Jason B
Old 11-28-2018, 11:11 PM #1
Cpt_Romania Cpt_Romania is offline
Real Name: Ruben
Cpt_Romania is on a distinguished road
Real Name: Ruben
Exclamation Installing Doug Thorley Headers on 2005 4.7L V8 w. 2" BL
Hello to you all,
I bring you all now the story of how I installed 05-09 Doug Thorley Headers on my 05 4Runner which has 2" BL, but not after I bought the 03-04s Headers and spent 3 months driving back and forth taking my headers off a grand total of 4 times before coming up with a solution!
Let us begin:
Exhaust tick started, tried to ignore it, it got much worse and I started to hate driving my 4runner. Found this Doug Thorley Header solution and I rationalized in my head that it was worth the money and that it will be the last mod I'll do ( Yeah right -_- )
After talking with Jason from Burtman Industries I learned that the 03-04 headers were "exactly" the same as the 05-09s except for not having an EGR tube and something else, which I'll mention later on.
I ordered the Headers, (2) Magnaflow catalytic converters and the 4.7L Air Induction Pump Bypass Kit and Exhaust Port Plates off of eBay, which you need for the 03-04s because they do not have an EGR tube.
So long story short, the 03-04s did NOT fit because of the 02 sensor bung placement on the headers, they were drilled into the bottom of the header making it impossible for my female end to fit, on top of the fact that the steering shaft was entirely in the way. This is the other difference I was talking about that neither myself or Burtman saw coming, guess that's what happens when your blazing a trail into uncharted waters and Doug Thorley said they will NOT sell their headers to people with Body Lifts
So I left my car at the shop as I tried brainstorming a solution ( the shop is 2 hrs away from my home by the way, so I had to get a ride back home ) and I came to the conclusion that the 05-09s would be the best solution since there were no solutions coming up for extending 02 sensor wires.
Obviously I couldn't return the 03-04 headers because they already had a pair of cats welded to them. Here is the post where I SOLD the 03-04 pair and there's more information there.
http://www.toyota-4runner.org/sale-t...-%7C-sold.html
So I got bought a set of 05-09 Headers and another set of Magnaflow Cats, had them welded up again and drove back to the shop and it still wouldn't clear the steering shaft ( we "dimpled" previously a little ) so this is where I lost my mind and took a hammer and blow torch to them until they fit
[ Also I still had the $199 4.7L Air Induction Pump Bypass Kit that you connect to your Air Intake which I didn't even "need" anymore because the 05-09 Headers come with the EGR tube so it's more of a precaution at this point in case the "computer/sensor" goes out, but I'm told it costs a lot of money to replace and if you don't your Check Engine light will stay on ) but the thing is that my check engine light will probably always be on because of one reason or another so it's just an ornament in my engine bay now ]
Also if you want to hear what the 4runner sounds like with the headers installed, check out the link below!
https://www.youtube.com/watch?v=PMwzCJZCWtM
Here come the pictures:
Installing Doug Thorley Headers on 2005 4.7L V8 w. 2" BL-img_20181118_173927-jpg  Installing Doug Thorley Headers on 2005 4.7L V8 w. 2" BL-img_20181118_173937-jpg  Installing Doug Thorley Headers on 2005 4.7L V8 w. 2" BL-img_20181118_200711-jpg  Installing Doug Thorley Headers on 2005 4.7L V8 w. 2" BL-img_20181118_200716-jpg  Installing Doug Thorley Headers on 2005 4.7L V8 w. 2" BL-img_20181118_201002-jpg  Installing Doug Thorley Headers on 2005 4.7L V8 w. 2" BL-img_20181118_214034-jpg  Installing Doug Thorley Headers on 2005 4.7L V8 w. 2" BL-img_20181119_145045-jpg  Installing Doug Thorley Headers on 2005 4.7L V8 w. 2" BL-img_20181119_145802-jpg
Cpt_Romania is offline   Reply With QuoteReply With Quote
Old 11-28-2018, 11:52 PM #2
K-D-Runner's Avatar
K-D-Runner K-D-Runner is offline
K-D-Runner will become famous soon enough
K-D-Runner's Avatar
You gotta get around to doing a build thread man, I'd love to see more of your rig!
Sent from my Pixel 3 XL using Tapatalk
K-D-Runner is offline   Reply With QuoteReply With Quote
Old 11-29-2018, 12:31 AM #3
Marfy's Avatar
Marfy Marfy is offline
Marfy will become famous soon enough Marfy will become famous soon enough
Marfy's Avatar
I have a 1.25 body lift and also have rubbing issues. I was able to grind a bit off one of the steering shaft bolts and it isn’t too bad. For what ever reason, when I reverse and turn, it rubs a little more.
Anyway, I appreciate how hard you worked to get these to fit but I have to say, seeing what you did to get them to fit makes me really sad.
[Sold] 2007 Limited - V8 4WD
Stock Rear RAS / Bilstein 5100s / OME 885 / RB 1.25 BL / BFG KO2s - 275/70R17 / SCS Ray 10 - Brushed Gold /
XenonDepot Hid Kit (lows) / Aftermarket Yellow Fogs w/ XenonDepot HIDs / DT Premium Long Tubes / Custom Y w/ 2 cats deleted / full custom exhaust pipe with magnaflow / aFe CAI / MAF Calbrator
Marfy is offline   Reply With QuoteReply With Quote
Old 11-29-2018, 08:38 AM #4
Todapwr's Avatar
Todapwr Todapwr is offline
Todapwr is on a distinguished road
Todapwr's Avatar
You beat that header like it owed you money!
