Old 01-03-2019, 06:52 PM #1
almus almus is offline
almus is on a distinguished road
04 v6 Car inspection set vsc light
I have a 2004 v6 about 150k miles.
No codes present
Went in for NH inspection. Shop claims that they
couldn't connect or read obd computer
with the NH state code reader.
I note that now the VSC trac and VSC off lights are blinking.
I cycle power. VSC trac and VSC off lights go off but then come
back on in about 1/4 mile. Now they are on continuously.
(no CEL )
I bring car to dealer. They say that they cannot reset the yaw sensor.
They say I need at least a Yaw sensor but they are not sure what else is wrong. >700.00$
And all I needed was an inspection
The only thing that has happened strange is battery died on car (left light on)
recently.
Any ideas???
almus is offline   Reply With QuoteReply With Quote
Old 01-03-2019, 06:56 PM #2
lightfreak lightfreak is offline
lightfreak will become famous soon enough lightfreak will become famous soon enough
You need to do a zero point calibration. There’s a detailed thread on here about it.
2004 4Runner Limited V6 4WD ***SOLD***
385,000 Km
Titanium Metallic
Vehicles: '21 Highlander XSE V6 AWD | '21 Acura RDX SH-AWD Tech | '03 Honda CBR600F4i
lightfreak is offline   Reply With QuoteReply With Quote
Old 01-03-2019, 07:31 PM #3
Dealer did this 3x times and it keeps coming back.
I am familiar with the procedure as I have done it as well
I am just puzzled why code reader at first garage seems to have messed up everything
Old 01-06-2019, 07:44 PM #4
wiring diagram between obd and ECM??
OK. The dealer cannot find the issue now I am regretting leaving it
with them over the weekend.
Does anyone have a wiring diagram that shows connections between
(2004) 4runner OBD port and ECM (aka ECU) ?
I was able to connect to OBD with my cheapie OBD reader, but the dealer
is not able to reset/recalibrate the yaw sensor and he is not able to connect
to OBD for NH inspection. Dealer did however replace the yaw sensor
at a cost of 700 which is fkg outrageous!!
I asked for my old yaw sensor which I am damn sure is fine and I will
swap it back in and check when (and if) this issue is resolved.
Having said all this---Anyone recommend a indy toyota mechanic in
south east NH ??
Thanks
Old 01-06-2019, 07:53 PM #5
TenTwelve's Avatar
TenTwelve TenTwelve is offline
Real Name: Eric
TenTwelve will become famous soon enough
TenTwelve's Avatar
Real Name: Eric
If they couldn't read check the fuses. My techs were trying to program my new key/fob and he wasn't getting any communications. Found a blown fuse.
2007 4.7 Limited - Let the fun begin!
TenTwelve is offline   Reply With QuoteReply With Quote
Old 01-06-2019, 08:25 PM #6
I checked the fuse... It is OK
Old 01-06-2019, 08:42 PM #7
Supersonic Supersonic is offline
Supersonic is on a distinguished road
one thing you can try is to put a Brake Light Stoplamp Switch in, 84340-47020 that should be the OEM part number and then you could go look for the Part on Amazon, eBay, Nearby parts store. That's what was wrong with mine kept the lights on with the brake light switch was replaced in the lights went out.
Supersonic is offline   Reply With QuoteReply With Quote
Old 01-13-2019, 12:29 PM #8
Follow up to close thread
Dealer found that the OBD port pins were not connecting.
They repaired the pins---not sure if the pins were "pushed in"
and as such, were not making contact
Of course the dealer still charged me 700 for the yaw sensor R&R
even though I bet you dollars to donuts old one was fine.
NH just (last year?) made abs functionality a requirement for
inspection, so according to Toyota, the VSC system had to be operable
Thanks to forum for help and comments
Old 01-14-2019, 11:03 AM #9
Quiero Quiero is offline
Quiero is on a distinguished road
That sucks OP.
I've wanted to move to NH for a long time but the entire concept of a vehicle inspection just seems so wrong to me. FREEDOM!!
Did you authorize the yaw sensor replacement? Unless you gave them the go ahead you are 100% not responsible for that.
Quiero is offline   Reply With QuoteReply With Quote
Old 01-19-2019, 09:37 AM #10
Originally Posted by Quiero View Post
That sucks OP.
Most people don't realize that NH ("live free or die") is really strict on
all kinds of auto' inspections---stricter than MA, which has a reputation for being a nanny state. But at least in NH I can get cheap booze, fireworks and the firearm laws are more reasonable.
As for the yaw sensor---they told me the old one was bad,
so I OK'd the replacement. But I am pretty sure that the issue was
the OBD port.
Old 01-19-2019, 12:12 PM #11
simple's Avatar
simple simple is offline
simple will become famous soon enough
simple's Avatar
My yaw sensor just went bad, it couldn't hold calibration. I just replaced mine for 30 bucks. I got a used one on ebay, and just got an alert the other day that the price dropped to 20. I'm really sorry man... its atrocious that the dealer charges that. But, I've seen as high as 1200 for that.
Air 4rceRunner One, 04 Sr5
simple is offline   Reply With QuoteReply With Quote
car , inspection , sensor , trac , vsc
Behind the grill light bar - VA state inspection compliant gdvan01 5th gen T4Rs 11 04-01-2018 01:37 PM
Ugh.....Failed Inspection crash813 Classic T4Rs 6 10-07-2014 04:24 AM
VA Inspection question vabluefish Maryland / Virginia / WV / D.C. 4 10-19-2012 08:58 PM
NC Inspection: check engine light/engine too lean footracer 3rd gen T4Rs 5 09-10-2009 06:39 PM
