Old 09-24-2020, 10:33 AM #31
Originally Posted by Captsolo View Post
The Toyota dealer that sold me the 4runner in 2005 did the Transmission service (Drain and Fill of 5 quarts of WS IV). I have their receipt with date and mileage and costs.
The 4runner holds about 12 quarts of WS, so you get a good (but not complete exchange/flush) renovation.
Read what happened here and above:
Mr_Dobalina View Post
I had a flush done on my 2002 Tacoma. The transmission blew up 4 months later...
4runner transmissions have gone to 250,000 miles with no tranny service. Some have gone over 500,000 miles (with D/F 5 quart service??).
Every 60,000 miles after the first drain and fill at 100,000 miles is good practice with Toyota lifetime WS. IMO.
you really need to quit posting misinfo like this... nowhere in any toyota owners or service manual does it say to drain 5qts at 110k miles... where are you getting those number from? just because thats on your receipt does not mean thats a recommended amount. & you cant drain 5qts on a pan drain. my guess is that the dealer just overfilled the trans by ~1qt & charged you for 5 qts, that is how youre supposed to check the fluid level, let it drain at the right temp until a trickle to verify the correct fluid level. not have a friend drain 5qts then have a friend refill 5 qts.
& whats with the T 1V or WS IV. WS does not have IV after it, its just WS. your first post told everyone to use T 1V in their 5 speed sealed trans!!!
Old 09-26-2020, 10:17 AM #32
4runrr 4runrr is offline
4runrr is on a distinguished road
I was getting the transmission rumble strip effect and hard downshifts on a transmission with 180K original fluids. Had the dealer change the fluids according to something similar (4th gen vice 5th): Transmission fluid change - Toyota 4Runner Forum - Largest 4Runner Forum
It immediately cleared up the rumble and the hard downshifts. Had about a week were I was worried it would blow up per peoples comments. But 2 years and 20K miles later it's still working fine.
4runrr is offline   Reply With QuoteReply With Quote
Old 07-28-2022, 02:25 PM #33
Ali0227 Ali0227 is offline
Real Name: Ali
Ali0227 is on a distinguished road
Real Name: Ali
Question What's a full exchange
Originally Posted by Bluesky 07 View Post
Did you see Scotty Kilmer’s episode on “lifetime” transmission fluid? Change it by full exchange (not forced flush) as others have recommended. My local dealer did a full exchange for $179 or so. Thought that was fair since the fluid alone was $100+.
Sorry, I'm not a mechanic, just a female trying to maintain my 04' Limited 6 cylinder runner and don't know what you mean by a full exchange. I've never had the ATF changed yet and after reading posts with different suggestions of drain and fill vs. flush, thought it's about time I take action and get er' done. Is there any kind of machine involved in a full exchange? Sorry for my lack of knowledge. I'm original owner and have 128K miles on the vehicle. I had planned on doing a drain and fill 2 or 3 times as some have suggested because of high mileage. I think I saw a post that recommended driving around 500 miles in between drain and fill. If I do a drain and fill 2 or 3 times putting mileage on between each drain and fill, will that totally get all the old fluid out, including what's in the torque converter? What are your thoughts for my year and mileage? Thank you!
Ali0227 is offline   Reply With QuoteReply With Quote
Old 07-28-2022, 02:44 PM #34
Real Name: Ali
Real Name: Ali
Drain & Fill
Originally Posted by Warwicke36 View Post
Change the fluid with multiple drain and fills. I did 4 on my 2004. I had 193k on it when I did it. P.O. never did it. I tow with mine and wanted new fluid in there. I also added a Hayden cooler and Scangauge to watch temps.
IMO if thick fluid is keeping the clutch packs working then it's shot anyways. Id rather find out at my shop then out somewhere. In 15 years of being a mechanic I have had 2 transmissions fail after a FLUSH (not a drain and fill) 1 was a Grand Cherokee with 223k which I suspect had issues beforehand but I didn't road test it long enough to know. The other was a Chevy truck with a plow and a sander, also with high miles.
Good luck. Use the right fluid from the dealer!
