Originally Posted by DZNUTS
I’m sure if you find out the resistance values for the original speed sensors, you could wire in some wheel speed sensors. At least that should take care of the speedometer and odometer. Can’t tell you if it’ll fix the lack of stability control or ATRAC, if you have it.
I hadn't thought of that, I was overcomplicating things. The stock sensors could probably be plugged back in (if you still have the factory harness) and routed back up to the body out of the way. Or like mentioned above maybe you just need the resistance values.
As for VSC and ATRAC, you don't
really need it. If you're offroading you'll want a locker, it might suck without ATRAC depending on what exactly you'll be driving over.
2005 4R Sport 4WD
"The last of the V8s!" - Custom TIG'd SS Dual Exhaust - King 2.5" +2 LT. - ARB Front & Rear - 37's - Dana 60 -
Build Thread
1977 Celica Liftback - LFX Swap -
Build Thread
