Originally Posted by U.G.N.
Thank you
@ Jcmeadows82
for this great write-up. I have several questions about the process:
1) What is the purpose of draining motor oil and leaving the engine without it? Does it relate to replacing the crankshaft front seal?
2) Was it really necessary to replace the crankshaft front seal as the FSM does not mention about it nor it comes with the Aisin TKT-021 Engine Timing Belt Kit with Water Pump I bought from Amazon? Do you need a special tool to replace that seal?
3) How did you remove the crankshaft pulley? The FSM requires usage of a SST. Did it come out by hand?
4) How did you remove the old belt? The FSM states "Using a SST, loosen the tension between the camshaft timing pulley (RH bank) and crankshaft timing pulley by turning the camshaft timing pulley
(RH bank) counterclockwise slightly."
5) Did you use a crowfoot adapter for 3/8 torque wrench to torque 2 stud bolts on the water pump?
No problem! More info out there the better!
To answer your questions:
1) I drained the oil for 2 reasons. It needed an oil change and because I was replacing the Crank Seal at the same time. I have done more like this on many cars in the past and replace the $15 seal every time because why not if it cost $15 bucks!? If I didn’t have the VVTi motor I would have done the CAM seals too but that would have been digging too deep.
2) Necessary? No. I replace seals that are easy to get to when doing major work because if that thing was to start leaking within a year of doing the job I would be kicking myself for not taking the 20 extra min to replace it. I have done jobs like this in the past and not replaced it and 1 out of 3 times I regret it greatly. So, you could totally not replace the seal if you want to just wait for it to MAYBE start leaking. Might not though
Also, no special tools needed. The seal can be pulled with a small flat head screwdriver or nice picks and installed by taping very gently around the edge of it until it sits flush. Watch a video on YouTube on the subject if you’re not sure. They are all basically the same.
3) The crankshaft pulley is installed with a B.A.B (Big A$$ bolt) that is torqued down to 4.37 jigawatts of torque (250ish pounds I believe) and so removal of the BOLT is made WAY easier with the tool I have listed in the writeup (it can be seen attached to the crankshaft in one of the pictures as well) so I recommend at least having that tool. Other than that, you need a breaker bar, and a socket wrench with a long tube over the handle or way to extend it to produce the leverage required to break the bolt free. As far as the pulley, it can be stuck to the crankshaft well, or it can slide nicely off. A pulley removal kit (not the Jaw style) is your friend here and you can usually rent or borrow one from your local hardware store. Watch the videos I posted, and you can get a better idea of what it takes to remove the pulley.
4) So, with the timing belt, when you have set the pulleys to the correct markings there is spring tension on the cams as you have basically just set one of the lobes pressing down on a set of valves. When you loosen the belt the cam shaft that is under tension will move about a tooth. Having the tool will allow you to unload that pressure slowly... not sure how big of a deal it is for the spring to push the cam suddenly when you remove the belt... maybe someone on here can chime in as I just yolo'ed it and let the tension off by pulling the belt?
4.5) Putting it back on was the tricky part as I needed to turn the cam and put the tension back into the system to get the notches to match up. This part of the job is a bit foggy and so maybe someone with a couple of these jobs under their belt could chime in.
5) Nope. I got them in the ballpark by setting a torque wrench to the specified torque, torqueing something, then replicating roughly the same pressure on the same length wrench. Not a huge deal, but a crowfoot would be nice.
Hope I have answers some of your questions. YouTube and forums like this are your best friend! good luck to you!
