Old 09-30-2019, 10:01 PM #1
Pekoe1111 Pekoe1111 is offline
Pekoe1111 is on a distinguished road
Daystar 2.5 Front or Bilstein 5100 All Around?
I have a 2008 Limited with XREAS and rear air suspension, with both appearing to work fine.
I am purchasing 275/65-18 Duratracs and want an inexpensive 3” lift.
Understanding that I can adjust the rear air suspension to give me 3” for free (no real off-roading for me), I am focusing on the front.
Here's what I believe are my best options, but please weigh in!
1. Install the Daystar 2.5” spacer lift in front and keep XREAS intact; or
2. Replace front and back XREAS struts with Bilstein 5100 struts because I know XREAS connects front and back struts. I assume the Bilstein will give me the 2.5” lift in front - correct?
The Daystar 2.5 is about $100 and Bilsteins will cost almost $400, but I’m wondering if labor may be cheaper. Also thinking only a matter of time before XREAS needs to be scrapped and better to pay the labor for Bilsteins once.
Am I missing any other options?
Thanks!
BB
Pekoe1111 is offline   Reply With QuoteReply With Quote
Old 09-30-2019, 10:22 PM #2
Reading that 5100 rides stiffer than stock, which I do not want.
Old 10-01-2019, 11:31 AM #3
eleven14 eleven14 is offline
eleven14 has a spectacular aura about eleven14 has a spectacular aura about
Thanks!
BB
If it's strictly cost that you're basing your decision off of, the Daystar will be much cheaper labor-wise (only affecting the fronts, no XREAS removal, not touching the rears).
That said, paired with the correct springs, the 5100s will future-proof things for you. I pulled the XREAS off my '08 LTD last month and the shocks were OK but the springs were shot. Made a huge difference and rides perfectly.
Depending on your ultimate use/goals for the truck, the Daystar is likely only a stop-gap measure. I'll be swapping out coils on mine once I get a front bumper/sliders/tires, but already have the 5100s ready to go.
Hope that helps
eleven14 is offline   Reply With QuoteReply With Quote
Old 10-01-2019, 12:01 PM #4
jrm's Avatar
jrm jrm is offline
jrm will become famous soon enough
jrm jrm is offline
jrm's Avatar
The XREAS being was shot, was the reason the seller of my truck wanted to get rid of it. I swapped it out soon after i bought it. In your case theres no real need to replace what isnt broken. I know you can add spacers to XREAS but i think its limited to 2"s b/c of the XREAS line length/anchor points. Going over 2-2.25"s could require UCAs in order to retain front end suspension geometry though... Someone will correct me if im incorrect.
jrm is offline   Reply With QuoteReply With Quote
Old 10-01-2019, 12:05 PM #5
ROTC@CU ROTC@CU is offline
ROTC@CU is on a distinguished road
I went from the daystar to the 5100's when my stock shock started leaking. on road, i've not noticed to much difference in ride between the two. BOTH are stiffer than stock SR5 suspension, in a good way. I paired the 5100's with 5th gen coils. I'd go with the 5100's, if you have >100k on your existing suspension.
ROTC@CU is offline   Reply With QuoteReply With Quote
Old 10-01-2019, 01:32 PM #6
jfsjr92 jfsjr92 is offline
jfsjr92 is on a distinguished road
This. I'd go with the 5100s.
2004 SR5 V6 4WD
On a Journey from Stock to Built
So Far: removed running boards, Sony XAV-AX5000 receiver
Waiting Install: OME Coils, Billstein 5100s, 255/80r17 Falken Wildpeak
jfsjr92 is offline   Reply With QuoteReply With Quote
Old 10-02-2019, 05:36 PM #7
mijbr90190 mijbr90190 is offline
mijbr90190 is on a distinguished road
My 5100s are certainly stiffer than the xreas, but I feel like it handles corners so much better while still retaining comfort.
mijbr90190 is offline   Reply With QuoteReply With Quote
Old 10-03-2019, 12:56 PM #8
gaber6 gaber6 is offline
gaber6 has a spectacular aura about gaber6 has a spectacular aura about
I got the daystar 2.5 lift. This is my first SUV and lift and would do a regular suspension lift next time. Not that the result was bad, but a little firmer ride wouldn't be too bad and I'd rather have the full travel that a proper lift would give.
gaber6 is offline   Reply With QuoteReply With Quote
bilstein , daystar , front , lift , xreas
Daystar coming out- OME, Toytec Superflex and Bilstein 5100's going in Bigrupp 4th Gen T4Rs 42 12-06-2017 07:19 PM
Daystar kit and bilstein 5100's MOOSERunner 5th gen T4Rs 10 03-11-2015 10:19 AM
Daystar 2.5 w/ XREAS or Bilstein 5100 Neauxla 5th gen T4Rs 16 10-16-2014 11:48 PM
Front Bilstein 5100 shocks, FJ Springs, And Daystar 1.5" Rear Spacers Installed -Pics man03999 4th Gen T4Rs 39 06-12-2010 11:03 PM