I have 128K and have never changed mine yet. Going to bring to my mechanic next week for drain and fill. At what intervals did you perform your 4 drain and fills? I also have an 04 (it's my baby!). Did you go by time, miles put on vehicle or some other interval in between each drain and full? Also is there anything that should be done after each drain and fill, like filter change (if there is one), etc? Thank you!
Old 07-28-2022, 03:15 PM #35
Real Name: Ali
Real Name: Ali
Drain and Fill
Originally Posted by Drcoffee View Post
“ ... of 5 quarts of WS IV”. That is a generic phrase. I sure hope the dealer did not use IV ATF. That would be the wrong fluid. So, dont put too much faith in what exactly the dealer did. You can say they did a drain and fill, thats all.
The shop overcharged for the fluid. A drain and fill is only 3.5qts but the average consumer would not know that and just accept the charge for 5qts. I think the issue here is miscommunication. Stop saying 5qts. You dont know that for fact, only that someone was charged for it.
If your tranny was shifting well before a fluid exchange, it should be better afterwards. If it wasnt working well before the fluid change, chances are it will bring on an early failure.
Here is my take on it. New ATF is a great cleaner. What happens to all that crud when you put a cleaner in tne old transmission? All that crud frees up and blocks small passages within the tranny. Results in failure. The solution is to add a high quality filter to catch the crud before it can reenter the tranny. Check out MAGNEFINE inline filters. I add it to all my vehicles on the cooler line and power steering return line. Never had a transmission failure, ever.
Hi I'm just reading your post now. I'm not a mechanic but have an 04 V6 4WD 4Runner and wanted to have my ATF changed but concerned b/c I have 128K miles so don't want to do a flush. If I let my mechanic do a drain and fill 3 or 4 times putting 300-500 miles on the vehicle between each drain and fill, do I have to worry about the crud getting into tranny? If so, where is the high quality filter placed on the vehicle so crud doesn't get into tranny? Or would you recommend a full fluid exchange (doing it all at once)? I was reading not sure if it was this thread but a full fluid exchange it done using the trans. pump? Thank you.
Old 07-28-2022, 03:19 PM #36
Napalm's Avatar
Napalm Napalm is offline
Real Name: Nathan
Napalm will become famous soon enough Napalm will become famous soon enough
Napalm's Avatar
Real Name: Nathan
I just bought my '07 with 195k on the clock, tranny fluid hasn't been changed since 30k miles. I plan to have a simple drain and fill done, hoping it doesn't cause any problems.
2007 SR5 V8
2017 Limited
Napalm is offline   Reply With QuoteReply With Quote
Old 07-28-2022, 04:05 PM #37
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
A flush involves a machine pumping new fluid in under pressure. A full exchange is really just a drain and fill done all at once instead of a few quarts per session. There’s no machine and the fluid is poured into the transmission rather than pumped in under pressure. This thread describes the process. I recommend reading the entire thread as people make some good points and suggestions based on their experience. Personally I don’t see the point of doing several drain & fills as opposed to all at once but that’s a judgement call.
The purpose as I understand it is to reduce the possibility of stirring up stuff in the fluid that might cause problems (same reason not to get the pressure flush) but the counterpoint is that modern transmissions are less susceptible and I’ve yet to see anyone with an issue from doing a full exchange.
As for year & mileage, imo you’re in a great place to replace your fluid. I did my first one at 114K miles.
I’m not a mechanic either ;-) but am happy to answer any other questions as best I can. Actually, I have one for you: does your ‘04 have a transmission dipstick or had Toyota gone to the sealed system by then?
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 07-28-2022, 07:01 PM #38
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
The 2003 and 2004 V6 has the 4 speed transmission and isn't sealed, and yes it has a dipstick.
If it was the 2004 V8 it would be a 5 speed and sealed, that's the first year of the sealed transmission for 4Runners, 2005 and onward both the V6 and the V8 has the 5 speed sealed transmission, also an FYi the 2003 V8 had the 5 speed transmission as well but it wasn't the sealed version and had a dipstick.
