Old 01-10-2019, 11:52 AM #16
Terminator03 Terminator03 is offline
Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough
Originally Posted by TenTwelve View Post
The center console armrest does not cover that bank switches at all. they are wide open right behind the shifter. A shirt cable will allow you to place your phone in the pocket below the HVAC controls.
I actually meant the part of the console cover that folds out. Some here refer to it as a “burger tray”. I generally fold that out and put my phone on it while driving, and using a nav app, or when it’s plugged into the power port for charging. I use the pocket behind that row of switches for my Oakleys. When the burger tray is folded down, it appears to me that it might be difficult, or interfere with a USB cable in the position next to the DAC switch.
2004 black SR5 V8 4WD with TRD dual exhaust, Thorley headers, AFE dry filter, Sprint Booster, Icon 2.0 rear shocks, OME 895E springs, Fuel wheels with 265/70/17 Wildpeak AT3W tires, more to come...
Terminator03 is offline   Reply With QuoteReply With Quote
Old 01-10-2019, 11:56 AM #17
TenTwelve's Avatar
TenTwelve TenTwelve is offline
Real Name: Eric
TenTwelve will become famous soon enough
TenTwelve's Avatar
Real Name: Eric
Ahhhh... Gotcha. Yes, still plenty of space to keep the USB cable plugged in
2007 4.7 Limited - Let the fun begin!
TenTwelve is offline   Reply With QuoteReply With Quote
Old 01-10-2019, 02:34 PM #18
Perfect, thanks!
Old 01-10-2019, 03:07 PM #19
LinuxHack3r's Avatar
LinuxHack3r LinuxHack3r is offline
LinuxHack3r will become famous soon enough
Since you have this stereo (similar model) what did you do with the green parking brake wire? I’ve read that some stereos allow for just grounding that, where others require a device to simulate the parking brake hookup. I’m installing in my daughter’s Camry today and was planning to just ground it, but thought I better ask so not to damage the unit. Also, her factory JBL radio has 2 antenna inputs. What do you do with the small one?
Good questions! I actually just installed the Sony XAV-AX100 yesterday evening. I plan on a short writeup this evening with a few photos, but I'll try to answer your questions.
I did 100% absolutely nothing with the "parking brake" wire. I pulled it to the fuse panel where I was suppose to splice it. However, not being connected does not seem to affect CarPlay or the functions of the radio at all.
I suspect that Android Auto depends more on that wire than CarPlay does. Also, I [I]suspect[/] that if you try to play a video on the headunit from a USB drive, it would probably require the parking brake to be spliced.
I did not ground it or anything. Until I see a reason to do anything more, I'm leaving it exactly as is.
My stock Toyota radio had 2 antennas as well. It really threw me off for a while. I called Crutchfield, he basically said that (some) Toyotas have 2 antennas -- a short and a long one. I guess the factory radio can switch between the two. So far my radio seems to work as expected. You just use the bigger plug and set the smaller one aside.
My Build Thread
2007 Toyota 4Runner SR5 V6
LinuxHack3r is offline   Reply With QuoteReply With Quote
Old 01-10-2019, 03:24 PM #20
Awesome, thank you! I’ll just leave that parking brake wire loose for now then.
Old 01-10-2019, 03:28 PM #21
Save yourself potentially future trouble. Pull both he parking break and the reverse indicator to the fuse box while everything is apart. It took probably 5 minutes or less to pull the the right way. Will be much easier in the future if you decide to splice one or both wires to where they should be.
My Build Thread
Old 01-10-2019, 05:38 PM #22
Darn, I wish I saw this, or thought of it myself before the install! I put it in awhile ago, but the good news I should that it works awesome! Her car had a factory JBL with 6 disk changer, so I decided to get the integration harness so I could keep the amps. It not only sounds good, but it is seriously loud! I totally want this for my runner now, but I also wish it had the rear USB, so I’m going to keep looking for a bit before deciding. I mean, having the front USB isn’t a total deal breaker, but I was hoping to do a remote port near the DAC switch just for a cleaner setup with no wires hanging down.
