Old 10-31-2018, 01:26 AM #1
woodman60 woodman60 is offline
woodman60 is on a distinguished road
Head Gasket Repair - or Not
Help! I own a 2005 V6 with 195K. Purchased by me at 180K. Has always run great.
I've gotten two oil analyses from Blackstone 3000 miles apart and both were positive for coolant in the oil. Following the first, I also ran a block tester and showed hydrocarbon gases in the radiator. Hard to imaging it's anything other than a head gasket.
However, there are no other symptoms. No CEL or codes. No rough running at start up. No white exhaust. No fouled plugs. Always runs at a constant temp below mid-point on the gauge, etc.
If I hadn't read about early 4th Gen head gasket problems here, and gotten an oil analysis, I would probably still be fat, dumb and happy...instead of just fat and dumb.
Should I fix it now? Wait to see what develops? It's really hard to want to spend $3-4 K on a truck that runs so well.
woodman60 is offline   Reply With QuoteReply With Quote
Old 10-31-2018, 08:54 AM #2
hinmo24t hinmo24t is offline
hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough
just keep running her
hinmo24t is offline   Reply With QuoteReply With Quote
Old 10-31-2018, 10:55 AM #3
Trumpet Trumpet is offline
Trumpet will become famous soon enough Trumpet will become famous soon enough
Fix it now, you're out the coin. Fix it later, it may fail harder in a much more expensive fashion.
Tough call.
But if I knew my headgasket was failing I couldn't/wouldn't take the vehicle on road trips or really do much else with it until it was repaired.
2007 SR5 V6 long live the kingfish !
2009 SR5 V6 ---RIP
Trumpet is offline   Reply With QuoteReply With Quote
Old 10-31-2018, 10:59 AM #4
gaber6 gaber6 is offline
gaber6 has a spectacular aura about gaber6 has a spectacular aura about
Sounds like how my 2005 failed at 155k.
It's not a horrible fail that a stop leak can can't fix if on a trip... Or put stop leak in it now to slow it down for 6 months, save an extra $200 a month for the fix and decide when you have the cash to fix it or stop leak it again.
gaber6 is offline   Reply With QuoteReply With Quote
Old 10-31-2018, 12:21 PM #5
rumfoord's Avatar
rumfoord rumfoord is offline
rumfoord is on a distinguished road
rumfoord's Avatar
Any coolant loss?
rumfoord is offline   Reply With QuoteReply With Quote
Old 10-31-2018, 03:04 PM #6
Originally Posted by rumfoord View Post
Any coolant loss?
about 1/4 - 1/2 inch per week in my overflow.
Old 11-01-2018, 06:47 AM #7
radlynx radlynx is offline
Registered User
radlynx will become famous soon enough
Registered User
good call for the oil analysis. oil and coolant mixing is not good. get it fixed if you plan on keeping it for a long time.
Sent from my SM-G930T using Tapatalk
radlynx is offline   Reply With QuoteReply With Quote
Old 11-26-2018, 06:42 PM #8
djpope09 djpope09 is offline
djpope09 will become famous soon enough
Blackstone probably mentioned that you could run it like that as long as you change the oil regularly (like 500-1000 mile intervals).
If I were you I would do it now. If the coolant is getting into your exhaust it will ruin your cats. That's just more money to pay later.
I did this job in my garage about 11 months ago without removing the engine or any body panels. If you haven't done it yet and have questions, feel free to PM me.
djpope09 is offline   Reply With QuoteReply With Quote
Old 11-26-2018, 07:50 PM #9
It's in the shop now. Rough running at startup was happening more often and I was starting to get a little bit of white exhaust.
Peace of mind will be worth it.
Old 12-10-2018, 02:27 PM #10
rumfoord's Avatar
rumfoord's Avatar
You won't regret fixing, I committed to mine and while ya, out the 3 grand still happy to have it.
Old 12-10-2018, 02:44 PM #11
Seymore Butts's Avatar
Seymore Butts Seymore Butts is offline
Seymore Butts will become famous soon enough Seymore Butts will become famous soon enough
Good call on fixing it now. Are you doing any other work "while you're there"?
Seymore Butts is offline   Reply With QuoteReply With Quote
Old 12-10-2018, 02:57 PM #12
Came in right around 3K. Was planning to do the water pump, but snafu with getting the part held that up. Easy enough to do later.
Feel better about investing even more money into it now. Dobinson's lift all around and new front LCAs going in next week...followed shortly by a set of Falken Wildpeaks...and sliders...
Old 10-30-2022, 08:37 AM #13
whirlwind22 whirlwind22 is offline
whirlwind22 is on a distinguished road
What do you think?
Blew the head gasket in my 04, what do you guys think would be a fair sale price?
whirlwind22 is offline   Reply With QuoteReply With Quote
Head Gasket repair shadowdude22 Classic T4Rs 10 06-03-2016 05:58 PM
head gasket repair photos iBison 4th Gen T4Rs 0 06-21-2015 10:35 PM
3.4L P0305 after head gasket repair help!!!!! Nelsontacoma 3rd gen T4Rs 7 07-25-2013 09:23 AM
head gasket repair leads to piston through head theresa4586 3rd gen T4Rs 37 03-20-2013 01:20 AM
Head Gasket repair KingJerd Classic T4Rs 5 04-11-2009 05:59 PM