2004 Limited V8
Old 07-29-2022, 09:21 AM #39
Real Name: Ali
Real Name: Ali
Fluid exchange?
Originally Posted by Seymore Butts View Post
Do the complete fluid exchange by using the in & out cooler lines at the radiator. That's not a pressurized flush, just an exchange while the fluid is normally circulating.
Your transmission was designed to use a specific fluid, and the stuff in your high-mileage transmission is completely out of spec at this point.
You'll probably notice smoother shifting, better mileage, and your transmission will last longer with proper fluid and not that old, dirty stuff that's in there now.
Does your method use the trans pump to pump the old fluid out. I have an 04’ non sealed tranny and trying to understand process so I can be clear with my mechanic, so please pardon my lack of knowledge. If my mechanic can’t do the exchange in a non-pressurized method, I guess I’ll have him drain and fill and do that 3 or 4 times. Do you know if the drain and fill done several times will eventually get the old fluid out of the torque converter? Thank you!
Old 07-29-2022, 09:26 AM #40
SurferUK's Avatar
SurferUK SurferUK is offline
SurferUK has a spectacular aura about SurferUK has a spectacular aura about SurferUK has a spectacular aura about
SurferUK's Avatar
You could always send the link for the process to your mechanic to see if it is something they can do. If it helps I am an experienced DIYer but by no means an expert. I followed that guide as this is my first ever automatic and as long as you are methodical and have someone to shift through the gears and turn the engine off as soon as you say, it really is a straightforward job. I used a cheap 12V pump to pump the fresh fluid in, and did the differential and transfer box oils at the same time. All in all a relaxed days work.
I think the advantage of this method is that you're not mixing too much new fluid with old fluid.
2008 2.7 2WD 4 speed (Tacoma-Runner?)
SurferUK is offline   Reply With QuoteReply With Quote
Old 07-29-2022, 12:49 PM #41
BackOff's Avatar
BackOff BackOff is offline
Real Name: Derek
BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough
BackOff's Avatar
Real Name: Derek
Firebirdguy towards the end of this thread nails it.
Easy Peasy transmission fluid exchange V6
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
BackOff is offline   Reply With QuoteReply With Quote
Old 07-29-2022, 02:45 PM #42
Jubsz Jubsz is offline
Jubsz is on a distinguished road
^I did pretty much that method on my new to me 08 V8 with 161k miles. Much prefer to use the cooler's return line than trying to pump under the truck past the exhaust. I exchanged 14 quarts. I never had records of it being changed prior to my ownership but it shifted fine. Kinda slow but no shutters or anything. It's been about 3k miles and still going strong.
I did one thing different to that method. I did start under the truck and drained the contents of the transmission pan. I drained it into a measured container which was about 3 qts. I filled the same amount through the cooler's return line before starting the truck to flush the next sample. IMO, it was best to get clean fluid in the pan to start off instead of continuously mixing things up. There was a clear point at the end that my fluid became red and new.
Jubsz is offline   Reply With QuoteReply With Quote
Old 07-30-2022, 08:25 PM #43
Real Name: Skip
Real Name: Skip
With the non-sealed 4 speed and 5 speed transmissions, you refill the fluid via the dipstick tube, there is no refill hole on the side of the transmission that the sealed transmissions have and no reason to use the return line to refill, so it's a much easier process to refill the fluid, simply insert a funnel into the dipstick tube and pour in the fluid, also checking the fluid level is a breeze since all you have to do is check via the dipstick, otherwise the above linked method to exchange the fluid is the same.
2004 Limited V8
Should I change transmission fluid or not? bgravy 3rd gen T4Rs 34 04-11-2020 02:12 PM
Transmission Fluid Change? chetJ 5th gen T4Rs 8 05-06-2014 08:22 AM
Transmission Fluid change $$$ ToolmanJohn Maintenance/Detailing 5 07-03-2012 05:02 PM
Transmission Fluid change???? jesman1484 3rd gen T4Rs 1 11-01-2007 07:49 PM
Transmission fluid change BadHabit Maintenance/Detailing 2 03-26-2005 04:46 PM
