Old 12-31-2018, 10:34 PM #1
Quiero Quiero is offline
Quiero is on a distinguished road
Rear door window exterior rubber (Not rear hatch) replacement?
Please excuse me as I did a search but nearly everything refers to the rear hatch/lift gate.
My 07's passenger and driver side rear door exterior rubber weather stripping has dry rotted and failed. They dont leak water inside, but I'm worried about them leaking in to the door. These are the "scrapers" on the two rear doors.
Does anyone have a part number for these, and how difficult are they to replace?
Thank you
Quiero is offline   Reply With QuoteReply With Quote
Old 12-31-2018, 10:48 PM #2
Seems I was using the wrong search terms. Incase anyone comes across this post, this one is helpful: help - weather stripping
Old 12-31-2018, 11:19 PM #3
Primetime4370's Avatar
Primetime4370 Primetime4370 is offline
Primetime4370 will become famous soon enough
Looks like 68163/68164. Check Here. This is for an '05 so, you might want to double check for your year. Also, try checking Amazon once you have the part number.
Primetime4370 is offline   Reply With QuoteReply With Quote
Old 01-01-2019, 07:38 AM #4
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Thank you
Just an FYI, these outer bottom window weather strips aren't design to totally keep water out of the door, they're designed to keep debri out and to sorta clean the window, they do however keep the majority of water from getting in the door, but water will still get in the door/s, all of the doors and hatch have drain holes in the bottom, there's a plastic insert in each hole that allows water to drain but keep bugs, small critters from entering, these drains need to be check from time to time to make sure they haven't clogged and not allowing water to drain out, they can be cleaned but if you have to clean them you most likely have debri in your door/s that also needs to be cleaned out so the drains don't clog again.
2004 Limited V8
Intermittent rear hatch lock and rear window. jillianj 4th Gen T4Rs 2 04-20-2018 07:03 PM
Defective Side Door Window Rubber - exterior EEEliminator 5th gen T4Rs 11 03-01-2018 11:12 PM
Rear Door / Rear Hatch Speaker Adapters ForeRunnerSi 5th gen T4Rs 5 02-21-2018 08:49 AM
Right rear window reg. & rubber channel replacement 77'911 Classic T4Rs 0 05-18-2012 05:37 PM
Disassembling Rear Hatch -> Stuck Rear Window MunkeyTX 3rd gen T4Rs 1 09-02-2008 10:48 PM
