, 10:32 AM
#23
It's a long shot, but I'd happily take a fat buyback towards a new Toyota truck.
https://www.forbes.com/sites/jensen/.../#685131aa7302
Dec 18, 2018, 10:40am
New Class Action Claims More Toyota Trucks Have Dangerous, Rusty Frames
Gary Weinreich says the frame of his 2005 4Runner was so badly rusted a steering component broke away while he was traveling down a two-lane road.GARY WEINREICH
By Christopher Jensen
A federal class-action suit claiming that the frames on the 2005 – 11 4Runners are defective and dangerous because they rust prematurely has been filed against Toyota. The action echoes a class-action settled last year but covering different Toyota trucks.
The allegation in the new class-action contends the frames “are prone to excessive, premature rust corrosion because the frames were not properly prepared and treated against rust corrosion when they were manufactured."
It names Gary Weinreich, the owner of a 2005 4Runner, as the lead plaintiff in the suit filed in South Carolina.
“The excessive rust corrosion on the Toyota 4Runner compromises the vehicles’ safety, stability, and crash-worthiness because important suspension components, engine mounts, transmission mounts, and body mounts anchor to the vehicles’ frames. It has also affected the value of the vehicle,” according to the suit.
In an email Toyota spokesman Eric Booth said “the safety of our customers is a top priority. While we cannot comment on these specific claims at this time, we will respond in the appropriate forum.”
The class-action settled last year covered 2005 – 10 Tacoma models; 2007 – 08 Tundras and 2005 – 08 Sequoias. (continues) ...
12-20-2018, 02:46 PM
#24
Like
@ flipflopnfly
says it's the magnesium chloride that is the killer of all things metal. It is mostly applied as a liquid, some call it brine, but it will eat through painted and primed metal. It turns semi truck trailers to scrap metal in a few years.
Even here in Oklahoma where we don't get much winter, cities have started "pre-treating" the bridges if winter weather is forecast. I think governments are being sold this "new" form of road deicing by some very unscrupulousness business people.
Don't just take my word on this, read up about magnesium chloride and metal. Talk to an automotive or other equipment manufactures. We need to petition to stop using the stuff on our roads.
I currently own 4 T4R 4th Gen
#1) 2003 Sport V8 2WD purchased new, totaled @ 175,000.
#2) 2003 SR5 V8 2WD running w/engine from #1(Son#3 is Driving)
#3) 2003 Sport V8 4WD
#4) 2004 Sport V8 Supercharged 4WD
12-20-2018, 03:54 PM
#25
Originally Posted by V8Man
Like
@ flipflopnfly
you are 100% correct. The chemicals being used are politically motivated business practice. They need to go back to sand! The rate at which these chemicals cause corrosion of vehicles and roads which together compound the problems 10 fold. Not to mention, the most likely long term effects on the environment and our health. Seriously need to start a petition.
12-20-2018, 10:56 PM
#26
Originally Posted by Burt
Nope.... The root cause is the crap on the road surface.
Funny, none of my older cars like my 1996 Honda Civic has any issues with rust driving in salty snowy conditions its whole life.
12-20-2018, 11:01 PM
#27
Like
@ flipflopnfly
You're 100% on point. Even worse than the MC is the brine IMO. Horrible stuff. Petitions do not do jack shit though. The people signing it will be a minority. Most people go through a car every ten years MAX, not enough time to understand the effects of these chemicals for some average joe shmoe.
12-28-2018, 03:41 AM
#28
Dang, I have a 2007. It'd be nice to get the frame taken care of. I got the rust ground off it and an undercoating put on it so hopefully that will alleviate most of the potential rust problems.
12-28-2018, 08:37 AM
#29
Unfortunately, even though the exterior may look good, a lot of the corrosion problems we have originate from the inside of the frame where it’s very difficult, or impossible to clean/coat correctly. I do agree though, that something done is better than nothing. I sandblasted, primed and painted my frame, but I’m still very worried about what’s happening on the inside where I couldn’t get to.
2004 black SR5 V8 4WD with TRD dual exhaust, Thorley headers, AFE dry filter, Sprint Booster, Icon 2.0 rear shocks, OME 895E springs, Fuel wheels with 265/70/17 Wildpeak AT3W tires, more to come...
12-28-2018, 08:50 AM
#30
Real Name: Sparky
Real Name: Sparky
You'll see a tanker truck spraying scalding hot water/mag chloride brine before every blizzard here. It's nicely aerosolized so at highway speed it gets inhaled into every nook and cranny of your vehicle, especially if you pass the truck and get a "broadside" from the sprayers.
Go to an underbody car wash as much as possible in the winter, if you let that shit sit caked on your truck for a week it'll start to cause mischief.
And the truck in the story looks like it spends its weekends in half a foot of saltwater at a boat launch... never trust anyone named "Gary."
Old and (c)rusty.
