Old 11-15-2018, 01:32 PM #1
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
Suspension Noob Question - Is This Tacoma TRD Setup a Direct Swap?
I found these components for sale - a Bilstein 4600 setup off a 2014 TRD Tacoma. Thinking of going with it in place of my XREAS, which is still working fine but will eventually fail. Would these be a direct swap onto my '07 Sport?
EDIT: Checked p/ns on Bilstein's site and they're the same for the fronts but the rear shows 24-186056 for the '14 Taco and 24-186049 for the '07 4Runner. So maybe the rears won't work?
If so, thoughts and opinions also welcome. I've seen the 4600 vs. 5100 discussions so I'm aware of the differences there.
Thanks for any insight.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 11-15-2018, 04:42 PM #2
ZebRuaj's Avatar
ZebRuaj ZebRuaj is offline
ZebRuaj will become famous soon enough
ZebRuaj's Avatar
IIRC, you need to change out the bushing for the rear shocks.
Another discussion here along with the bushing part #
07 T4R Sport Edition V6 4x4
ZebRuaj is offline   Reply With QuoteReply With Quote
Old 11-15-2018, 05:01 PM #3
2016 4Runner SR5's Avatar
2016 4Runner SR5 2016 4Runner SR5 is offline
Real Name: Chris
2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold
Real Name: Chris
Steel lower bushing sleeve on the front shocks needs to be shaved down a hair, otherwise they are a direct swap and provide roughly 1" lift. Rear shocks require the bushing and sleeve to be pressed out and a new bushing installed. Not worth it IMO since 5th gen 4R shocks are a direct swap along with 5th gen 4R coils which also offer a small lift to the 4th gen.
2016 4Runner SR5 is offline   Reply With QuoteReply With Quote
Old 11-15-2018, 05:06 PM #4
Bluesky 07's Avatar
Bluesky 07's Avatar
Thanks, I missed that thread in my search. Very helpful.
Old 11-15-2018, 05:53 PM #5
Real Name: Chris
Real Name: Chris
To add to this, 5th gen 4R shocks also have a much larger body than the Tacoma shocks do. Not sure how much that'll help with ride quality but it can't hurt.
Old 11-16-2018, 12:20 PM #6
jrm's Avatar
jrm jrm is offline
jrm will become famous soon enough
jrm jrm is offline
jrm's Avatar
the TRD front coils
are a bit under sprung for a 4th gen. Thats been my experience.
jrm is offline   Reply With QuoteReply With Quote
Old 11-19-2018, 04:41 PM #7
Bluesky 07's Avatar
Bluesky 07's Avatar
@2016 4Runner SR5 , from what I've read, it's the FJ fronts that need the bushing sleeve narrowed, not the Tacoma, right? Bilstein's website shows the same 4600 p/n for both my 2007 4Runner and a 2015 Tacoma so I assume this should fit without modification.
Old 11-19-2018, 07:31 PM #8
swanny swanny is offline
swanny is on a distinguished road
I'd say stay away from doing this. I did it and the ride was super soft and bouncy. Save your pennies a while longer and do a full upgrade made for your vehicle.
2006 Sport 4x4 V8 - OME Nitrocharger 2885/2895 - Icon Rebound 17x8 - Nitto Ridge Grappler 285/70/17 - RCI Engine Skid
swanny is offline   Reply With QuoteReply With Quote
Old 11-19-2018, 08:55 PM #9
Real Name: Chris
Real Name: Chris
Can't say for sure. I have a set of 3rd gen Tacoma stock front Bilstein shocks which will eventually make their way under my 2005 sport but that won't be for a while.
Old 11-20-2018, 10:16 AM #10
Bluesky 07's Avatar
Bluesky 07's Avatar
I appreciate the input. I'm going ahead with the swap and the reason is the nature of changing things like the suspension. If I don't care for a shirt I bought, I can return it; not so much with this. I'd rather risk $130 (seller's final price) to see if I like this than spend hundreds more on a setup I may or may not like and will either be stuck with for a while or lose money reselling it.
Also, and again I appreciate the benefit of your experience, but ride is so subjective and peoples' opinions so varied that it's tough to know whether advice applies to you until you bolt the gear on and drive it.
And if you're right, I'll be the first to post back here telling you I should have listened.
Old 11-20-2018, 02:41 PM #11
I wish you the best of luck.
Old 11-20-2018, 02:53 PM #12
Bluesky 07's Avatar
Bluesky 07's Avatar
Thanks, assuming you're not being sarcastic. ;-)
Surprised your experience wasn't more positive. The 4600 p/n for the Tacoma is the same as the 4Runner so Bilstein must feel it works for either vehicle.
Old 09-03-2019, 01:31 AM #13
TCP4R TCP4R is offline
TCP4R is on a distinguished road
So what’s the update? I see this thread is old but I am about to do the same thing so I would love to hear your feedback if you went through with it.
TCP4R is offline   Reply With QuoteReply With Quote
Old 09-03-2019, 05:25 AM #14
Bluesky 07's Avatar
Bluesky 07's Avatar
It’s been the best upgrade I’ve done to my truck. See the linked thread in my sig.
Old 09-03-2019, 08:01 AM #15
JVC8790's Avatar
JVC8790 JVC8790 is offline
Real Name: John
JVC8790 has a spectacular aura about JVC8790 has a spectacular aura about JVC8790 has a spectacular aura about
JVC8790's Avatar
Real Name: John
Also went through with it. Started with 2nd Gen Tacoma fronts and subsequently have found 3rd Gen which I am led to believe provide an additional inch of lift. Those are still yet to be installed but I love the 2nd Gen TRD Offroad stuff I have on there now!
2004 4Runner V8 Limited - TRD Exhaust, LED Interior Swap, Pioneer HU, Tacoma TRD Front Suspension, FJ Rear Springs, 10" + 32" Light Bars, Prius Shift Knob, 275/65R18 Falken Wildpeak, 18x9 Level 8 MK6 Et0, GOBI Ladder, 06-09 Headlight Swap, TOTALED NOV 2019, RESURRECTED APR 2020 Build Thread
1998 Volvo S70 T5 - Custom Airlift Suspension, BBS Nebula Wheels, Brada Seats, Engine Bolt Ons - StanceWorks Build Thread
2010 Subaru Forester 2.5X - Wifes Car
JVC8790 is offline   Reply With QuoteReply With Quote
3rd Gen Tacoma suspension swap onto 4th Gen 4Runner bstave 4th Gen T4Rs 61 02-04-2024 11:11 PM
tacoma suspension swap and lift install.....lots of pix! yotamandan 4th Gen T4Rs 38 01-25-2023 09:07 PM
Tacoma Suspension Swap ARK_SWAMP_RIDER 4th Gen T4Rs 430 03-18-2021 05:49 PM
2016 Tacoma Bilstein Suspension Swap? blackfc3s 4th Gen T4Rs 2 05-10-2016 10:23 PM
Any interest in Tacoma suspension swap? gone_primal 4th Gen T4Rs 4 04-17-2015 11:18 PM
