12-20-2020, 06:12 PM
#31
Year: 2005
Tire Size: 265/70/17
Gear Ratio if you know it:
2WD, 4WD or AWD: 4x4, keep in 2WD unless rainy
Modifications that affect MPG:
Current highway fuel economy: 22 @ 65mph, 18 @ 74mph
V6 or V8: v6
Average speed you travel: 3mph over
Anything else you want to add: I drive like a grandpa.
12-21-2020, 01:54 PM
#32
Real Name: Russell (OB #9908)
Year: 2007
Tire Size: Stock 265/65/17 (but A/T, not highway tires)
Gear Ratio if you know it: Stock
2WD, 4WD or AWD: 4WD (always in 2WD except offroad, in bad weather, or doing the monthly "use it or lose it" maintenance)
Modifications that affect MPG: Reduced rake due to Tacoma TRD OR coils in front (maybe?)
Current highway fuel economy: 19-21 (can get 23+ at 55 mph, measured with OBDII scanner reading real-time MPG)
V6 or V8: V6
Average speed you travel: 65-80 depending on speed limit/conditions
Anything else you want to add: N/A
12-21-2020, 02:16 PM
#33
Looks like I'm the only one who really sucks.
Year: 2006
Tire Size: 285.70.17 Falken AT3W Load C
Modifications that affect MPG: Shrockworks bumper, heavy sliders, TC Mid Travel, Thule 16 cu ft roof box. Only including Thule box because I used it during MPG calculation.
Current highway fuel economy: 12.82
V6 or V8: V6
Average speed you travel: 80+ Keep in mind I learned to drive in NJ, so I do drive like the stereotype.
Sent from my SM-G981V using Tapatalk
06 Curry Runner
12-21-2020, 03:58 PM
#34
Year: 2004
Tire Size: 245/70-17
2WD, 4WD or AWD: 2WD
Modifications that affect MPG: Skinnier than stock tires, but same height
Current highway fuel economy: 19.6 on gauge, 18 actual hand calcd
V6 or V8: V8
Average speed you travel: 74
Anything else you want to add: Recent 800 mile round-trip using Google Maps for distance rather than odometer, and then hand calcd
12-21-2020, 05:08 PM
#35
Year: 2008
Tire Size: 285/70-17
2WD, 4WD or AWD: 4wd, 2wd except when off-road or inclement weather
Modifications that affect MPG: tires, plate bumper, sliders, steel skids, hitch tire carrier with full size spare and hi lift jack.
Performance (lol) intake, Flowmaster 50 suv, 3° retard cam gears, XTP intake plenum spacer.
Current highway fuel economy: 17 thanks mainly to the cam gears, they make a good difference. City driving is about 15, which is pretty good considering all the extra weight.
V6 or V8: V6
Average speed you travel: 70-75
Anything else you want to add: I love this rig and will take the poor mileage.
Sent from my SM-G986U using Tapatalk
12-21-2020, 05:14 PM
#36
year 2007 SE new
Stock tyres
No mods, all stock.
4.0 V6
Interstate: 65-70 listed
2 drivers averaged 23 MPG one day. (Southern Oregon to past Bay Area, CA)
12-21-2020, 06:35 PM
#37
Originally Posted by AceSpades
Year: 2004
V6 or V8: V8
How do you like the 245's? I run 255's but recently I've seen that size in some all terrains. Curious to compare weights and wondering how they do in snow.
Its not even 1/2" so probably not much difference.
12-22-2020, 12:13 PM
#38
The tires came with the car when bought so i cant compare to the original 265s. Tire size calculator says the height difference is only 0.06" or 1/16" compared to stock 265/65-17. When the time comes im looking to go with 255/70-17s. I also have no experience in the snow, we dont get that here
12-22-2020, 02:57 PM
#39
Originally Posted by Inv4drZm
Year: 2005
Tire Size: 35" MT
2WD, 4WD or AWD: AWD
Modifications that affect MPG: Full armor, no roof rack, 3" lift, 1.5" BL
On the same day driving from Colorado to Kansas, flat interstate:
@73mph a full tank gave me 18.5mpg
@80mph a full tank gave me 16.5mpg
V6 or V8: V8
Anything else you want to add: Calculated by hand and added 12% for tire diameter.
I think this needs an update lol
12-22-2020, 03:07 PM
#40
I'm not sure but I think this is after I installed the speedometer healer which corrects the speedometer which in turn corrects the odometer to compensate for the larger tires. So by manually correcting for the 12% difference I doubled up on the math.
So I think my actual numbers with 35's were:
@73mph 16.3mpg
@80mph 14.5mpg
With 37's I think its closer to 11 or 12 in town commuting.
02-26-2022, 10:43 PM
#41
Year: 2008
Tire Size: Factory limited trim 265/60R18. Michelin LT.
Gear Ratio if you know it: stock
2WD, 4WD or AWD: AWD - Full time 4WD
Modifications that affect MPG: Hood deflector
Current highway fuel economy: 15 MPG
V6 or V8: V8
Average speed you travel: 74 MPH
Anything else you want to add: I could probably get 18 MPG if I went 65.
02-27-2022, 07:36 AM
#42
Year: 2007
Tire Size: 265/65 17
Gear Ratio if you know it: Standard
2WD, 4WD or AWD: 4WD that I leave in 2WD
Modifications that affect MPG: Roof rack with site stepladders, always full of tools
Current highway fuel economy: 19.2 US Gallon 23.1 Imperial gallon
V6 or V8: V6
Average speed you travel: Unknown, cruise at about 60mph on long journeys but often accelerate hard. D
Anything else you want to add: I always use super unleaded 98+ RON. Equivalent to your 93 Pump I think. They have crappy 10% ethanol standard fuel here now.
2008 2.7 2WD 4 speed (Tacoma-Runner?)
02-27-2022, 10:13 PM
#43
Stock 2006 V8 Limited on factory 18 inch rims. Blizzaks in the winter. Kumhos the rest of the year.
16 mpg city/highway mix but mostly gentle highway cruise. Calculated on the trip computer and actual calculation of fuel used and distance traveled.
Occasionally 17 - 18 mpg if I don't drive too much stop/go.
Using the smaller US liters (3.78) to one gallon conversion. The Limited V8 is awd all the the time. About $75 USD to fill up every 2.5 weeks. Not bad for the vehicle that is this capable.
02-28-2022, 02:33 AM
#44
Originally Posted by meltdowner
Tire Size: Standard
Gear Ratio if you know it: Don't know
Modifications that affect MPG: Greasing zerks, air filter and oil change
Current highway fuel economy: EDIT: 19MPG after more mileage
V6 or V8: v8
Anything else you want to add: I drive like a grandmother.
I was at 22 but as soon as I stopped at some lights and what not, the mileage dropped fast.
19mpg? Dang man! Good on you!! Thats awesome.
02-28-2022, 02:53 AM
#45
Year: 2006
Tire Size: 285/70R17 (Randos that were on when I bought it)
Gear Ratio if you know it: Don't know. Standard
2WD, 4WD or AWD: AWD?
Modifications that affect MPG: Small rack behind sunroof. Has a spacer lift.
Current highway fuel economy: Anywhere from 13-15mpg
V6 or V8: V8
Average speed you travel: 65-75 on the highway.
Anything else you want to add: I feel like I am getting worse mpg than others. I am slowly going through the truck and changing everything out. Fluids are being done next. So far the brake fluid and power steering fluid were black from the PO.
My ultra gauge says the average is 14.6mpg, but I forgot to reset it before I went on a trip this weekend. LCD screen says around 15.7.
