Originally Posted by TenTwelve
Could they have been wired incorrectly? Unlike incandescent bulbs LEDs are polarity specific.
Originally Posted by AuSeeker
This is my thoughts as well, you could try and see if you can just pull the bulbs and turn them 180* if the socket allows for that and if the wiring is reversed that should make them work.
Originally Posted by Ed_C
Sounds like you wired the resistors correctly.
I agree polarity could be reversed. Even though common sense dictates the black wire from your new turn signals should be ground (OEM white w/black wire is definitely ground) I'd switch them around.
It's happened to me before, same brand aftermarket bulb sockets but for different bulbs. I assumed the wire colors were the same, ended up ruining a LED bulb because what should have been a ground wire was not, two positives connected to a LED bulb = burnt out LEDs
Update: the wiring on the new signals was, indeed, reversed. Rewired with white to white/black, black to green, and everything is working now.
Many thanks to y'all for the assistance!
