11-19-2018, 09:11 PM
Lca options.
Looks like my lower ball joints are going out 149k miles is a good run. Looking for options gonna go ahead and replace both lca's not interested in rebuilding. Looking for opinions on aftermarket and where to get the best prices on oem. Any companies that sell them with urethane bushings and unreadable jonts? Thanks in advance
Dusty
[SIGPIC[/SIGPIC]03 V8 limited
Front 5100 toytec 620# springs jba uca
Rear 5160 with sway away springs. Rci skid. Spc rear trailing arms
Diff drop 285/70/17 k02 n 17x9 ar172
11-19-2018, 09:25 PM
Real Name: Caleb
Real Name: Caleb
I replaced my passenger side LCA with a 1A Auto control arm. The price was great and quality is very good. I have about 10K miles on it including a trip thru Colorado and Moab, Utah with zero issues. I also replaced the hardware with SPC bolts.
2006 T4R Sport 4x4 V8 My Build
1.5 AllPro wheel spacers, Bilstein 5100's with OME 886's with 1/4" Toytec spacers, OME 2896 rear coils, SPC UCA's, LT285/70-17 BFgoodrich KO2's on 2016 wheels, ARB on-board air system, LFD Off Road Skid Plate, DV8 Offroad Tacoma steel bumper with Smittybilt XRC Winch, PIAA 530 Fog Lights, Diff Breather Mod, Limited grille, CBI ditch light brackets and light pods, ARB awning, Wilco Offroad Tiregate,Full size spare tire, RCI Rock Sliders, HCF delete, Smokers kit, Interior LED swap, Map light mod, Pionner AVH-X391BHS HU, Tentbox RTT, Cobra CB, Flowmaster exhaust
11-20-2018, 09:14 AM
Originally Posted by blackoutt
Thanks for the links. Yeah the Sig pic cam out huge. Not sure if im keeping it.
05-04-2020, 12:00 PM
I was warned. This is the boot on a six month old LCA from NAPA.
2005 V8 4Runner
1" Toytec body lift, FJ Cruiser stock springs front and rear, Bilstein 5100 front struts, 1.5" rear coil spacers, Total Chaos front UCA's, Uinta Metal Fab custom built front bumper, VHF Radio for comms
05-04-2020, 12:35 PM
Real Name: Ron
Real Name: Ron
I would go with SuperPro, Google them and check out some of their videos. You can buy from Apache Off road. I just bought their bushing kit from Apache last month.
05-04-2020, 12:48 PM
I've got some OEM arms that are ready for a rebuild I'll sell you for a reasonable price.
I'd replace the bushing and ball joint, but they're just taking up space in my garage.
'09 V8 Limited | Dobinsons Lift | Front: 3" - C59-302 + GS59-220 | Rear: 2.5" - C59-675V + GS59-701 | Tires | Ridge Grappler 275/65/18XL | Wheels | Method Standard Machined Finish 18x9 -12 offset | SPC UCAs | DT Long Tubes | GSport 2.5" Cats | DT Y-Pipe | Magnaflow Cat Back | 2.5" Vibrant Ultra Quiet Resonator
05-04-2020, 07:49 PM
I'm still on my stock bushing for both upper and lower control arms. Suspension is as good as it was when new and the truck has 270k miles on it. I will be replacing them at 300k with stock bushing because they are the best period.
05-06-2020, 04:28 PM
I have a brand new set of Moog lower control arms for sale.
Here is the link
https://www.toyota-4runner.org/3481352-post3640.html
I will have pics of my 4runner soon
05-10-2020, 04:00 PM
OEM all the way. I’m at 240k miles and no problems. I can see the bushings are getting warn but can’t tell by driving it. Only changing out since I’m upgrading the suspension and am going to have it all apart anyway. $600 seems like a lot until you see the cheap crap failing on here all the time.
05-12-2020, 03:37 PM
Just swapped my LCA's and UCA's with OEM. LCA's were new from Mcgeorge? Toyota for just over $600 shipped. Picked up 2017 UCA's with 20k on them for $100. Another $150-200 in OEM hardware. It's a firmer ride now with new bushings for sure, but feels so much better being solid and knowing all my suspension is less than 20k miles with 293,000 on the odometer. Have my originals too if someone wants a set to rebuild....
Eibach pro truck with WOR springs on 1st notch in front. 5100's in rear w/ FJ OEM takeoff coils. 255/70R18 on 18" Limited wheels. 1.5" spacers on rear(one trimmed a bit to correct lean). Gibson catback, 06+Headlamps, auxito 16K bulbs in high, low, and fogs!
08-11-2020, 01:09 PM
'08 Limited V8 Supercharged: URD // Doug Thorley // Rotora // Titanium Works // JAUS // Toytec // Bilstein // Fuel Shok // Nitto // Icon // Hefty Fabworks // RCI // CBI // Shrockworks // Baja Designs // Auxbeam // Fiberwerx // Addco
08-11-2020, 01:17 PM
Originally Posted by Satori
If, you've got the $$, they are a solid product. A buddy of mine is running long travel total chaos LCA's on his tacoma on 37's and loves em.
08-11-2020, 01:48 PM
Another option for OEM is amayama.com. They come from across the pond but for the price, might be worth the wait.
I just rebuilt mine with whiteline bushings and Moog ball joints and what a job.
Sent from my SM-G986U using Tapatalk
