Old 07-18-2019, 04:42 PM #1
slalomnut slalomnut is offline
slalomnut is on a distinguished road
4th gen dual battery tray??
I've searched high and low to no avail. Everything I've found has been for a 3rd or 5th gen. Anyone know of a dual battery tray to replace the stock one?
Thanks!
slalomnut is offline   Reply With QuoteReply With Quote
Old 07-18-2019, 04:48 PM #2
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
I did this write up a while ago... it might help
Toyota 4Runner Forum - Largest 4Runner Forum - View Single Post - Questions: Dual Bat setup and Power Distribution block from Shrock
I used the Dirty Parts tray (says FJ Cruiser but it works just the same). It did not replace the tray in the stock location which can hold 2 if that is what you were asking about.
I've been thinking of removing this setup and selling the entire thing here, but I haven't got around to it yet. I am making a lithium setup which will be installed inside the cab.
Old 07-18-2019, 05:55 PM #3
Nice setup! Thanks. I'm really hoping to find a dual tray for the existing battery location to maximize space utilization and lower cost of cabling.
Old 07-18-2019, 06:27 PM #4
Bumbo's Avatar
Bumbo's Avatar
You ever consider just making something a little more custom?
Making a DIY tray and two smaller batteries is anther option to consider.
Nothing stops you from using a smaller battery and a DC-DC charger which is far easier to mount.
This is a nice option not a lot of people know about. Perfect for smaller fridge projects.
West Mountain Radio - Super PWRgate PG40S
Odyssey PC680 Battery
https://www.amazon.com/Odyssey-Batte...28-spons&psc=1
You can also consider using cheaper and smaller APC batteries which are designed for a UPS.
Uses alternator when the car is running.
Charges 2nd battery when car is running with 10a charger.
Switches over to 2nd when car is not running.
Old 07-21-2019, 04:19 PM #5
tellurunner's Avatar
tellurunner tellurunner is offline
tellurunner is on a distinguished road
Thanks!
Call Matt @ Off Grid Engineering in Longmont. He is extremely knowledgable and can walk you thru your options. I did the second battery on the passenger side and it turned out great.
'07 Sport
Build Thread
tellurunner is offline   Reply With QuoteReply With Quote
Old 07-23-2019, 02:44 PM #6
Thanks! I'll check them out.
Old 07-24-2019, 01:05 AM #7
Dirtrider216 Dirtrider216 is offline
Dirtrider216 will become famous soon enough
2003-2009 4Runner Complete Dual Battery System – Off-Grid Engineering
Off grid engineering makes an awesome complete dual battery setup but it’s definitely pricey. Can’t comment on quality- I came across their products through an Instagram add but the stuff definitely looks nice
2006 limited v8 4wd
Toytec/ebiach 3” coilover lift with 1/2” top plate spacers, Jba high caster UCA’s, blistein 5100 rear shocks with toytec superflex hd springs, Cooper st max 255/80/17 with mb 352 in 17x9 -12 mm offset, auxbeam light bar in front bumper, custom retrofit headlights, SS brake lines, 5th gen brakes, custom rear storage box
Dirtrider216 is offline   Reply With QuoteReply With Quote
Old 07-24-2019, 02:43 PM #8
blackoutt's Avatar
blackoutt blackoutt is offline
blackoutt has a spectacular aura about blackoutt has a spectacular aura about
blackoutt's Avatar
I used the off grid tray and built my own dual battery setup cause I wanted a cheaper relay.
https://www.toyota-4runner.org/3255206-post10.html
blackoutt is offline   Reply With QuoteReply With Quote
Old 07-24-2019, 05:51 PM #9
From having my own OGE setup as well as knowing a handful others with their products, I can definitely say it is top notch
'07 Sport
Build Thread
Old 07-24-2019, 11:57 PM #10
traildog's Avatar
traildog traildog is offline
Real Name: George
traildog is on a distinguished road
traildog's Avatar
Real Name: George
If space maximization is your biggest concerning then the front right corner can fit a Group 34 with relocation of the power steering reservoir.
View this post on Instagram
Dual battery setup
A post shared by [email protected] (@4rnrdog) on
traildog is offline   Reply With QuoteReply With Quote
Old 07-25-2019, 12:58 PM #11
shmabs shmabs is offline
shmabs is on a distinguished road
[QUOTE=traildog;snip[/QUOTE]
Do you have any other pictures of how you relocated your reservoir and mounted the battery? This is nearly exactly what I would like to do.
I spent some time the other night unbolting things and moving them around in preparation for a second battery and mounting my ARB compressor, so I am very curious to see more details in what you have going on.
I just followed you on instagram, I'm @garagegremlin
Thanks!
shmabs is offline   Reply With QuoteReply With Quote
Old 07-25-2019, 01:52 PM #12
techno's Avatar
techno techno is offline
techno is a jewel in the rough techno is a jewel in the rough techno is a jewel in the rough
techno's Avatar
I'm in the process of getting a Prado dual battery tray from Piranha Offroad in Australia. It locates the second battery behind the passenger side headlight. I'll let you know how it works out.
techno is offline   Reply With QuoteReply With Quote
Old 07-25-2019, 03:08 PM #13
blackoutt's Avatar
blackoutt's Avatar
I guess it also depends on v6 vs v8.
If v8 here's how I did arb twin compressor up front with second battery (heavier of the two things) at the stronger part of the inner fender.
Old 07-27-2019, 09:08 AM #14
How was mounting the extra battery tray? It looks like Off-Grid Engineering's.
Old 07-29-2019, 07:57 AM #15
blackoutt's Avatar
blackoutt's Avatar
Yes it is OGE. It was very easy. The parts were nice fit well. It was expensive but I suppose worth it for what you get. Haven't had to worry about it at all since install many miles ago.
4th , battery , dual , gen , tray
Who makes the dual battery tray for v6? Seymore Butts 4th Gen T4Rs 5 01-12-2021 09:49 PM
Advise on Dual Battery Tray supermike 3rd gen T4Rs 19 01-12-2020 07:20 AM
FS 4th Gen/FJ Dual Battery Tray $150 Seattle,WA Trabs00 For Sale: T4R Items 0 01-31-2016 01:34 AM
Tacoma dual battery tray- will it fit in a t4r? nytefog 4th Gen T4Rs 0 08-26-2014 03:13 PM
FS: 5th Gen ABR Dual Battery Tray $200 Portland OR frosty_1 For Sale: T4R Items 5 08-06-2013 09:50 PM
