06-30-2022, 03:24 PM
Real Name: brian
Real Name: brian
Very weird rear side marker issue.
Just bought a few months ago an 08 4runner v8. Come to find out I got screwed by the dealer. Had great repair history from a toyota dealer but for some reason it was having batteries changed about every 3 months. This vehicle did sit for long periods so I thought that was the issue ( 116000 miles in 15 years, 3000 in the last 4 years ). My GF looked out the window the other night and it looked like the rear side markers were on. I attributed that to the outside lights on the garage reflecting on them. I went out today and thet WERE lit, dimly but lit on both sides. Only the rear side markers. This vehicle had alot of rodent damage before I got it that was repaired with new harnesses from toyota. I traced all the wiring and no other damage.
Any ideas? Anyone ever had this issue?
'08 4Runner Limited V8 Shadow Mica: Sport hood, bilstein 6112's, 5160's, b12 coils, Gibson cat back, 4runner XSP rims, Michelin X LT AS 275/55-20
'06 4Runner Limited V8 Salsa Red: bilstein 6112, 5160, Wheeler T12's, 4Runner XP wheels, Michelin AT2 275/55/20, Magnaflow Exhaust,, Powerstop brakes, sport hood
RIP.....'08 4Runner Limited V6: white, bilstein 6112s, 5160s, b12 , powerstop brakes, nav, TRD cat back, 4Runner XP rims, Michelin Defender LTX 275/55-20, sport hood
06-30-2022, 05:25 PM
Real Name: brian
Real Name: brian
UPDATE:
the lights stay on when vehicle is off. When the key is turned on they go off.
06-30-2022, 05:36 PM
Originally Posted by inscarguy
UPDATE:
I don't think mine has them. Are they LED or filament lamps? Sounds like a dodgy earth somewhere is meaning they're getting used as an earth path.
2008 2.7 2WD 4 speed (Tacoma-Runner?)
06-30-2022, 07:20 PM
Real Name: brian
Real Name: brian
They are led.
07-01-2022, 07:30 AM
They are led.
I doubt a couple of LEDs that are on only dimly would drain your battery...best bet now is to get a multimeter with an amps and milliamps setting, and starting at the fusebox try and identify where the current is going on a fuse by fuse basis. The probes/leads of the meter need to be 'in line' for this test, unlike volts where you can measure without disconnecting anything.
07-01-2022, 07:57 AM
omg, have you seen my thread? maybe different but similar. been having bizarre issues for over a year.
07-01-2022, 05:00 PM
Real Name: brian
Real Name: brian
UPDATE:
found the issue. It ended up being a bad ground on the remote starter/alarm system. There were 3 grounds tied together but the mounting location was poor. It looks like it broke in the past and someone prior to me relocated it to another spot. I made a new spot and the lights went off and BONUS, I now have a working remote starter.
07-01-2022, 05:12 PM
i don't have an alarm system
