01-10-2019, 04:37 PM
#16
Originally Posted by WhiteBoomer04
I think $500 is around the right amount BUT....$800 is not unforseen because sometimes one bolt/nut tears into labor time.
I've done suspension swaps on many 4th gens and its incredible how long it can take on some trucks and not on others.
Best of luck.
thanks - the crew im dealing with now will treat me well and started at 580 so hopefully it goes well. i feel a bit better after realizing that i got my truck maybe 4 mos ago and it has pretty fresh KYB replacements in there already (drives awesome and lifts truck front end level for those looking for another leveling option,) but it didnt dawn on me that the shop wont be replacing 138k mile suspension, perhaps just 20k or 40k worth...ill still use some PB anyway over the next few weeks.
can anyone tell me if any bolt that might be seized, a typical shop would carry or be able to get while im gone for 5 days in the keys?
01-10-2019, 11:58 PM
#17
Real Name: Josh
Real Name: Josh
Seems pricey
01-11-2019, 12:27 AM
#18
Just had my lift installed this week. OME Front/Rear Shocks, OME 885/896 Front/Rear Coils, Front Top Plate Spacer, and Toytec Front Differential Drop Kit installed with alignment and 250-500 miles re-torque for $350.
2006 V8 Limited 4WD
| Doug Thorley Headers | Gibson | Old Man Emu | ToyTec | SPC Performance | RCI Metalworks |
| Skid Mark 4x4 | SpiderTrax | BFGoodrich KO2 | aFe | Rutech | HCF Mod |
01-11-2019, 11:30 AM
#19
nice ^ i see some of you in the 3-4 hundred range making out nicely. honestly in MA - ill accept the $580 quote i got, everything in this damn state is so expensive. tougher pill to swallow with how few places there are to wheel and camp; luckily i have one of the only legal places to do so about 15 minutes from my house, freetown state forrest.
01-11-2019, 03:08 PM
#20
Real Name: Mongy
Real Name: Mongy
360 for me, 800 seems to high.
01-11-2019, 04:10 PM
#21
The bolt that goes thru the lower shock eye and into the LCA. Mine seized in the bushing. Took hours to cut out.
Mark
04 V8 SE, RST Twin stick conversion. 4x4 Labs rear bumper, SW Sliders & Bullbar, ARB Locked F&R, 5.39’s, Smittybilt 10,000lb winch, 1.5 4Crawler BL, Flowmaster, CB and 2m/70cm Ham, Sat. Radio, CO2 system, Lightforce, African Outback Rack, Budbuilt, Front Runner RTT. Rock Solid Toys Solid axles, Atlas Crawl Case, 40" Cooper STT Pro's on Fuel Anza D116 beadlocks, 5:38 gear set, ADS Coilovers.
01-11-2019, 04:14 PM
#22
thanks for the info - hopefully that doesnt happen to mine and if it does they have a replacement bolt for the new shocks.
excited to have this scheduled though - getting the lift, rims and tire upgrade, sliders, and rear tire carrier pretty much all at once.
01-11-2019, 05:45 PM
#23
If youre pretty confident mechanically
you may consider having some assemble the struts for you and do the R & R yourself. Or rent yourself a spring compressor and DIY..
The rears even i can do but i did save some time and money just having mine assembled and not installed by someone else.
01-12-2019, 12:50 AM
#24
Originally Posted by JONBOY345
Mind sharing what shop you're using?
Coastal Automotive. It’s right before Awendaw and near Charleston. If you have any questions just send me a PM and I’ll help you out
🇺🇸 2005 Limited v8, 255/75/17 Mastercraft MXT, ToyTec 3” Lift With Superflex Rear Springs, LED Interior Swap, 161,000 Miles 🇺🇸
🇺🇸 2000 Limited 3.4, 166,000 Miles, Bone Stock...Currently 🇺🇸
05-31-2019, 04:21 PM
#25
Anyone have suspension/lift installed in the Dallas/North Dallas area have any recommendations and costs? The stealership quoted me $1,700, another shop never responded to my inquiry and a mobile mechanic quoted almost $900. I initially wanted to do it myself but don't have the tools nor the time.
06-02-2019, 10:09 PM
#26
Real Name: Topher
Real Name: Topher
Cant help for your area, but this may help for reference. I was quoted $800 to remove xreas suspension and install my icon stage 2 kit here in Houston
2009 Limited 4WD V6 Shadow Mica
ICON Stage 2 Kit SCS Ray10 17x8.5 BFG KO2 285/70r17
Rago Modular Storage Panels & Ditch Brackets * Prinsu Rack * Baja Designs Sqaudron Sports
KC Hilites Cyclones under hood * Blue Sea 12 Circuit Fuse Block * White LEDs Interior
Kenwood DMX906S Kenwood X802-5 Amp Infinity Front REF-6530cx & Rear REF-6532ex Pioneer TS-A2000LD2
06-02-2019, 10:30 PM
#27
Tandem Automotive in Haltom City--they specialize in Toyota trucks
They quoted me $450 for a suspension install including an alignment--was gonna take it to them before I just decided to do it myself. However, I did just have them replace the power steering pump and CV's about 2 weeks ago. Nice group of guys who know their stuff.
2006 Toyota 4Runner Limited 4x4 V6 Shadow Mica Sold
Dobinsons Suspension 300/221 Front & 505/637 Rear | FN Wheels f(x) pro | BFGoodrich KO2 275/70/17 | Front Runner Slimline II | ARB 2000 | Gobi Ladder | Treeline Outdoors Tamarack RTT
06-02-2019, 11:18 PM
#28
Thanks. I'll try and give them a call tomorrow.
09-30-2019, 09:40 PM
#29
did you get a quote from them?
they quoted me $1000 for install, alignment etc
09-30-2019, 10:05 PM
#30
Real Name: Bernard Chan
hey all - i have an appointment with longtime mechanic i knew in HS and was told for them to install my 5100s and OME springs (new kyb top hats too) that would be in the $800 range...does this seem fair assuming it goes smooth without running into any hardware issues?
too bad i didnt have the time or second vehicle to do this with my buddy Jay like we did with my wrx. the shop im going to lifted my old tj jeep but i dont remember many details from it.
thanks,
tom
If thats just labour alone, that is crazy steep. Im in Canada and went to a shop got charged $400 canadian for bilstein 5100+fj coils