Even though running those wires would’ve made future stuff easier, I still need to pull it one more time, as I didn’t have time to do the backup camera today, so whenever I get around to that, I’ll take your suggestion for sure.
Old 01-11-2019, 11:28 AM #23
Ausumm's Avatar
Ausumm Ausumm is offline
Ausumm is on a distinguished road
Ausumm's Avatar
I did this...
I put mine here, too.
I got the double USB...
one for power (charging) and the other for audio.
I did find that I kept bumping my USB thumb drive with it mounted there...
so I bought a low profile thumb drive and haven't had a problem since.
"Smokers Kit" + USB Mod-61xpukjricl-_sl1100_-jpg
Ausumm is offline   Reply With QuoteReply With Quote
Old 01-11-2019, 01:40 PM #24
TenTwelve's Avatar
Real Name: Eric
TenTwelve's Avatar
Real Name: Eric
Yeah, I can see the "burger tray" hitting a full size thumb drive. A USB cord is no problem though.
Old 01-17-2019, 01:09 AM #25
bob3dsf's Avatar
bob3dsf bob3dsf is offline
Real Name: Bob
bob3dsf will become famous soon enough
bob3dsf's Avatar
Real Name: Bob
I did this...
Dude, that's cool! I hate the OEM location of the AUX jack. You have a writeup?
2008 SR5 4WD (@280k!!)
bob3dsf is offline   Reply With QuoteReply With Quote
Old 01-17-2019, 10:56 AM #26
TenTwelve's Avatar
Real Name: Eric
TenTwelve's Avatar
Real Name: Eric
No write up. The little panel I bought has the USB and audio leads integrated and I just popped the blank switch, fished the leads through the hole, connected them to the back of my Pioneer H/U , and voila.
Old 01-25-2019, 06:12 PM #27
Installed, this thing looks and works great.
Pair it with the Anker Powerline+ II cable and it's a winner.
My Build Thread
Old 06-27-2019, 02:16 PM #28
WCHamby's Avatar
WCHamby WCHamby is offline
WCHamby is on a distinguished road
WCHamby's Avatar
How did the kwik seal ultra hold up? Any movement or is it pretty much solid?. I would also like to tack mine down but also, if I need to, just be able to peel it off if something goes wrong with the cable
WCHamby is offline   Reply With QuoteReply With Quote
Old 06-27-2019, 04:30 PM #29
royal T4R royal T4R is offline
royal T4R will become famous soon enough royal T4R will become famous soon enough
Seems like a fun mod, im going to give it a shot as I dont like how the standard non-smokers tray has to be flipped open all the time while I charge my phone.
royal T4R is offline   Reply With QuoteReply With Quote
Old 06-27-2019, 05:14 PM #30
0verland's Avatar
0verland 0verland is offline
0verland will become famous soon enough 0verland will become famous soon enough
0verland's Avatar
Best product in that shot is the Magpul phone case. Worth every penny and I wouldn't think of using anything else.
2006 V8 Limited 4WD
| Doug Thorley Headers | Gibson | Old Man Emu | ToyTec | SPC Performance | RCI Metalworks |
| Skid Mark 4x4 | SpiderTrax | BFGoodrich KO2 | aFe | Rutech | HCF Mod |
0verland is offline   Reply With QuoteReply With Quote
ashtray , headunit , kit , light , usb
Panman's Build & Adventures- A lot of "Crap, I hope this works" & "Eh, close enough" Panman 3rd gen T4Rs 28 05-09-2016 11:10 PM
NRA Calls Texas Open Carry Protests "Downright Weird" and "Just Not Neighborly" ndcent Off Topic 13 06-06-2014 08:29 PM
Call Him "Spiderman," Not "Antman." Maybe "Lefty." Kraeken 5th gen T4Rs 69 10-18-2013 08:24 PM
WTB: 4th Gen "4Runner," "Limited," and "Toyota" badges James_T Want to Buy/Trade 3 06-25-2011 11:42 AM
Zero point didnt work how to turn off "VSC TRAC" & "VSC OFF" & "ABS" lights sciff5 4th Gen T4Rs 6 09-27-2010 12:10 AM