2006 V8 4Runner Limited
FOX 2.5 DSC | Total Chaos | Dobinson 677V | Doug Thorley Headers & Y-pipe | Gibson | RCI Metalworks | BudBuilt | SCS Ray 10 | Wildpeaks 285/75/17 - 34s
Instagram @ TXT4R
Todapwr is offline   Reply With QuoteReply With Quote
Old 11-29-2018, 01:17 PM #5
Caldizzle's Avatar
Caldizzle Caldizzle is offline
Real Name: Calvin
Caldizzle will become famous soon enough
Caldizzle's Avatar
Real Name: Calvin
Gah that sounds so good
Caldizzle is offline   Reply With QuoteReply With Quote
Old 11-29-2018, 02:52 PM #6
Real Name: Ruben
Real Name: Ruben
Soon 😉
Old 11-29-2018, 02:53 PM #7
Real Name: Ruben
Real Name: Ruben
Don't be sad, it was worth it, who needs shiny chrome headers anyway 😁
Old 11-29-2018, 03:33 PM #8
DZNUTS DZNUTS is offline
DZNUTS will become famous soon enough
Originally Posted by Cpt_Romania View Post
Don't be sad, it was worth it, who needs shiny chrome headers anyway Installing Doug Thorley Headers on 2005 4.7L V8 w. 2" BL
More like who needs exhaust flow??? I’d throw a wide band on there to be sure your a/f ratio isn’t all jacked up
1995 ECR33 GTS-T (sold)
1990 s13 coupe TONS of work
2005 4Runner Sport V8
DZNUTS is offline   Reply With QuoteReply With Quote
Old 11-29-2018, 04:14 PM #9
HiVel-JR's Avatar
HiVel-JR HiVel-JR is offline
Real Name: Billy
HiVel-JR will become famous soon enough
HiVel-JR's Avatar
Real Name: Billy
Looks like you took 2 x fukitalls and went to work...
I will apologize for my ignorance, but why would DT make headers
that do not fit around the steering shaft...? Or is that because of your Body Lift?
I still have my DTs in the box... trying to figure out when to install them...
Plus I need someone to help me weld them together. PITA....
2005 4WD V8 SportEdition MY BUILD
ICON 2.5 resi-Stage 3, K&N CAI, Gibson Exhaust, Ash Tray Kit, Husky Cargo Liner, Husky Floor mats, Rear Diff Breather Extension, Driver side grab handles, 285/70R17 BF T/A K02, RIGID Hyper Spots in Scoop, Grill, Pillar, Rack front and back, Wilson 5000 magnetic, Stryker 490 CB Radio, Gamber Johnson Floor Mount, WILCO rear tire Carrier, Gobi Rack, StopTech Drilled and Slotted Cryo Brake Rotors, RPM Front Bumper, DT Headers (Not installed)
HiVel-JR is offline   Reply With QuoteReply With Quote
Old 11-29-2018, 04:43 PM #10
Crusifix Crusifix is offline
Crusifix will become famous soon enough Crusifix will become famous soon enough
Is this serious?
There is no way you are getting improved performance out of those. Jesus Christ man! Seriously, is this serious?
Crusifix is offline   Reply With QuoteReply With Quote
Old 11-29-2018, 05:11 PM #11
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
Originally Posted by Crusifix View Post
Is this serious?
As long as it doesn't break again like the stock manifolds do I'd say its a win. With the improved y pipe it could easily have the same performance as stock, the stock y pipe section is pretty restrictive
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 11-29-2018, 05:16 PM #12
No. First of all, now you have very uneven flow from not only one bank to the other, but you also have uneven flow from each individual primary pipe. He is completely negating what a header, or even the most basic manifold is supposed to do. I come from an automotive performance background, and from what I can tell in the photos, there is at least one header pipe with about 80% restriction, and one that isn't too much better. You have those two cylinders fighting against the free flowing cylinders now, and this will cause heavily reduced performance and efficiency. But, don't take my word for it. This thread has gone viral on other automotive sites for being a huge "WTF"?
Old 11-29-2018, 05:28 PM #13
Inv4drZm's Avatar
Inv4drZm's Avatar
No. First of all, now you have very uneven flow from not only one bank to the other, but you also have uneven flow from each individual header pipe. He is completely negating what a header, or even the most basic manifold is supposed to do. I come from an automotive performance background, and from what I can tell in the photos, there is at least one header pipe with about 80% restriction, and one that isn't too much better. You have those two cylinders fighting against the free flowing cylinders now, and this will cause heavily reduced performance and efficiency. But, don't take my word for it. This thread has gone viral on other automotive sites for being a huge "WTF"?
Don't take your word for it, take other random people's opinions on the internet too. LOL.
Its a durability mod. Its still better than the stock ones that crack.
Compared to these headers, the stock manifolds probably have a 25% restriction on each cylinder due to their diameter decrease, sharp bends, and short runners.
Old 11-29-2018, 05:29 PM #14
Looks very durable. No weak spots created at all in the tubing structure..
Old 11-29-2018, 05:32 PM #15
Seymore Butts's Avatar
Seymore Butts Seymore Butts is offline
Seymore Butts will become famous soon enough Seymore Butts will become famous soon enough
Wow, what a train wreck. Does Doug Thorley make headers that are actually compatible with the 4Runner?
Seymore Butts is offline   Reply With QuoteReply With Quote
4.7 liter v8 , doug thorley , headers , magnaflow , straight pipe
2005 4Runner 4.7L V8 with Doug Thorley Headers and Gibson Exhaust nimmo 4th Gen T4Rs 0 10-15-2018 10:18 PM
Doug Thorley Headers kraftwerkauto 4th Gen T4Rs 3 10-12-2012 11:25 AM
doug thorley headers Rc4r 3rd gen T4Rs 14 05-17-2011 11:29 AM
Doug Thorley Headers Beancounter25 Engines / Suspension / Wheels / Tires / Audio / Accessories 8 08-10-2009 08:27 PM
