Old 01-07-2019, 01:01 AM #1
Whaler17 Whaler17 is offline
Whaler17 is on a distinguished road
front wiper chattering noise
On my 2003 Limited, the front wiper on the passenger side make a chattering noise on most upstrokes. If there's enough rain, it wipes smoothly.
I'm thinking the first thing I should do is replace the blades because maybe they're old & hard.
Any other ideas?
Is it best to replace the arms and the blades together?
Thanks....
Whaler17 is offline   Reply With QuoteReply With Quote
Old 01-07-2019, 04:53 AM #2
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
new blades and a clean windshield , also add some rain x or another brand of water repellent.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
Old 01-08-2019, 03:45 PM #3
nevada's Avatar
nevada nevada is offline
nevada has a spectacular aura about nevada has a spectacular aura about nevada has a spectacular aura about
nevada's Avatar
Any other ideas?
Thanks....
use a crescent wrench, and twist the arm slightly. new blades may work for a while, or maybe not at all. twisting the arm should help with the blades you have. assuming they are in fact still in good shape, and wipe cleanly. if not, change them AND twist the arm.
1985 pickup: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited: stock. Build Thread YouTube Channel
nevada is offline   Reply With QuoteReply With Quote
Old 01-08-2019, 04:41 PM #4
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
Yeah, sometimes I get that too… pretty annoying.
It’s a consumable, they are not really meant to least. I usually just throw a new set of blades on it. I usually change them in the beginning of every rainy season at a minimum. Most I’ve tried don’t last, they tend to get beat up during the summer months.
Only word of advice is don’t shop at the bottom of the barrel for blades, I usually buy mid-tier stuff from Rock Auto and avoid top of the line stuff because I didn’t see the value. I find its better to change it more often anyways… as often as twice a year if I feel the need, or before a long road trip or something.
Old 01-08-2019, 07:21 PM #5
nuron nuron is offline
nuron is on a distinguished road
I usually apply RainX but find that it wears off too quick. Think I'll switch to Aquapel next season--more expensive, but people have said it lasts much longer and the wiper blades barely wear down.
nuron is offline   Reply With QuoteReply With Quote
Old 01-08-2019, 08:07 PM #6
CookieRoe's Avatar
CookieRoe CookieRoe is offline
Real Name: Ed
CookieRoe is a jewel in the rough CookieRoe is a jewel in the rough CookieRoe is a jewel in the rough
CookieRoe's Avatar
Real Name: Ed
Dealt with this for years. Tried everything. EVERYTHING.
Went with PIAA silicon wipers. $25 each on amazon. Expensive. Worth EVERY penny.
I've had them on for a few years now. Chatter is gone. It occasionally skips (visually), but no noise!! I'm very happy with them.
Get them.
Do it.
Thank me later.
Peace.
CookieRoe is offline   Reply With QuoteReply With Quote
Old 01-08-2019, 08:27 PM #7
Bumbo's Avatar
Bumbo's Avatar
I’ve never tried any windshield treatments or coatings… does it make a very noticeable difference?
Old 01-08-2019, 08:39 PM #8
nevada's Avatar
nevada's Avatar
rain-X makes a big difference. its almost like a lubricant.
Old 01-09-2019, 12:47 AM #9
matt922 matt922 is offline
matt922 is on a distinguished road
Get them.
Do it.
Thank me later.
Peace.
Buy these and never look back. They work better and they last much longer than regular rubber blades.
Galactic 07 v8 limited 4wd - 5100s @ 1.75, moog FJ fronts, toytec rear coils, 265/65/18 AT3
matt922 is offline   Reply With QuoteReply With Quote
Old 01-09-2019, 10:34 AM #10
Sarge Sarge is offline
Sarge is on a distinguished road
Over time, nearly every vehicle I've ever had will bend the wiper arms in one direction or another and cause chattering. Some will do it on the Park cycle, others do it on the upstroke from debris or snow/ice for us in those regions. The wiper blades are intended to wipe with the arm at a 90* angle to the glass - if they are not 90* they will chatter eventually, regardless of coatings or blade choice. Yes, premium beam type blades made of modern materials will operate smoother, but eventually will wear out faster if those arms aren't square to the glass. If you want them to last, carefully adjust the arms so they sit 90* to the glass and use at least a decent quality blade.
I've had the best track record with the Bosch Icon beam type and they seem to last far longer despite the nasty places I work. Rain-X or other coatings do make a big difference in clarity as well.
Sarge
2003 4Runner Limited V8
Sarge is offline   Reply With QuoteReply With Quote
Old 01-09-2019, 10:46 AM #11
catrains catrains is offline
catrains will become famous soon enough catrains will become famous soon enough
time to replace the blades .
short term fix spray silicone on a cloth and then wipe down the blade rubber .. that will fit it short term .. if so then get some new blades.
I keep a set of blades in my vehicle reason is I had a blade rubber break off .. not good when the windshield gets scratched .. happens when icy weather hits..
catrains is offline   Reply With QuoteReply With Quote
Old 01-11-2019, 09:17 AM #12
Auditechnician Auditechnician is offline
Auditechnician is on a distinguished road
This 🔼
YouTube
I recommend using 2 wrenches and counterholding with the one closer to the pivot point
Auditechnician is offline   Reply With QuoteReply With Quote
Old 01-11-2019, 12:47 PM #13
Originally Posted by Auditechnician View Post
This 🔼
YouTube
An excellent point and sorry I forgot to mention to use 2 tools to hold onto the arm - otherwise you can pretty easily break off the cowl shaft or at least bend it and render the whole thing junk. It is really common to see bent arms these days - they are not made of heavy enough material for the size of the much larger wipers and windshields on today's vehicles. My Dodge pickup runs 22" blades and I've had to tweak both arms on it already - at only 50K on the clock.
Sarge
Old 12-03-2019, 04:22 PM #14
BR06run BR06run is offline
Real Name: Bill R.
BR06run is on a distinguished road
Real Name: Bill R.
Clean the windshield the best you can and then put a coat of car wax on it. I use MEGUIARS GOLD CLASS on mine. You can't even hear the wipers,they wipe the water off better and the windshield is the clearest it has ever been.
BR06run is offline   Reply With QuoteReply With Quote
chattering , front , noise , replace , wiper
Chattering AC Clutch jorge's98limited Classic T4Rs 1 12-26-2014 09:45 PM
front end making chattering noise caddyhack Classic T4Rs 10 03-28-2010 06:30 PM
front end making chattering noise caddyhack 3rd gen T4Rs 5 03-05-2010 04:26 PM
engine chattering noise please help yahthis1 Classic T4Rs 12 10-02-2009 09:54 AM
Chattering when cold the_dingman Classic T4Rs 6 08-28-2009 11:26 AM
