01-06-2019, 02:39 PM
Front caliper issues
i've read on this forum that the 4th gen 4runner can have caliper issues. my 2007 has the original rears at 203k miles, but the fronts were replaced at 160k. the independent shop installed a pair from A1 Cardone. they come with a three year warranty.
the right one started failing at 25k miles. the left one started failing at 38k miles. both were replaced with additional labor charge (something i learned to pay attention to is even though the part has a warranty, the labor may repeat again and again).
now, at about 20k miles the warrantied right caliper is showing signs of failure. it is going in for inspection and i presume replacement. i already told the shop that i don't want to pay again for labor.
i seem to be in a bad replacement loop with these front calipers. i don't know if these reman calipers (in Mexico) are the problem. i've read of people having issues with toyota calipers.
are there special issues affecting the front caliper locations?
01-06-2019, 03:10 PM
Real Name: Roddy
Real Name: Roddy
How are they failing? Are they all doing the same thing, either locking up or leaking? You might consider a second opinion unless it's an obvious issue. I live down south and I'm running all four original calipers at 280k miles. I'm sure the region they're in plays some sort of role in service life.
'03 Limited V8 Toytec Ultimate 3/2.5" General Grabber ATx LT275/70 R17 Rear Grizzley locker
01-06-2019, 06:44 PM
i'm assuming the pistons are failing. each time they stop fully releasing, resulting in grabbing, pad dust and heat. owned since new, in the same location, so strange that the factory calipers went to 160k, and now issues. brake fluid changed each time.
01-06-2019, 08:31 PM
Search for "frozen calipers" and "5th gen calipers" to get yourself started. In short, if you do not upgrade your calipers to 5th gen ones you will have this problem indefinatelly
2004 4Runner Limited V8 4WD
Toytec Ultimate 3" (X-REAS & RAS - delete). LS460 + STi retrofit, Switchback Halos, LEDs in/out, Fog light mod.
CBI front bumper. 285/70/17 Duratracs.
JVC KW-V50BT with Hertz HCP4D & Hertz HCP1D, Hertz ESK-165 components and JL 10TW3 in custom stealth enclosure. Backup camera and steering wheel controls.
01-06-2019, 09:49 PM
why did the factory calipers go 160k miles, and replacements 20k-40k?
01-06-2019, 10:19 PM
Real Name: Skip
Real Name: Skip
I would say because they were OEM and brand new, instead if rebuilt or aftermarket calipers!
Very seldom will you find rebuilt or aftermarket anything that will last as long as the original OEM parts.IMHO
2004 Limited V8
01-06-2019, 10:54 PM
initially i was thinking that as well. however, in searching for insight, i read often of others running into this issue with toyota replacements as well. i called toyota parts, and they said that the dealer replacement calipers for the 4runner are not reman, but all new and made in california.
01-06-2019, 11:24 PM
Real Name: Skip
Real Name: Skip
BUT are they really OEM, as in are they the same as what came on the truck from Japan, I doubt it and it may not be possible to get exact replacements of the same quailty as what was installed orginally in Japan, unless you can get some that are still made in Japan??
2004 Limited V8
01-06-2019, 11:32 PM
i would have to assume that they would be equal to originals (just because the vehicle was assembled in japan, doesn't mean every part was made there).
01-07-2019, 12:02 AM
Real Name: Skip
Real Name: Skip
uh, OK if that's what you think/assume, but I disagree, Toyota isn't going to import parts from the USA to build their vehicles in Japan.IMHO
2004 Limited V8
01-07-2019, 09:57 AM
not impossible. toyota builds a lot of vehicles here in the USA. that includes the tacoma, tundra, sequoia, and highlander. i have no idea where all the parts are manufactured, but i assume many are domestic. no reason why calipers can't be made here and shipped to japan.
01-07-2019, 10:31 AM
front calipers on mine ave been an onging problem. the first time i went to replace mine my coworker (parts manager) told me to go with oreileys only because they have a lifetime warranty and he could only do 12mo warranty on OEM. went with oreiley (at about 120k) and ive done my passenger side twice (now at 191k). luckily its not that hard to do them with a speed bleeder and a clamp. if you do go the oreileys route, be sure to check your casting number on the caliper depending on the trim of your truck to make sur eyou have the right replacement.
01-07-2019, 04:37 PM
just got to back with replacement caliper. of course working fine now. will talk to shop about future warranty issue procedure. no labor cost this time. if i ever need to do a full front replacement, i will probably go back to toyota parts ($650 for calipers/rotors/pads).
01-08-2019, 03:43 PM
im surprised they didn't charge labor. its not the shops fault that the calipers failed. this is something we deal with quite frequently. very seldom will the parts supplier pay on a labor claim. SOMEONE has to pay the labor.
that does seem like fairly low miles for them to be seizing though. people say that the 5th gen calipers are better, but I don't see how. I believe the problem to be water in the system that settles in the calipers. maybe having the fluid flushed once a year would help extend the life.
I know that on this site, this is a "common" problem. but I own a brake shop, and other than my own personal vehicle, I have not ran into this issue. in fact, I rarely get one of these in for a brake job at all.
1985 pickup : EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5 : 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited : stock. Build Thread YouTube Channel
01-08-2019, 08:25 PM
i've been going to this independent shop for a long time. they made a good profit on the first set of calipers ($95 retail, $140 ea for me; why i normally source my own parts). they also, in my opinion, charged a lot for the two previous warranty replacements ($160 for a single caliper swap; typically full front labor is about $160).
i told them i thought i shouldn't have to pay for labor a fourth time (original plus two warranties). they agreed, and added a new brake hose (replaced last time)
to eliminate that possibility.
