01-09-2019, 10:29 PM
Real Name: brian
Real Name: brian
New Eibach complete lift kit
Has anyone tried this kit yet? Price is good. Some iin the 5th gen board seem to like it.
Pro-Truck-Lift Stage 1 Lift System for 2003-2009 4Runner (E80-82-073-01-22)
'08 4Runner Limited V8 Shadow Mica: Sport hood, bilstein 6112's, 5160's, b12 coils, Gibson cat back, 4runner XSP rims, Michelin X LT AS 275/55-20
'06 4Runner Limited V8 Salsa Red: bilstein 6112, 5160, Wheeler T12's, 4Runner XP wheels, Michelin AT2 275/55/20, Magnaflow Exhaust,, Powerstop brakes, sport hood
RIP.....'08 4Runner Limited V6: white, bilstein 6112s, 5160s, b12 , powerstop brakes, nav, TRD cat back, 4Runner XP rims, Michelin Defender LTX 275/55-20, sport hood
01-10-2019, 01:31 AM
i wonder how this is different from the toytec setup of the past because they used eibach springs for their lifts.
1999 2.7 5MT - SOLD // 2007 V8 4WD - Gone
2011 FJ 4WD - to new beginnings
// 4G V8 // 3G 2.7 5MT // Model 3 // IS300 5MT // FD RX7 //
01-10-2019, 07:45 AM
Looks like a quality setup. The only concern I’d have is there doesn’t seem to be any spring rate info, which for some is important. For example, I carry a lot of tools for my work, so the rear was sagging on mine. After a ton of research I determined that OME 2895E springs would handle the weight, and get the stance I was looking for with my mild front lift (Tacoma Bilsteins and springs). That is a great price for everything, but without knowing the spring rates, I wouldn’t chance it for my situation. Stock setup, definitely would a contender though.
2004 black SR5 V8 4WD with TRD dual exhaust, Thorley headers, AFE dry filter, Sprint Booster, Icon 2.0 rear shocks, OME 895E springs, Fuel wheels with 265/70/17 Wildpeak AT3W tires, more to come...
01-10-2019, 10:36 AM
https://www.toyota-4runner.org/5th-g...53184-eibach-p
I know it's a 5th gen link, but may give you an idea on the kit. It was posted that front spring rate is 660lbs and real is 205lbs. I would call eibach and confirm.
01-10-2019, 12:15 PM
Real Name: brian
Real Name: brian
Originally Posted by Charlievee
Thanks but the link does not work.
01-10-2019, 12:47 PM
Real Name: Chris
Real Name: Chris
Originally Posted by inscarguy
If you go to the spring only page they list the front spec.
628 front
rear doesn't list anything but I would guess 250-260
2005 V8 Limited. ARB Bumper, ARB Touring rack, Bilstein 5100 with Toytec 3" Tacoma springs, OME 2895's, 255/80 Cooper ST Maxx. TG spacers. JBA UCA.
01-10-2019, 06:13 PM
I have the same lift on my 2006 4runner, i like it the ride is smooth way better than stock. The stock suspension was bottoming out on the slightest bumps. Also keeps the cv axles straight as long as you keep it at the first notch like the instructions say. You still have adjustment room to add heavier front gear (ie offroad bumper, winch, batteries) adjust to the next level when needed
However, it does still have a slight rake. i'll take pictures to show you and post it up
2006 SR5 4wd, Eibach lift kit, mods in work..
01-10-2019, 07:16 PM
Real Name: brian
Real Name: brian
Thanks . That pic you sent, is that with the lift?
01-10-2019, 08:02 PM
Yes it is, had it on for roughly month already.
