Old 12-11-2018, 01:43 PM #1
Deangraen's Avatar
Deangraen Deangraen is offline
Deangraen is on a distinguished road
Deangraen's Avatar
Rear axle swap. Need help getting speedometer to work
Hi everyone.
I am new to the forum.
I just did a ford 9 inch rear axle swap with deaver leaf springs. after doing the swap i noticed i lost the speed sensors on the axle and i now dont have a working speedometer or odometer. Anyone else run into this issue and have some answers to fix this?
Deangraen is offline   Reply With QuoteReply With Quote
Old 12-11-2018, 03:06 PM #2
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
I would be surprised if it was possible to get it to work.
The wheel speed sensors are why junkyard axle swaps aren't common, no speedometer, no stability control, no ATRAC. Custom axles can be built to keep the stock bearings/hubs from Currie, ECGS, or Diamond.
I would contact Marlin Crawler and see if they have a way of doing it. If it was possible, it would be from taking a reading from the t-case area somehow I would imagine.
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 12-11-2018, 03:44 PM #3
DZNUTS DZNUTS is offline
DZNUTS will become famous soon enough
I’m sure if you find out the resistance values for the original speed sensors, you could wire in some wheel speed sensors. At least that should take care of the speedometer and odometer. Can’t tell you if it’ll fix the lack of stability control or ATRAC, if you have it.
1995 ECR33 GTS-T (sold)
1990 s13 coupe TONS of work
2005 4Runner Sport V8
DZNUTS is offline   Reply With QuoteReply With Quote
Old 12-11-2018, 04:48 PM #4
Inv4drZm's Avatar
Inv4drZm's Avatar
I hadn't thought of that, I was overcomplicating things. The stock sensors could probably be plugged back in (if you still have the factory harness) and routed back up to the body out of the way. Or like mentioned above maybe you just need the resistance values.
As for VSC and ATRAC, you don't really need it. If you're offroading you'll want a locker, it might suck without ATRAC depending on what exactly you'll be driving over.
Old 08-27-2019, 05:29 PM #5
Deangraen's Avatar
Deangraen's Avatar
I ended up finding out how to make it work. I did an Fj T-case swap and put in a mechanical sensor with a worm gear setup and tapped it into the ECU. Works perfect. Wasnt too worried about ABS, Traction Control, or any of the fancy stuff. Im currently doing an SAS and just caged the truck. And i have a spooled rear end and detroit front locker so even if i kept all the sensors they wouldnt work right because of the spool.
Old 08-27-2019, 06:54 PM #6
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
I am amazed at what some of you guys are capable of!!
Old 08-27-2019, 07:32 PM #7
montijo505's Avatar
montijo505's Avatar
Build thread anywhere?
Old 08-28-2019, 11:17 AM #8
Deangraen's Avatar
Deangraen's Avatar
I will soon. i havent had time to post it up yet.
4th , axle swap , issue , odometer , speedometer
Questions about rear axle seals and body work toastybroski 3rd gen T4Rs 14 10-10-2018 04:42 PM
Cincinnati area rear axle seal work? Lakland5 3rd gen T4Rs 0 09-03-2018 02:18 PM
02' rear axle swap to put an elocker in. . stir_fry_boy 3rd gen T4Rs 32 05-03-2018 08:43 AM
Shop to do press work for rear axle rehab Cmayer So Cal 8 12-06-2017 11:37 PM
Rear Axle swap 99yota4 3rd gen T4Rs 7 07-27-2010 12:48 PM
